P20CC-08 error code, abs and esp dash warnings - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 03-29-2018, 08:04 PM Thread Starter
Date registered: Jan 2012
Vehicle: 99 w210 4matic wagon
2004 e320 4matic wagon, sbc replaced ~3 years ago by local dealer (ripoff artist we no longer frequent, we go 70 miles up the road now) with a story similar to other frustrated w211 sbc sagas told here.
Trying to figure out what's going on.
Took it to O'Reilly's, they used Bosch obd 1300 and after some fiddling the counter clerk got it to display
P20CC-08 'Rough road detection' signal (by comparing wheel speeds) :Speed signal from control module ESP implausible /Read out fault memory of control unit ES
I get white ABS and ESP errors on the dash at engine start. Steering is a little heavy, brakes are a little heavy but nowhere near as bad as when the SBC went completely belly up a couple of years ago.
Any help would be appreciated. Is this a diy moment or a get thee to a trusted dealer moment?
In the past I've done basically all maintenance myself. But these newer cars seem to be designed deliberately to require the dealer ripoff artists to stay running past end of warranty. Which is why I bought a W210 after our experience with this lemon.
cptomes is offline
post #2 of 11 (permalink) Old 03-29-2018, 10:08 PM
Date registered: Apr 2008
Vehicle: W219 320CDI -07 W220 320CDI -01 W210 270CDI -01 EX: W211 320CDI -04
Quoted: 109 Post(s)
my wild guess is reluctor ring of rear speed sensor, it is VERY prone to fail...
if you would have decent indy nearby and/or bought your own SDS W211 is much better car than W210... sadly it also shows how greedy Dealers are, how overpriced their 'branded service' is...
-Do not try this at home -
mersum1es is offline
post #3 of 11 (permalink) Old 03-30-2018, 08:13 AM Thread Starter
Where is that reluctor ring? Inside the differential housing? How hard is it to replace?
cptomes is offline
post #4 of 11 (permalink) Old 03-30-2018, 03:18 PM
Date registered: Feb 2014
Vehicle: 2008 E350 4Matic, 2011 E350 4matic
Quoted: 161 Post(s)
You should get your own code reader that does MB specific codes. I think a lot of people like the icarsoft. It's around $150.
CetiAlpha5 is offline
post #5 of 11 (permalink) Old 04-01-2018, 03:13 PM
Purple Moderator
Date registered: Jul 2005
Quoted: 1510 Post(s)
The Autel MD 802 full car system model will do a better job for this and in the long run. I have ditched the icarsoft II unit due to wrong codes and no live time drive data which the Autel has for all functions.
Noodles is offline
post #6 of 11 (permalink) Old 04-04-2018, 11:38 PM
Quoted: 161 Post(s)
What live data have you found useful? I still have my X431, updated the software and now it offers live data but haven't played around with seeing which one is useful. The price of that system has gone way up. Got mine for $30 a few years ago and now I see it's in the $200 range on aliexpress. It used to be flaky though, I see they have a DIY version (diaglink) on Amazon for $99 so I guess that's a better price than the icarsoft anyway.
post #7 of 11 (permalink) Old 04-05-2018, 04:19 AM
Purple Moderator
The live data has been used to check O2 sensor voltages, lean/rich fuel trims, ABS data and other items.
It stores it for review later on the device or on a PC.
Noodles is offline
post #8 of 11 (permalink) Old 12-01-2018, 11:22 AM
Date registered: Mar 2011
Vehicle: 2007 E350 SP1 (M211.056/E272.964)
Quoted: 21 Post(s)
Just received Autel MD802, but can't connect/plug OBD II cable to the car. Do i need an adapter for W211?
I have no problem connecting/plug other scanner(autolink 319) to it.
The only difference between the two cable is that autolink 319 cable don't have pin 1,3,8,9,11,12,13, compare to MD802 all 16 pin.
btv94 is offline
post #9 of 11 (permalink) Old 12-02-2018, 08:20 AM
Purple Moderator
That is very odd.
That is the correct plug. We just had a post in the W163 section and a new Autel owner had the same problem.
It looks like on the long end (left side of the connector in your picture) the edge is bowed in a little bit. That was
the same thing we noticed in the W163 section. Have you tried to contact Autel?
The last page of this thread shows a similar issue.
https://www.benzworld.org/forums/w16...l#post17619658
Noodles is offline
post #10 of 11 (permalink) Old 12-03-2018, 06:39 AM
Date registered: Jan 2007
Vehicle: 2009 E350, 2007 E550, 2000 E320, 1997 E420 (Sold),2001 E320 (Sold)
Quoted: 20 Post(s)
I just bought an Autel MD805 last week and it fits perfectly into my 07 E550, 09 E350 and my 97 E420.
zitobenz is offline
