Ordered new low beams! - GE Nighthawk Xenon - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 04-25-2019, 06:38 AM Thread Starter
mgill85258's Avatar
Date registered: Oct 2006
Vehicle: 2005 W211 E320
Quoted: 30 Post(s)
So I just got this car and I swear the low beams are original because they're very, very dim...
I will replace them with GE Lighting H7 55NHX/BP2 Nighthawk Xenon, available here:
https://www.amazon.com/gp/product/B00GZHC2EE
According to Daniel Stern lighting and many of the users on candle power forums, these are quite literally the best H7 bulb money can buy. So, I'll give it a shot!
I can post some pictures of how they look in the car afterward.
Matt
Current:
2005 W211 E320
Previously Owned:
1999 W210 E320
2013 W451 fortwo pure
1997 W202 C230
1996 W202 C220
1996 W140 S320 L
1995 W202 C220
mgill85258 is offline
post #2 of 6 (permalink) Old 04-25-2019, 07:51 AM
tjts1's Avatar
Date registered: Apr 2009
Vehicle: 87 300D 5 speed
Quoted: 671 Post(s)
If your w211 wasnt equipped with factory hids, I suggest find in a set of used HID housings and swapping them in. Even if the lenses are yellowed you can replace those for $40 then code the car for HIDs.
Triggering religious fanatics since 1969
tjts1 is offline
post #3 of 6 (permalink) Old 04-25-2019, 08:07 AM
Date registered: May 2016
Vehicle: 2000 S430, 2003 S430, 2003 S600 TT, and 2005 E320 CDI
Quoted: 901 Post(s)
Variation on the above: you can do what I did and refurb your factory halogens with HID ballasts, projectors, and bulbs. Coding the car for XENON PRESENT afterwards is very easy with SDS.
2000 S430 (Dad's car, used for special occasions)
2003 S430 (one of two current DD's--second W220 project car, just for fun--decided to keep it after all)
2003 S600 (third w220 project car, the sports car)
2005 E320 CDI (the other current DD--first W211 project car)
Formerly--AND ONCE AGAIN! (I just married the girl):
2000 S500 (best friend's--now WIFE's--DD: my first W220 project car, once gone to, AND NOW RETURNED FROM, an excellent home--welcome back home, baby!)
cowboyt is offline
post #4 of 6 (permalink) Old 04-25-2019, 09:26 AM Thread Starter
mgill85258's Avatar
Quoted: 30 Post(s)
HID's sound nice but I keep seeing stories of them failing and then it's expensive when they go out, right? I figure H7's are pretty reliable and I just swap a cheap bulb when they die... ?
I have never had HID's though, so... I mean, is there any good before/after comparison I can see? Are they truly worth it?
Thanks
Matt
Current:
2005 W211 E320
Previously Owned:
1999 W210 E320
1997 W202 C230
1996 W202 C220
1996 W140 S320 L
1995 W202 C220
post #5 of 6 (permalink) Old 04-25-2019, 10:27 AM
Quoted: 901 Post(s)
Actually, there is. It's one of my threads in the W220 forum, featuring the E320 CDI in one of the posts.
Here's the page that shows, as an example, halogen high-beams vs. HID high-beams. Low-beam performance is similar. Look for the post comparing the S430 vs. the S500. The S430 here has "single xenon" low-beams, and traditional high-beams. The S500 has the exact same headlight assembly, but upgraded by me to bi-xenon (low- and high-beam HID).
https://www.benzworld.org/forums/w22...l#post16712538
And here is what my E320 CDI's new headlights look like. I hadn't taken "before" pictures on this car, but the difference was *stark*, I assure you.
https://www.benzworld.org/forums/w22...factory-4.html
We also have two Honda Civics. I have converted one of them from halogen to HID. Compared to the other Civic of similar vintage, the HID-equipped Civic is so far and away brighter that they're not even in the same conversation anymore. Really.
Here's what the Civic looks like now.
https://www.benzworld.org/forums/w22...l#post17192394
As for reliability, if you get junk, yep, they're unreliable...just like with anything else. I admit that I made that mistake on the Civic in one area (the bulb-to-ballast adaptor), since replaced with a quality adaptor that is rock-solid. Amazing what just $5 more will do for quality. :-) And that's really the key; if you stick with quality stuff, e. g. Hella Gen 3 ballasts, Osram/Philips/Jahn bulbs, and either Hella or Morimoto projectors, I've found the HID's to be very reliable, indeed. I love 'em, and there's no way I'd ever go back now.
But aren't the bulbs expensive?
Not much more than a pair of those "xenon" halogen bulbs, really. Expect to pay, real-world, between $60 and $100 for a pair of good, non-Chinesium bulbs. I go into this extensively in the aforementioned thread. Remember, though, that HID bulbs will last 17 years. How do I know that? Because the project 2000 S500 was 17 years and 135,000 miles old when I bought it, and it was pretty clear due to the "blue shift" that those were the original bulbs. Yeah, baby. That's why I stick with Osram, Philips, and Jahn. You'll likely get at least 15 years out of your bulbs, perhaps more.
cowboyt is offline
post #6 of 6 (permalink) Old 04-25-2019, 10:52 AM Thread Starter
mgill85258's Avatar
Quoted: 30 Post(s)
Good information. I will definitely consider this later on. For now hopefully these new bulbs hold up just fine for a while and will at least give me some time to figure out what works best for HID's if I opt for that route.
Thanks!
Matt
Current:
2005 W211 E320
Previously Owned:
1999 W210 E320
1997 W202 C230
1996 W202 C220
1996 W140 S320 L
1995 W202 C220
R350 Xenon Low Beam Lamp Replacment jkoeh W251 R-Class 3 04-01-2017 05:23 PM
Low Beams Dont work art_arev W163 M-Class 123 12-06-2014 06:17 PM
Pssnger Xenon Low Bean Sometimes does not turn on.. Camsky General Mercedes-Benz 0 01-27-2011 07:35 AM
We Need A Permanent Sticky for Error Codes Hary Gahtoe C208/A208 CLK-Class 22 01-22-2010 12:11 PM
New bulbs for my AMG fog lamps, Xenon low beams, and Halogen high beams. lynns R129 SL-Class 17 01-16-2010 03:54 PM
