2008 E350 Control Arms and Ball Joints - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 03-26-2019, 05:02 PM Thread Starter
Date registered: Feb 2007
Vehicle: 2008 E350 Sport
I believe it is time to change the bushings and ball joints in my control arms and lower control arms. After over analyzing the numbers and the infinite pursuit of getting a better deal, I am considering replacing all of the bushings and reusing the existing control arms as opposed to buying new control arms. I figure if I have to remove ball joints and press them in, I may as well do the same for the bushings instead of buying new control arms. Total savings is about $250.
I am not sure if I am over simplifying the process or not, so I am looking to the forum for recommendations. I realize it will take some time, but I do not have anything else pressing right now. Thoughts???
SS
2008 E350 Sport
1999 E320 - Sold
eksantos is offline
post #2 of 10 (permalink) Old 03-26-2019, 05:23 PM
Supporting Vendor
AutohausAZ's Avatar
Date registered: Dec 2004
Vehicle: Too Many to List
Quoted: 31 Post(s)
Here are our suspension parts for your car: https://www.autohausaz.com/catalog/c...pension_system
To save some cash, visit our Vendor section for the details regarding Benzworld member special pricing.
Visit the AutohausAZ Vendor Section for special pricing for Benzworld members:
AutohausAZ is offline
post #3 of 10 (permalink) Old 04-02-2019, 04:56 PM
ezzo's Avatar
Date registered: May 2017
Vehicle: 2008 E300 4Matic
Quoted: 27 Post(s)
eksantos, since your car is not 4Matic you simply change the bushing and ball joints without having to change the control/thrust arms themselves. A few hours each side. Should not be a big deal.
this is the DIY video you need to watch
Good luck!
ezzo is offline
post #4 of 10 (permalink) Old 04-03-2019, 08:54 AM Thread Starter
Thanks. I decided to go with new arms as well. Thanks for the input. Hopefully, I will get it done this weekend.
SS
2008 E350 Sport
1999 E320 - Sold
eksantos is offline
post #5 of 10 (permalink) Old 05-20-2019, 02:49 PM Thread Starter
When to Torque the Strut and Stabilizer Bar Nuts to Lower Control Arm
When installing a new spring arm or front lower control arm, do you torque the strut and stabilizer bar nuts with the wheels on the ground or can you do it while still jacked up? I know that the sub-frame bolt is done with tires on the ground. I just cannot find a definitive answer regarding the other two nuts. Thanks for any input.
SS
2008 E350 Sport
1999 E320 - Sold
eksantos is offline
post #6 of 10 (permalink) Old 05-20-2019, 05:36 PM
ezzo's Avatar
Quoted: 27 Post(s)
eskantos, always torque the nuts and bolts of all suspension components when the car is in a "ready to drive" position. This means on the ground (leveled on all four wheels).
Witek_M likes this.
ezzo is offline
post #7 of 10 (permalink) Old 05-20-2019, 06:37 PM Thread Starter
Thanks for the information. That will be a little more of a challenge. I have watched too many Youtube videos. Some do, some don't. I just want to make sure that it is done correctly, so again, thanks.
SS
2008 E350 Sport
1999 E320 - Sold
eksantos is offline
post #8 of 10 (permalink) Old 05-20-2019, 06:55 PM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 829 Post(s)
Here is simple rule. If it has metal center then piece of rubber and metal outer sleeve pressed into something it needs to be tightened with wheels in ready to drive position. Preferably after rolling fore/aft few feet to relieve camber tension.
That applies to anything from Audi to Yugo.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #9 of 10 (permalink) Old 05-28-2019, 08:25 AM
Date registered: Oct 2017
Vehicle: 2006 cdi, 1993 500e
Quoted: 42 Post(s)
I did mine- wasn't hard. I don't understand on the spring arms? The lower control arms, the inner bushing is the one that fails. Lemforder or OE are the way to go. The nut- it's fine to torque it in the unloaded state because it's to a ball joint. LWR ball joint- easy. Those nuts are all 1-time use I believe and they are torque + angle. I'd buy OE nuts as the ones with the joint can sometimes be completely different. The thrust arm- i would replace it.
Upper ball joints last a bit better, but they are so cheap and easy to replace... I'd do it.
Legodude is offline
post #10 of 10 (permalink) Old 05-29-2019, 09:10 AM
ot1
Date registered: Apr 2007
Vehicle: 2006 E320 CDI
Quoted: 141 Post(s)
Getting under the car to tighten the control arms is impossible when its on the ground. I slide my homemade wooden ramps under the wheels and lower the vehicle onto the ramps. Then tighten the bolts.
ot1 is offline
DIY: Replace ball joint boots, front upper control arm jal1224 W140 S-Class 11 03-10-2018 04:50 AM
How-to: Replacing Ball Joints w124 300e latief W124 E,CE,D,TD Class 16 09-02-2017 05:40 AM
Yes, upper control arm ball joints *do* matter cowboyt W220 S-Class 3 12-21-2016 07:57 AM
88 560sl upper control arms w/ ball joints CA-280SL R/C107 SL/SLC Class 'For Sale/Trade/Buy' Forum 4 01-05-2016 04:45 PM
Front ball joints, control arms. sauliusagintas W220 S-Class 14 11-30-2012 10:35 PM
