2009 E-350 with Sport package -Tail light - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 03-25-2018, 09:26 PM Thread Starter
Date registered: Nov 2005
Vehicle: 1997 E-420, 2001 E-320, 2007 S-550, 2009 E-350
Quoted: 26 Post(s)
Send a message via Yahoo to hadam
I have 2009 E-350 with Sport package. My passenger side (Right Side) tail light has been damaged in parking spot.
I like to purchase the replacement tail light. I look around for 2009 E-350 for tail light and I am not finding simple tail light, there are many options.
I know my tail light has halogen bulbs and also LED on top part of light for brake light.
Do I need to replace the whole tail light? Or, I can just get tail light without bulb assembly? Is LED light is part of tail light or it is part of tail light bulb assembly?
Please can someone help me to clarify what I need to purchase to replace the damage tail light. Where I can purchase this tail light from?
Please note all the bulb in tail light still working, there is NO defective lamp messages on instrument cluster.
ID:	2404009   Click image for larger version
2001 MB E-430 - 150K Miles Gone- Totaled
2009 MB E-350 - 107K Miles
2001 MB E-320 - 164K Miles
2003 MB CLK-320 Cabriolet - 126K Miles
1997 MB E-420 - 157K Miles
2007 MB S-550 - 140K Miles
2011 MB G-550 - 90K Miles
hadam is offline
post #2 of 4 (permalink) Old 03-26-2018, 11:39 AM
konigstiger's Avatar
Date registered: Jan 2007
Vehicle: '71 Pinto
Quoted: 367 Post(s)
I would suggest shopping part 2118202664 used, new $179.35 https://www.parts.com
konigstiger is offline
post #3 of 4 (permalink) Old 03-26-2018, 03:47 PM
mallig's Avatar
Date registered: Jul 2008
Vehicle: 2007 E350 4Matic Sport Packge; P2; Pano Roof
2009 E350 taillight
The tail lights are separate items (left or right) and the center hood mounted led brake lights are also separate items.
Here is a web address where I found a replacement for my damaged unit after a similar parking lot altercation.
2007-2009 Mercedes E350 (Sedan) Tail Light 2008 Right Passenger Side - AutoLightsBulbs.com
Fit was perfect - the only thing I did was to save the foam isolator piece from the old lamp assembly for the new one. I own a 2007 E350 Sport with P1 packaged sedan.
mallig is offline
post #4 of 4 (permalink) Old 03-29-2018, 03:23 PM Thread Starter
Quoted: 26 Post(s)
konigstiger and mallig, Thank you so much for your feedback. I will go ahead and order the tail light.
Only concern I had was that break part of the light is LED, so it seems that new tail light will come with LED already mounted in it on upper part of the light, I just need to connect to existing Bulb PCB board to LED of new light.
I am planning to use the same bulb board that is in existing damaged light. For now I have jut put Red Duct tap on it so no moisture or water get into the tail light.
hadam is offline
