722.6 lock-up clutch slipping (never closed) - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 06-27-2017, 12:30 AM Thread Starter
ezzo's Avatar
Date registered: May 2017
Vehicle: 2008 E300 4Matic
Quoted: 25 Post(s)
I hooked up a computer to my 722.6 transmission and found that the torque converter never locks. Can anyone advise on this, please?
Basically, when the gear is in park or in neutral, the computer shows: Lock-up clutch is open (image attached), but while driving, it is always "slipping". I drove the car on the highway at 70-75 miles/h (110-120 Km/h) and never got the torque converter to lock.
I am inclined to flush the transmission fluid especially at 136K miles (218K Km) with no reference of this service in my records from the previous original owner.
Any help is appreciated.
ezzo is offline
post #2 of 11 (permalink) Old 06-27-2017, 05:47 AM
Date registered: Feb 2010
Vehicle: 2007 E320 Bluetec, 2008 320ML CDI
Quoted: 266 Post(s)
Poster MAVA has great depth on these transmissions.
While you wait for his advice take a read at this thread and download the information. Plenty to pour over.
https://www.benzworld.org/forums/w140...ce-manual.html
Skippy
Skippy,
SkippyJasper is offline
post #3 of 11 (permalink) Old 06-27-2017, 09:31 AM
Kajtek1's Avatar
Quoted: 1935 Post(s)
Suppose those cruisers lock the converter above 80 mph, but on my diesels I could not see that happening even at those speeds.
Nothing you can do about it.
Kajtek1 is offline
post #4 of 11 (permalink) Old 06-30-2017, 06:05 AM Thread Starter
ezzo's Avatar
Quoted: 25 Post(s)
Skippy
Thanks for pointing this out. Although it has a lot more than I have wanted, it is really useful. I will have to spend a long time until I find an answer to lock-up clutch question!
Ezzo
ezzo is offline
post #5 of 11 (permalink) Old 04-25-2019, 12:31 AM Thread Starter
ezzo's Avatar
Quoted: 25 Post(s)
Just to have a closure to this thread, I went to an expert transmission shop. They hooked up the computer (the same one I used myself), which was not a star but an aftermarket Chinese knockoff. We went on a lengthy test drive. The guy said the tansmission was in great shape and that the torque converter locking was working fine. Their computer did show "slipping" all the time, but the guy said I should ignore that because the computer was not specific for MB. The guy said he could feel the locking after each shift if the car is not accelarating.
ezzo is offline
post #6 of 11 (permalink) Old 04-25-2019, 07:02 AM
Date registered: Sep 2007
Vehicle: 2006 E320 CDI
Quoted: 24 Post(s)
Originally Posted by ezzo View Post
Just to have a closure to this thread...The guy said the transmission was in great shape and that the torque converter locking was working fine. Their computer did show "slipping" all the time, but the guy said I should ignore that because the computer was not specific for MB. The guy said he could feel the locking after each shift if the car is not accelarating.
Interesting. Mine behaves in the same manner when I look at my diagnostic computer. Mine feels OK though, FWIW. I've got other valve body issues due to dirt over time, but that is another story.
smyers is online now
post #7 of 11 (permalink) Old 04-25-2019, 07:19 AM
Date registered: Apr 2008
Vehicle: W219 320CDI -07 W220 320CDI -01 W210 270CDI -01 EX: W211 320CDI -04
Quoted: 105 Post(s)
it is usual...
-Do not try this at home -
mersum1es is offline
post #8 of 11 (permalink) Old 04-25-2019, 07:47 AM
tjts1's Avatar
Date registered: Apr 2009
Vehicle: 87 300D 5 speed
Quoted: 668 Post(s)
With a proper scan tool you should be able to shut off the lockup torque converter and compare the bahavior. The most likely failure point is the lockup torque converter solenoid. The 722.6 locks the torque converter in every gear including first. This is very unusual for an automatic. The result is that that lock out solenoid (TCC) gets worn out much faster than every other solenoid in the transmission. If you're doing the conductor plate I suggest also replacing the TCC solenoid. It's a $28 part on fleabay.
ezzo likes this.
Triggering religious fanatics since 1969
tjts1 is offline
post #9 of 11 (permalink) Old 04-26-2019, 05:39 AM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 775 Post(s)
There are many factors influencing TC lock. Engine load being primary. Is is easier to observe transition from open to slipping to closed in 3rd or 4th gear.
mersum1es and ezzo like this.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #10 of 11 (permalink) Old 04-30-2019, 05:35 AM
Rossafuss's Avatar
Date registered: Oct 2013
Vehicle: 2005 E320 CDI *black on black with nearly every option*
Quoted: 182 Post(s)
i did this same test with DAS before i replaced my torque converter and rebuilding my valve body, and noticed no change in the numbers running the test AFTER changing the torque converter.
My torque converter itself however, had severely worn lockup clutch material and an intermittent stator clutch causing all kinds of weird behavior. a new torque converter restored normal driving behavior and smoother driving.
_______________________________________
"Concentrated power is not rendered harmless by the good intentions of those who create it."
2005 CLK320 - Wifes DD
2005 E320 CDI - Black on Black 450K+miles - MY current DD
2006 E320 CDI - Dads DD
2007 E320 Bluetec - Sisters DD
2008 ML320 CDI - Mothers DD
Gone:
83 300SD
86 190D 2.5
91 300D
95 C280
97 C280
99 E300D
Rossafuss is offline
