Cooling system lasted about 15 years! :) - Page 5 - Mercedes-Benz Forum
post #41 of 48 (permalink) Old 05-10-2019, 02:07 PM
Kajtek1's Avatar
Quoted: 1932 Post(s)
Just becouse you don't see junk on top of the radiator, doesn't mean it is not packed at the bottom.
Anyway, I always appreciate when somebody volunteer to be Guinea Pig.
Still even with your positive review, I am not taking my chances for $5 saving.
We are long way from times when radiators cost $120.
Kajtek1 is offline
post #42 of 48 (permalink) Old 05-11-2019, 06:40 AM
ot1
Date registered: Apr 2007
Vehicle: 2006 E320 CDI
Quoted: 130 Post(s)
Originally Posted by Kajtek1 View Post
The cluster gauge is dummy gauge, or at least on my 2008 model.
I drove it with temp displayed on climatronic and when going downhill engine cooled down to 75C, the dash gauge did not drop from 82C.
Water pumps can outlast the car, so you never know.
The best preemptive repair is get a new car.
On my 2006 e320 cdi, the cluster temp gauge is definatly not a dummy, when the thermostat went out in the dead of winter, my gauge would only get up about about 40 degrees during a long idle, once the car was underway the gauge would drop to 10 or lower.
ot1 is offline
post #43 of 48 (permalink) Old 05-11-2019, 07:42 AM
ot1
Quoted: 130 Post(s)
Originally Posted by Benzyle View Post
For me a water pump is not a maintenance item....if it ain't broke ,,dont fix it..
For me the water pump is now a maintenace item. If you have a second car to drive, someone to come and get you when you break down, and live near a dealer, dont travel far from home, etc them ok maybe not, but
One very cold and snowy Friday evening and several hundred miles from home, my low coolant warning came on, had to stop at three different connivence stores before i could get even a gallon of distilled water. Found a dealer, 50 miles away, just before closing, they didnt have a pump in stock, werent sure when it would come in because it was during Christmas/New Year holidays and they were backlogged a week so next Friday. So only bought coolant from the dealer. I ordered a pump from FCP while sitting at the dealers. Went to A grocery that was closed but I snuck in through the out door, a self checkout register was lit, so I managed to buy 5 gallons of distilled, by the time I got home at midnight I had used 4.5 gallons. I got the pump Monday dec 31, and put it on, wasn’t too diificult, had to pull the fan. And make sure there is no grime and grit under the high pressure fuel pump. This is why its a maintenance item for me from now on.
smyers likes this.
ot1 is offline
post #44 of 48 (permalink) Old 05-12-2019, 10:08 PM
Benzyle's Avatar
Date registered: Nov 2013
Vehicle: MY05 CLK55 AMG , MY05 CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
Quoted: 277 Post(s)
Fair enough each to his own ,,,
In 40 years of car ownership ,,mostly all over 10 years old ,,,I have only ever had to replace one water pump ,,,,as designed it started leaking slowly at the weep hole,,,,plenty of warning and time to get a new pump and get organised.
Benzyle is offline
post #45 of 48 (permalink) Old 05-13-2019, 07:07 AM Thread Starter
mgill85258's Avatar
Date registered: Oct 2006
Vehicle: 2005 W211 E320
Quoted: 30 Post(s)
I've had 6 total MB's now, all at least 15 years old or more, and I've also only replaced one water pump ever. It was on a 1995 C220.
Matt
Current:
2005 W211 E320
Previously Owned:
1999 W210 E320
2013 W451 fortwo pure
1997 W202 C230
1996 W202 C220
1996 W140 S320 L
1995 W202 C220
mgill85258 is offline
post #46 of 48 (permalink) Old 05-13-2019, 07:42 PM
ot1
Quoted: 130 Post(s)
Mine failed at 159,000 miles.
ot1 is offline
post #47 of 48 (permalink) Old 05-14-2019, 04:39 AM
Date registered: Jul 2010
Vehicle: 2006 e320 CDI
Quoted: 64 Post(s)
I have you beat by 700 miles. Mine failed at 158,300, approximately 1,500 miles and 30 days after I had the system flushed and new anti freeze installed. My indie also said the pulley's were loose/noisy and just waiting to fail. He also changed the serpentine belt and upper radiator hose.
Mike T.
mtrevelino is offline
post #48 of 48 (permalink) Old 05-14-2019, 07:06 AM
ot1
Quoted: 130 Post(s)
Mike T.
Replaced both idler pulleys 141800 mi 5/14/2018
Belt tensioner and Belt 141102 mi. 4/25/2018
First I replaced just the tensioner pulley as it wobbled badly and a shreading belt, I noticed the belt not tracking straight, starting to lose a rib a couple of weeks later and so the whole tensioner and another new belt under warranty, one idler had slop, ordered the idlers to be safe.
ot1 is offline
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
SBC Brake Flush Revisited (Again) - In Great Detail smyers The Discount Tire Direct Tire, Wheel, Brake & Suspension 8 05-11-2019 02:17 PM
Got Codes? Check this list Check Codes W210 E-Class 80 06-12-2017 09:00 PM
W140 Fix it Yourself Articles Merc600sec W140 S-Class 265 11-04-2015 11:17 PM
M104, oil in cooling system strange problem.... devcrk W124 E,CE,D,TD Class 11 11-16-2010 08:58 PM
test Jillian80 Test 5 06-09-2008 11:28 AM
