Timing Chain Tensioner Question - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 05-21-2019, 09:46 AM Thread Starter
Date registered: Mar 2019
Vehicle: 2003 E320
When replacing the timing chain tensioner, is it just a "pull out the old one-put in the new one job"? Or do I have to do something else after in regards to the timing/timing chain?
2003 E320, 122k miles, makes tapping sound when load is put on the engine, but smooth at idle and when rev'd...
Thanks, J
JesusL is offline
post #2 of 5 (permalink) Old 05-21-2019, 11:12 AM
tjts1's Avatar
Date registered: Apr 2009
Vehicle: 87 300D 5 speed
Quoted: 688 Post(s)
Thanks, J
Check your oil pressure first. There's an O ring between the oil pickup tube and pump which is known to fail on the M112 and M113 engines. These cars didn't get an oil pressure gauge or warning light from the factory. When the O ring fails you have no way of knowing until the engine starts to make strange noises.
Triggering religious fanatics since 1969
tjts1 is online now
post #3 of 5 (permalink) Old 05-30-2019, 03:25 PM Thread Starter
Vehicle: 2003 E320
Does this o-ring go on the filter housing? or is this a different ring? Sorry for my confusion
JesusL is offline
post #4 of 5 (permalink) Old 05-30-2019, 04:55 PM
Date registered: Oct 2017
Vehicle: 2006 cdi, 1993 500e
Quoted: 42 Post(s)
I think he's talking about the pickup tube which carries the oil from the bottom of the pan to the oil pump.
Legodude is offline
post #5 of 5 (permalink) Old 05-30-2019, 05:03 PM
tjts1's Avatar
Quoted: 688 Post(s)
https://youtu.be/_TG9Und29dI
tjts1 is online now
Do It Yourself (DIY) repair thread and wheel and tyre thread Dr.Grillz W126 S,SE,SEC,SEL,SD,SDL Class 249 05-28-2019 11:35 AM
Euro AMG M117 5.0 - Timing Chain & Tensioner Job w Pictures! FloridaCole W126 S,SE,SEC,SEL,SD,SDL Class 11 10-26-2012 05:10 PM
My Stupid Noob Question of the Day - Timing Chain Reversity R/C107 SL/SLC Class 18 08-30-2011 05:45 PM
How to reset timing chain tensioner after removal 10seccorrado W202 C-Class 2 06-05-2011 06:14 PM
300 diesel (nonturbo) timing chain tensioner question Thomas.Schumacher W123 E,CE,D,CD,TD,TE Class 3 12-23-2004 06:13 AM
