Timing Chain? Timing Chain Tensioner? Or What? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-14-2019, 09:30 AM Thread Starter
Date registered: Mar 2019
Vehicle: 2003 E320
So I bought my 2003 E320 about 3 months ago with 119k miles. Ever since there has been a tapping/rattling sound which I have not been able to find/fix. The car has almost 123k miles now. I have cleaned the MAF sensor, replaced spark plugs, changed the oil and filter and the air filters, and have used fuel additives in some full tanks, 1 Chevron and and 2 Lucas. I like Lucas better, the engine seems to run smoother and quieter. I also replaced the crankshaft position sensor last week as it would not start sometimes and the scanner showed the code for it. I believe the motor mounts need to be replaced as they show some leakage, but there is no vibration at idle at all, just noise on acceleration.
Now the tapping noise does not happen at idle, even if I rev it. It only happens on acceleration and goes away as speed increases. But if I get my foot off the pedal for a second or two when accelerating, the tapping goes away, and comes back when I press the pedal again. So basically it makes the sound only when there is load on the engine.
After reading extensively on google, I am thinking it might be the timing chain or the tensioner. I have posted a couple of videos on youtube. One for cold start and one for warm start. Here are the links:
Cold Start:
Warm Start:
Any advice and comments are greatly appreciated.
Thanks, J
JesusL is offline
post #2 of 3 (permalink) Old 05-15-2019, 02:34 AM
Benzyle's Avatar
Date registered: Nov 2013
Vehicle: MY05 CLK55 AMG , MY05 CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
Quoted: 300 Post(s)
Doesn't sound too bad to me...
These engines are usually trouble free when it comes to timing chain and tensioner.
Sometimes they have a tick from lifters ,,but that is usually fixed by a good oil change and drive at higher rpm.
Under load ,,,is it pinging ? Is your fuel good quality high octane..?
Benzyle is offline
post #3 of 3 (permalink) Old 05-15-2019, 08:57 AM
ot1
Date registered: Apr 2007
Vehicle: 2006 E320 CDI
Quoted: 143 Post(s)
Bearing rattle, pull the belt off and check for play in idler pulleys and tensioner. Also i hear a whir sound, maybe water pump
ot1 is offline
Timing Chain Tensioner M119.98 Drbobme1 W140 S-Class 4 01-18-2016 08:17 AM
complete timing chain job parts new W126, R107 aroundthescenes For Sale/Wanted/Trade/Giveaway 1 12-01-2015 05:43 PM
How to reset timing chain tensioner after removal 10seccorrado W202 C-Class 2 06-05-2011 06:14 PM
HELP!...Timing chain adjustment and engine wont turn! miroxz W140 S-Class 16 02-26-2008 12:06 AM
timing chain, rails replacement baido R/C107 SL/SLC Class 0 08-12-2007 02:47 PM
