SBC Count question? - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 06-23-2019, 08:25 PM Thread Starter
Date registered: Sep 2006
Vehicle: 2005 e320 cdi
Quoted: 7 Post(s)
SBC Count question?
I had the white BRAKE visit workshop on my cluster. I thought it was the rear pads so I changed them but while in therethere they looked ok so I put on new ones anyhow. I did the fronts about 7K ago so knew that was not it. Scanner was showing a SBC error so I ended up putting it in the dealer. Brakes were working fine though. Dealer confirmed an internal error and put on a new pump under warranty. I suspect it was a software issue, maybe the counts were reached? The PO had the pump replaced about 4 years ago, so??
Anyway, my scanner can get the counts of the pump so I did a before and after the new pump. Why is the pump not set back to zero? As you can see, before was 746433 and after was 331779.
ID:	2523206   Click image for larger version
arcteryx is offline
post #2 of 8 (permalink) Old 06-24-2019, 04:35 AM
Purple Moderator
Date registered: Jul 2005
Quoted: 1510 Post(s)
Just a guess but perhaps MB forgot to reset the pump unit they put in.
They are using reman units for this work so my guess is that that count
is from the reman unit.
Noodles is offline
post #3 of 8 (permalink) Old 06-25-2019, 08:43 AM
Kajtek1's Avatar
Quoted: 1977 Post(s)
Good question to ask your SA.
They reset 1/2 of the count? That sucks.
MB part person told me that what is sold as "remanufactured" parts are actually new parts, but getting the core back prevents aftermarket doing monkey jobs on them.
Kajtek1 is online now
post #4 of 8 (permalink) Old 06-26-2019, 05:49 AM
Date registered: Oct 2015
Vehicle: 2006 E320 CDI
Quoted: 66 Post(s)
That makes sense. I wonder if the best thing to do is simply to reset the counter to zero. Can the Foxwell do that?
06 E320 CDI "Benson", Platinum Blue, 175k mi
06 E320 CDI "Rutherford", Black, 145k mi
91 300D "Otis", Smoke Silver, 129k mi
98 E300 "Murray", Silver, 129k mi, Stage 2 Rocketchip chip tuned, under son's care
Eleven other MB's owned and sold
2002 Honda Odyssey 255k mi (want to name it "Homer," wife won't let me)
1961 Very Tolerant Wife
shertex is offline
post #5 of 8 (permalink) Old 06-26-2019, 09:14 AM
Kajtek1's Avatar
That's the question you might have to find answer for.
I have the button on my MaxiEcu, but sold the car with SBC and never used it.
With scanners you have to find their possibilities the hard way.
post #6 of 8 (permalink) Old 06-26-2019, 10:17 AM
Purple Moderator
The Foxwell can not as far as I know.
MB SDS in developer mode can, but brush up on your German reading skills.
There are also a myriad of SBC counter reset tools available on eBAy and Ali, but those I put in the use at your own risk category.
Noodles is offline
post #7 of 8 (permalink) Old 06-26-2019, 07:48 PM Thread Starter
Quoted: 7 Post(s)
I do not think it can. It's not a big deal, I have a new pump and know the starting point, but was curious. I may reach out to the SA and see what he says.
arcteryx is offline
post #8 of 8 (permalink) Old 06-27-2019, 08:51 AM
Purple Moderator
We know the pump was replaced, but what if the number of counts is already seen by the SBC control unit?
That unit is what tracks and then condemns the pump based on actuations. If that is the case you got repaired
SBC system, but it may already appear to the SBC control unit that about 40% of your actuations have happened.
I would ask the dealer if that is not a big deal as it may still be covered under the 25 year extension. Or can they
zero out the counter?
Noodles is offline
