Pumping Action when breaking... - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 08-15-2017, 04:44 AM Thread Starter
Rocketeer1926's Avatar
Date registered: Nov 2011
Vehicle: 1998 SL 500 - Sport & Pano : 2014 E350 4Matic - Luxury : 2015 GLK 350 4Matic
Quoted: 37 Post(s)
Yesterday, i started to feel a slight pumping action when breaking coming from the front of the car (i.e. feeling it on brake pedal and steering wheel).
The brakes were done about 1800 miles ago and everything has been fine. Car is a 2008 E350 with 4matic, Sport option and has 117K on it.
I am wondering if it's ABS or the wheels, tires ? There are no codes ...any thought's/direction appreciated.
Thanks, David
Rocketeer1926 is offline
post #2 of 8 (permalink) Old 08-15-2017, 05:54 AM
Benzyle's Avatar
Date registered: Nov 2013
Vehicle: MY05 CLK55 AMG , MY05 CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
Quoted: 298 Post(s)
If you mean the brake pedal pulsates during braking,,that could be several things,
1. Wheel bearings worn or out of adjustment.
2.Caliper not sliding properly due to bad installation.
3.Brake rotor warped.
If you had a garage do the brakes I would take it back and get them to check their work.
Benzyle is offline
post #3 of 8 (permalink) Old 08-15-2017, 07:56 AM Thread Starter
Quoted: 37 Post(s)
thanks for the comment, I will bring it back...and have them check it.
Thanks, David
post #4 of 8 (permalink) Old 08-20-2017, 03:19 AM Thread Starter
Quoted: 37 Post(s)
spot on BENZYLE - it was warped rotors. Shop replaced under warranty...
Thanks, David
post #5 of 8 (permalink) Old 08-20-2017, 05:56 AM
Benzyle's Avatar
Quoted: 298 Post(s)
Thanks, David
Good to hear it is fixed at no cost.
Make sure the wheel bolts are all at the correct torque,,usually 110Nm. Incorrect torque can cause this problem. Many shops over-tighten wheel bolts.
Also avoid riding the brakes which can cause a build up of excessive heat.
Benzyle is offline
post #6 of 8 (permalink) Old 04-25-2018, 07:57 PM
Date registered: Apr 2018
Vehicle: 2011 E350
AFTER OWNING AN AUDI FOR SEVERAL YEARS, I BOUGHT A 2011 E350 AND AM A LITTLE CONCERNED WITH THE JERKY BRAKING UNLIKE THE SMOOTH DECELERATION WITH THE AUDI. MY STAR SERVICE MECHANIC TOLD ME THE BRAKES AND ROTORS WERE IN GREAT SHAPE. IS THIS JUST AN ATTRIBUTE OF MERCEDES BRAKES?
#11BenzAZE350 is offline
post #7 of 8 (permalink) Old 04-25-2018, 10:29 PM
Benzyle's Avatar
Quoted: 298 Post(s)
No.
Braking is usually smooth.
Time to find another mechanic.
Benzyle is offline
post #8 of 8 (permalink) Old 04-27-2018, 06:28 PM
ot1
Date registered: Apr 2007
Vehicle: 2006 E320 CDI
Quoted: 143 Post(s)
You had a brake job prior but were the rotors replaced then? You might still have a stuck caliper problem. Buy a infrared thermometer from harbor freight and check temps after driving 30 minutes and compare both sides, if there a large differential they didnt fix the problem. Shoot it through the spokes onto the rotor.
ot1 is offline
