speed limit exceeded on w211 - Page 2 - Mercedes-Benz Forum
post #11 of 15 (permalink) Old 08-13-2017, 02:24 AM
t_e
Date registered: Aug 2017
Vehicle: 2007 E280
120 Speed Limit Exceded
Hi,
I live in UAE too, i experinced the same and tried everything, tell i found the solution, most probably you will not be able to do it by yourself because even if you have the system on you laptop you also need that device for checking (diagnostic connector)
Anyhow you have to go to a mechanic, he will remove this 120 from the car system kindly watch the video linked below:
If you ask me there's a service center in Shj called Kojack, they did not understand in the begining but i explaind it to them along with the video and fortunately they did it
Regards,
t_e is offline
post #12 of 15 (permalink) Old 08-14-2017, 02:46 AM
Benzyle's Avatar
Date registered: Nov 2013
Vehicle: MY05 CLK55 AMG , MY05 CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
Quoted: 299 Post(s)
Like Katjek1,said,check your owners manual.
Controls in detail,Driving systems, Permanent Speedtronic.
Use the steering wheel controls to set or switch off.
Go to settings,arrow down to vehicle sub menu, select speed limit and reset to desired speed,or switch it off completely.
Benzyle is offline
post #13 of 15 (permalink) Old 08-14-2017, 03:01 AM
t_e
Vehicle: 2007 E280
It has nothing to do with the speed limit in car setting, it's something built in the DAS/Star system
t_e is offline
post #14 of 15 (permalink) Old 08-14-2017, 03:17 AM
Benzyle's Avatar
Quoted: 299 Post(s)
It was not clear that that was the case.
Is every car sold in UAE limited in speed to 120kph due to government control ?
Benzyle is offline
post #15 of 15 (permalink) Old 08-14-2017, 03:21 AM
t_e
Vehicle: 2007 E280
I'm not sure, some cars have this security and some not, i think it depends on the dealer
t_e is offline
