Cooling system lasted about 15 years! :) - Page 2 - Mercedes-Benz Forum
post #11 of 48 (permalink) Old 05-04-2019, 03:27 AM
Vehicle: 1999 E430; 2005 ML500
Quoted: 96 Post(s)
Originally Posted by Benzyle View Post
For me a water pump is not a maintenance item....if it ain't broke ,,dont fix it..
Except for timing belt driven pumps, then replace when you do the belt.
Hirnbeiss is offline
post #12 of 48 (permalink) Old 05-04-2019, 04:53 AM
Date registered: Jul 2010
Vehicle: 2006 e320 CDI
Quoted: 64 Post(s)
My take is if you do a system flush, the water pump will start leaking after one month. Been there, done that!
Mike T.
mtrevelino is online now
post #13 of 48 (permalink) Old 05-04-2019, 05:41 AM
tjts1's Avatar
Date registered: Apr 2009
Vehicle: 87 300D 5 speed
Quoted: 687 Post(s)
The water pump might not be a maintainance item for you but it is a maintainance item for your engine. It ain't broke until it's broke and you're sitting on the side of the road with an overheated engine.
https://youtu.be/OhLqWu5yCK4
Triggering religious fanatics since 1969
tjts1 is online now
post #14 of 48 (permalink) Old 05-05-2019, 06:13 PM
Date registered: Sep 2016
Vehicle: 2002 E55 AMG Sedan
Quoted: 270 Post(s)
I don't think the radiator on the e320 is inadequate. Having a larger radiator isn't always a good thing. If you are doing something that stresses the engine like towing or racing, etc then you DO want a larger radiator. But a radiator that's too large for the engine means the engine is going to struggle to maintain the proper operating temperature and that's not good either.
Remember Mercedes have been using the same engine and radiator since 1998 in the W210. So they believe the setup is fine.
illstplaya is offline
post #15 of 48 (permalink) Old 05-05-2019, 09:12 PM
Kajtek1's Avatar
Quoted: 1957 Post(s)
Per my experience MB designs cooling system for pulling 2 tons trailers on Sahara desert in triple digits temperatures and driving E300DT with engine fan removed proves it.
But I am religious on using MB only coolant.
With water pumps you just never know.
Sure when you are doing other jobs, replacing the pump at 250,000 miles might be reasonable, but as pointed above -failing bearings will give you some warning with drip.
Benzyle likes this.
Kajtek1 is online now
post #16 of 48 (permalink) Old 05-06-2019, 12:42 AM
tjts1's Avatar
Quoted: 687 Post(s)
They didn't use the same radiator on the W210 E320. That radiator core is 32mm thick. I've worked on a lot of MBs and I've never encountered a 16mm radiator core before this 04 E320. I'm not sure how a 34mm radiator core could "over cool" an engine with a functioning thermostat but I'd love to hear more about that theory.
E300 diesel has a 40mm radiator core from the factory. But I've got this fancy new and improved 16mm radiator just gathering dust in my garage. I think you should try it in your fanless E300. Its no thicker than your AC condenser. I hear it does wonders for your engine's cooling system.
LOL
tjts1 is online now
post #17 of 48 (permalink) Old 05-06-2019, 08:21 AM
Kajtek1's Avatar
For radiators it is frontal surface and number of rows that counts for heat exchange.
Obviously thicker radiator might indicate more rows, but not necessary.
I also did remove the only fan on Fiat 125 and drove it just fine without it.
But that was in Poland, where we did not see triple digits temperatures.
So once again, I never had any signs of MB overheating even I routinely drive in temp above 100F and some of my cars had high 200's thousands miles. .
I prize MB coolant for high efficiency and used it even in my trucks.
First result was that truck engine visco fan stop coming on in city traffic. Those fans were over 20 hp rated, so you could definitely tell when they are on.
That not only made driving more comfortable, but saved fuel as well.
Consider that before trying to save 5 bucks on Zerex
post #18 of 48 (permalink) Old 05-06-2019, 01:01 PM
tjts1's Avatar
Quoted: 687 Post(s)
Actually you forgot about total surface area. Oops.
But if you really think it's all about frontal area but all means the 16mm radiator is ready to go.
tjts1 is online now
post #19 of 48 (permalink) Old 05-06-2019, 07:35 PM
Quoted: 270 Post(s)
The same reason why people that live in extremely cold climates block off part off their grill or radiator. Too much cooling is not good. The thermostat won't be able to keep up with the extra unneeded cooling.
How do you explain the E320's not over heating? If the radiator was too small then why hasn't anyone had a problem?
post #20 of 48 (permalink) Old 05-07-2019, 04:33 PM
Date registered: Nov 2007
Vehicle: 2001 ML430
Quoted: 2 Post(s)
Originally Posted by mgill85258 View Post
Had radiator, upper and lower hoses, bleeder line, and expansion tank all totally swapped for brand new stuff.
Apparently the expansion tank is lovingly referred to as the 'explosion tank' by the auto techs. Eventually they'll just burst from the constant expanding/contracting with the heat and pressure, etc.
Should be all set for at least another 15 years, I guess. I suppose it's definitely suggested that if you're replacing the radiator just go ahead and do all those other items as well so you don't need to go back and drain/refill and replace the expansion tank when that decides to go.
Hopefully that was the largest repair bill I'll have to deal with for some time.
Horrid! Only 15 years. Should last 30 years or more with other than annual coolant changes and occasional coolant hose replacements. No reason for the radiator or expansion tank to have failed that fast unless you've been filling it with salt water.
billferreira is offline
SBC Brake Flush Revisited (Again) - In Great Detail smyers The Discount Tire Direct Tire, Wheel, Brake & Suspension 8 05-11-2019 02:17 PM
Got Codes? Check this list Check Codes W210 E-Class 80 06-12-2017 09:00 PM
W140 Fix it Yourself Articles Merc600sec W140 S-Class 265 11-04-2015 11:17 PM
M104, oil in cooling system strange problem.... devcrk W124 E,CE,D,TD Class 11 11-16-2010 08:58 PM
test Jillian80 Test 5 06-09-2008 11:28 AM
