W211 E270 CDI - overheating?? - Page 3 - Mercedes-Benz Forum
post #21 of 32 (permalink) Old 09-08-2017, 09:20 AM Thread Starter
Date registered: Dec 2015
Vehicle: 2004 E270 CDI
Quoted: 8 Post(s)
Thanks mtrevelino.
The mileage on car is 170k, if i changed both the radiator and water pump, how am i going to know which part was causing engine to overheat?
Azeemmuh is offline
post #22 of 32 (permalink) Old 09-08-2017, 05:34 PM
Date registered: Jul 2010
Vehicle: 2006 e320 CDI
Quoted: 65 Post(s)
Originally Posted by Azeemmuh View Post
Thanks mtrevelino.
I was just throwing it out there. To change the water pump is an approximately four hour job. If you change it while the radiator is out, it would probably take under two hours. With 170k, the water pump does not have much life left.
Mike T.
mtrevelino is offline
post #23 of 32 (permalink) Old 09-08-2017, 07:16 PM Thread Starter
Quoted: 8 Post(s)
Noted.
Azeemmuh is offline
post #24 of 32 (permalink) Old 09-11-2017, 07:30 AM
Kajtek1's Avatar
Quoted: 1976 Post(s)
MB water pumps can last million miles, although latest models report more failures than older. The pump on my father's 1987 300DT is still original at 300k miles.
You can inspect the pump for bearings play after belt removal.
Kajtek1 is offline
post #25 of 32 (permalink) Old 09-11-2017, 05:19 PM
Quoted: 65 Post(s)
Originally Posted by Kajtek1 View Post
MB water pumps can last million miles.....
I recently had my cdi at the dealer for an inspection and one motor mount. When I take it to the dealer they do a thorough inspection. It has been a couple of years since I had it at the dealer so I wanted them to do the inspection and see what they find. Now to what the Service Writer said. He said he rarely sees water pumps go bad, but he mentioned in my case the water pump is seeping. It is seeping from the gasket (not the weep hole). He told me to just keep a eye on it. He did quote a price of approximately $900 for the job. And that is strictly the water pump, no pulley's or anything else. When I decide to have this done, I will purchase the pump and pulley' sand have my indie do it. My cdi has 150k on it.
Mike T.
post #26 of 32 (permalink) Old 09-11-2017, 05:25 PM
Kajtek1's Avatar
I'have been via few of those "Free safety inspections"
$4000 estimate for jobs under the car and checking it at home - the belly pans were never removed.
From quoted 2 flex disks - 1 was new and 2nd in decent condition. Evidently SA seeing car with over 200k miles and no service records assumed everything is original.
I can do such inspection in about 25 seconds from comfort of my chair.
Kajtek1 is offline
post #27 of 32 (permalink) Old 09-18-2017, 10:34 AM Thread Starter
Quoted: 8 Post(s)
Update : Changed the radiator this evening. With the new radiator fitted and after burping the cooling system, engine temperature is still 107-108 deg C? The old radiator looked fine to me.
Any ideas?
Azeemmuh is offline
post #28 of 32 (permalink) Old 09-18-2017, 01:42 PM
Benzyle's Avatar
Date registered: Nov 2013
Vehicle: MY05 CLK55 AMG , MY05 CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
Quoted: 297 Post(s)
As per my post number 19, Change the thermostat.
Benzyle is offline
post #29 of 32 (permalink) Old 09-18-2017, 08:35 PM Thread Starter
Quoted: 8 Post(s)
Thanks Benzyle, I should've listened to you earlier. Since I live in a warmer climate, should I go for 85C thermostat or lower?
Azeemmuh is offline
post #30 of 32 (permalink) Old 09-18-2017, 08:50 PM
Benzyle's Avatar
Quoted: 297 Post(s)
I don't think you have a choice of different temps.
Just get the correct one for your model,which I think will have an opening temp of 87 degrees c.
Benzyle is offline
