2006 cdi- how do you get 40 mpg on the highway? - Page 2 - Mercedes-Benz Forum
post #11 of 49 (permalink) Old 01-30-2018, 11:05 AM Thread Starter
Date registered: Oct 2017
Vehicle: 2006 cdi, 1993 500e
Quoted: 45 Post(s)
Thanks for the responses and mileage posting.
I'm going to assume everything is functioning properly and go ahead with doing services/maintence.
One it's caught up to my liking- I'll mess with a tuning it to perhaps improve power and economy.
Legodude is offline
post #12 of 49 (permalink) Old 01-30-2018, 12:02 PM
Date registered: Feb 2017
Vehicle: 2007 E320
Quoted: 2 Post(s)
A few weeks ago I set my cruise to 60mph and went 20 miles down I-5 and got 43.5 mpg (said the computer) in my 07 E320 bluetec. However, I usually get 32-35 mpg mixed driving (tank calculation) and going a more reasonable speed like 75mph. Yes its a OM642 and its fairly modified (no dpf, no egr, no swirl flaps). It has been fully serviced recently which probably helps at 103k on the clock. My friend has a fully stock 08 E320 bluetec with 120k miles and he gets mid to high 20s mpg no matter how hard he tries. I am curious shertex, how much Optilube do you add per tankful? I assume that's to keep the injection pump lubricated?
2007w211 is offline
post #13 of 49 (permalink) Old 01-31-2018, 04:11 AM
Date registered: Oct 2015
Vehicle: 2006 E320 CDI
Quoted: 66 Post(s)
1 oz. of summer blend per 10 gallons. Mainly to lube injectors. Pump may be lubed by oil...not sure.
06 E320 CDI "Benson", Platinum Blue, 175k mi
06 E320 CDI "Rutherford", Black, 145k mi
91 300D "Otis", Smoke Silver, 129k mi
98 E300 "Murray", Silver, 129k mi, Stage 2 Rocketchip chip tuned, under son's care
Eleven other MB's owned and sold
2002 Honda Odyssey 255k mi (want to name it "Homer," wife won't let me)
1961 Very Tolerant Wife
shertex is offline
post #14 of 49 (permalink) Old 01-31-2018, 08:50 AM
Rossafuss's Avatar
Date registered: Oct 2013
Vehicle: 2005 E320 CDI *black on black with nearly every option*
Quoted: 195 Post(s)
i've adjusted the MPG computer -12% using star so my calculated fill up MPG is DEAD ON to +.5mpg to the mpg computer. During the winter (below 32f) I get about 29-33 on the highway driving 75-80mph.
The weather just started to warm up recently, and at 45f-50f i got 37.5mpg on a 100 mile highway run. I don't doubt that when its 75f-80f I can get 38-40mpg. Thats ACTUAL mileage too, calculated the traditional way miles\gallons added.
city/highway combined driving i get 23-27mpg
I just changed all the nozzles on my injectors 2k miles ago though, so they're brand new. I should be seeing slightly better fuel economy.
_______________________________________
"Concentrated power is not rendered harmless by the good intentions of those who create it."
2005 CLK320 - Wifes DD
2005 E320 CDI - Black on Black 450K+miles - MY current DD
2006 E320 CDI - Dads DD
2007 E320 Bluetec - Sisters DD
2008 ML320 CDI - Mothers DD
Gone:
83 300SD
86 190D 2.5
91 300D
95 C280
97 C280
99 E300D
Rossafuss is offline
post #15 of 49 (permalink) Old 01-31-2018, 01:48 PM
LeFantom's Avatar
Date registered: Jul 2012
Vehicle: '05 E320 CDI Black/Black
Quoted: 11 Post(s)
Salutation , long time no talk.))
Just wanted to clarify small detail...relevant to topic of discussion.
You still using your EGR delete mod or ... ?
Cheers.
-M.
Nothing is written in stone unless it's your Tombstone
- LeFantom
LeFantom is offline
post #16 of 49 (permalink) Old 02-01-2018, 09:18 AM
Kajtek1's Avatar
Quoted: 1978 Post(s)
Originally Posted by hangit View Post
The onboard MPG calculation has been shown to be inaccurate. I believe the only way you will attain 40MPG at highway speeds is if your trip is downhill with a tailwind.
John
You need to find country with real hills.
The 99.9 mpg is end of the scale, as I was doing much better.
With 3 MB who had mpg display, I recorded computer errors from 1% on the best and 6% on the worse. Once you figure out the gauge error, it is pretty reliable.
Kajtek1 is offline
post #17 of 49 (permalink) Old 02-01-2018, 02:27 PM Thread Starter
Quoted: 45 Post(s)
How do I adjust the onboard computer calculations using SDS?
Legodude is offline
post #18 of 49 (permalink) Old 02-02-2018, 03:54 AM
Quoted: 66 Post(s)
Follow this path (may vary slightly depending on your set-up):
Control Units
Information and Communication
Instrument Cluster
Control Unit Adaptations
Settings
Trip Computer Settings
Correction Factor of Fuel Consumption
shertex is offline
post #19 of 49 (permalink) Old 02-02-2018, 07:38 AM
Nimrodthewombat's Avatar
Date registered: Dec 2002
Vehicle: 2008 E 320 Bluetec (ELEGANCE) 2005 CLK500 (avant-garde)
Quoted: 58 Post(s)
I have gotten 40.5 mpg on my 2008 E320 Bluetec at times but I have to set the cruise control on 55 and drive a relatively flat route. In city driving I get around 28-32 and on the highway at 75 mph it runs around 34-36 mpg.
2005 CLK500 Cabriolet (Avant-garde)
Nimrodthewombat is offline
post #20 of 49 (permalink) Old 02-02-2018, 07:42 AM
Kajtek1's Avatar
Heck, I was getting 30+ mpg in gasoline wagon 4M.
All it took was staying in semitrailer tail wind at 60 mph.
Kajtek1 is offline
