2006 E320 CDI - Refurbishing my beloved ride. Looking for things I might miss. - Page 8 - Mercedes-Benz Forum
post #71 of 217 (permalink) Old 04-29-2019, 12:49 PM Thread Starter
Date registered: Sep 2007
Vehicle: 2006 E320 CDI
Quoted: 41 Post(s)
Originally Posted by cowboyt View Post
You can also use the newer G-48 "blue" fluid, which came out in (I think) 2008. Think of it as the new Zerex G-05.
Thanks. My spec sheet says the very same thing. I'm sure it came with G-05 from the factory.
smyers is offline
post #72 of 217 (permalink) Old 04-29-2019, 06:36 PM
Kajtek1's Avatar
Quoted: 1979 Post(s)
Again, it is religion. Some owners use Zerex only as this saves $5 over MB coolant.
I read too many topics with engine overheating issues and too often it turned out Zerex was involved.
Maybe my impression is biased, maybe not, but for 5 bucks I am not going to Guinea pig.
Kajtek1 is offline
post #73 of 217 (permalink) Old 04-30-2019, 04:06 AM Thread Starter
Quoted: 41 Post(s)
Thanks Kajtek1. Very interesting discussion. This forced me to take the time to look closely at this. The guys here may already know what I'm about to spew. I'll just go with the MB fluid... if I can. I'm not that interested in the $5 savings... obviously. My only coolant flush that was done at this point was done by the dealership many miles ago (at least 4 years ago perhaps), so yes, they used MB coolant. It is green, so it is the 325.0 spec that is equivalent to G-05. Below is the spec sheet from the manual. At the bottom, it shows the Zerex fluid, which is part of the MB spec.
As far as cooling goes, all the MB spec coolants are 99% ethylene glycol, minus the water, with the 1% being additives. So the heat transfer capability of each one is identical. Zero difference. So the only thing that can make for a problem is the additive package, which is about anti-corrosion and anti-oxidation.
If you get incompatible additives, you can have a BIG problem. Zerex G-05 uses a HOAT additive package, as does the MB 325.0 spec fluid. But it does appear that the the newer 325.0 MB fluid is akin to the Zerex G-48 spec, both of which also use a HOAT additive package. Regardless, all should be compatible and not cause any reaction with each other, as they are on the factory spec list. Is one as good as the other for protection? I don't know.
One thing to be careful of that I need to look into more - The newer MB coolant that is pink (325.5 spec) that uses a Si-OAT additive package that is NOT compatible with the original 325.0 spec coolants that use HOAT additives. It does look like I can get the 325.0 spec from FCP Euro, so it must be available. It is the Blue, so it is the G-48 equivalent.
But point taken and I'll do a bit more research.
Name:	Coolant Specs.jpg
smyers is offline
post #74 of 217 (permalink) Old 04-30-2019, 05:30 AM
Rossafuss's Avatar
Date registered: Oct 2013
Vehicle: 2005 E320 CDI *black on black with nearly every option*
Quoted: 195 Post(s)
iv'e never had any issue with Zerex. My guess is anyone that's run into any issues aren't allowing their engine to burp itself, which results in the cooling system being under filled.
I always remove the upper radiator hose at the rad, and add coolant into that hose into the block. greatly reduces the amount of burping that has to be done.
cowboyt likes this.
_______________________________________
"Concentrated power is not rendered harmless by the good intentions of those who create it."
2005 CLK320 - Wifes DD
2005 E320 CDI - Black on Black 450K+miles - MY current DD
2006 E320 CDI - Dads DD
2007 E320 Bluetec - Sisters DD
2008 ML320 CDI - Mothers DD
Gone:
83 300SD
86 190D 2.5
91 300D
95 C280
97 C280
99 E300D
Rossafuss is offline
post #75 of 217 (permalink) Old 04-30-2019, 05:56 AM Thread Starter
Quoted: 41 Post(s)
Which is exactly why I just purchased the vacuum filling system. Takes all the "I think I got the air out" doubt. I'll report back on how well it works once I use it. Based on what I'm hearing from those that have them, it seems like it's the way to go these days since we no longer have old school radiator caps and expansion on the top of the radiators.
smyers is offline
post #76 of 217 (permalink) Old 04-30-2019, 11:28 AM Thread Starter
Quoted: 41 Post(s)
Originally Posted by Legodude View Post
I think that leak point is pretty common. That's the mixing chamber to intake gasket. The bolt spacing is a bit large. It's not a terribly hard job- just take some time. I did mine without draining the coolant.
The gasket is a thin stainless with a coating of teflon to "seal".
Michael
I just finished up the mixer pipe gasket replacement task. As you said, it's not super hard... but it is a time eater. Plenty of bolts that are a bit difficult to get to and get retorqued properly. Wobble extension are your friends on this one. And man, the mess that had to be cleaned down the charge air pipe. I think I went through nearly a full bottle of simple green.
The mixer pipe wasn't as gunked up internally as I would have thought after 320K miles.
Unfortunately, she was down for 4 days because when I ordered my seals, I forgot the gasket for the exhaust gas cooler/manifold interface and I started the job on a Friday evening and the only place I could find that $4 gasket was through a dealer. So I had to wait on that part to finish the assembly. Doh!
Name:	2019-04-26 19.01.04.jpg
ID:	2508764   Click image for larger version
Name:	2019-04-26 19.01.01.jpg
ID:	2508766   Click image for larger version
Name:	2019-04-26 20.58.10.jpg
smyers is offline
post #77 of 217 (permalink) Old 04-30-2019, 01:38 PM
Date registered: Nov 2009
Quoted: 72 Post(s)
Just replaced my diesel return lines between injectors and to the fuel filter. Easy job. Are you sure yours are still pliable? My 06 has only 118k miles and the rubber was hard and had to be cut off the nipples.
John
hangit is offline
post #78 of 217 (permalink) Old 05-01-2019, 04:21 AM Thread Starter
Quoted: 41 Post(s)
John
That's what you meant when you said fuel lines in the previous post. I thought you meant the main rubber lines off the filter.
You are right, those are getting stiff, especially those that were covered in black death. Where does that hose go to exactly that comes off the rear Tee. I haven't chased it. To the fuel filter somehow?
smyers is offline
post #79 of 217 (permalink) Old 05-01-2019, 04:55 AM
Quoted: 72 Post(s)
Yes, the rear hose goes to what I think is a banjo bolt that leads to the fuel filter. Not too difficult to get to.
John
hangit is offline
post #80 of 217 (permalink) Old 05-01-2019, 07:40 AM Thread Starter
Quoted: 41 Post(s)
John
Where can I get that fancy braid covered hose? The dealership only sells the entire thing as an assembly... for $225. That's one of those ridiculously high priced parts. I guess I should do the o-rings on the fittings as well, but those too are not listed as a part. I can go get them sized at an o-ring supplier. I don't know the original material, but Viton is compatible with diesel and good for 205F.
EDIT - Never mind! Looks like RPEuropean.com carries the hose at $5 per meter. I also found complete assemblies on E-bay. The MB Part number for the assembly is 6480700632.
smyers is offline
2006 e320 cdi - glow plug reamer? bobman W211 E-Class 13 11-06-2017 09:49 AM
2006 E320 CDI vs Newer Automotive Technology playadude W211 E-Class 19 04-01-2015 05:31 PM
Fan keeps running bossjj98 W163 M-Class 311 08-14-2014 05:42 PM
2006 E320 CDI Barrf General Mercedes-Benz 1 02-25-2009 04:59 PM
2006 E320 CDI on the way brakes W211 E-Class 34 01-24-2009 08:19 PM
