2004 E320 - Red Battery "Visit Workshop" - Is it the Relay or Main battery - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 08-24-2015, 06:00 AM Thread Starter
ccrobin's Avatar
Date registered: Sep 2011
Vehicle: 2004 E320 wagon 4-Matic
Hoping someone here can provide guidance...
I have been having the Red Battery "Visit Workshop" error for a while now. The message comes on immediately after starting the car. When it first started happening, it would clear itself after driving for an hour or so. Now it comes on every time I start the car and does not clear itself.
I assumed it was the aux battery and replaced that a month ago, but it made no difference.
The last few days I have accessed the service menu before starting the car, and find the battery voltage to be anywhere from 12.0 volts to 13.2 volts before starting the car. As soon as it starts, voltage jumps to around 14.1 volts.
I am suspecting either the main battery or the aux battery relay. The battery is not new, but seems to be holding a charge fine, so I hate to drop $150 on a new one if it is the relay. The relay I would have to order and is not returnable, so I also hate to spend $60 on that if it is not needed.
I am wondering if there is a way I can test the relay to determine which is the culprit, or if these symptoms help to diagnose? Or is there something else I should consider as the problem?
In case this is relevant, last winter it was not uncommon when starting the car below zero degrees to have the "Battery Protection - Convenience Functions Unavailable" message pop up for about a minute, but it always went away. The car always starts fine and does not seem to have a weak battery.
Any insight is appreciated!
CURRENT: 2004 E320 WAGON 4-MATIC. Astral Silver.
RIP: 1987 300SDL "Eve" - 275K Miles. Automatic. Astral Silver w/Blue Interior & Power Rear Seats
ccrobin is offline
post #2 of 11 (permalink) Old 08-24-2015, 10:46 AM
Purple Moderator
Date registered: Jul 2005
Quoted: 1494 Post(s)
The main battery should be load tested. If it is weak it needs to be replaced with a quality AGM style battery of the exact same size and capacity.
Noodles is offline
post #3 of 11 (permalink) Old 11-08-2015, 07:44 AM Thread Starter
ccrobin's Avatar
I did load test the battery, and it appears to be fine. I changed the Aux Battery relay, but that did not help either.
I was able to scan my car with Carly OBD2 scanner, and received the following list of Faults/Events. Perhaps this would give some insight on what to check next?
Note: I have not yet cleared ant of these codes a I didn't want to lose the data unless/until I had time to review them.
Due to length, I will have to break up the report into 2 posts. Here is part 1:
Fault Report - MerceWhat - Version: 5.04 LV
ID1: 114e5123-66e7-499d-8fb0-9e832d02a4b2-85fID2: c2466b3b-7fcf-4481-91ce-87d7d4157500-d34-45cc
INFO: 0B0BC3B2A192847B684F402C28924
Base: Series 211 - E Notchback/Van/ Baureihe 211 - E Stufenheck/Kombi
Build-Year: 2004
Faults: 127
ECUs: 34
Model: all/alle (MotorID=NA, Parameter=0)
Battery: 13.2V
Enhanced communication
Normal connection
Optimized: 100
None
Date: 2015-11-05 17:22:37
OBD2ECU
Version: 22
Device: >samsung< >trltetmofrp< >SM-N910T3<
Motor Control:
ME - Motor/Engine Electronics (MB: NO_HWID_FOUND)
ECU OK, no Fault or Event Code
ABS / DSC / Brake:
WSS - Weight sensing system (MB: 2118202185)
Airbag:
AB - Airbag (MB: 2118205785)
Event: The supply voltage of the control unit is too low (undervoltage). / Fault: N2/7 (Restraint systems control unit) control unit terminal 15R/15 undervoltage
Code: 9003
Fault: The codes (right-hand or left-hand drive) stored in control modules N2/7 (Restraint systems control unit) and N93 (Central gateway control unit) are not identical. The codes (right-hand or left-hand drive) stored in control modules N2/7 (Restraint systems control unit) and N73 (Electronic ignition switch (EIS [EZS])) are not identical. / Fault: Fault in CAN communication with control unit N10-1 (Multifunction control module).
Code: 907B
Fault: Fault in CAN communication with control unit N93 (Central gateway control unit). / Fault: N2/7 (Restraint systems control unit): coding is faulty.
Code: 906A
Fault: Fault in CAN communication with control unit N93 (Central gateway control unit). / Fault: Fault in communication with component B48 (Front passenger seat occupied and child seat recognition) or there is a cable fault.
Code: 906C
Fault: Fault in CAN communication with control unit N93 (Central gateway control unit). / Fault: The component or the signal line to the component B48 (Front passenger seat occupied and child seat recognition) has . The component or the signal line to the component B48 (Front passenger seat occupied and child seat recognition) has T.
Code: 906D
Fault: Fault in CAN communication with control unit N93 (Central gateway control unit). / Fault: The component or the signal line to the component B48 (Front passenger seat occupied and child seat recognition) has or . The component or the signal line to the component B48 (Front passenger seat occupied and child seat recognition) has Q or S.
Code: 906E
Fault: Fault in CAN communication with control unit N93 (Central gateway control unit). / Fault: Component B48 (Front passenger seat occupied and child seat recognition) is defective.
Code: 906F
Code: 9070
Fault: Fault in CAN communication with control unit N93 (Central gateway control unit). / Fault: There is an external fault in the child seat recognition.
Code: 9071
Fault: Fault in CAN communication with control unit N93 (Central gateway control unit). / Fault: The coding for component B48 (Front passenger seat occupied and child seat recognition) is faulty.
Code: 9072
Transmission Control:
ETC - Electronic transmission control (MB: 0325452432)
Event: One or more messages from the engine control unit are not available on the CAN bus. One or more messages from the engine control unit are not available on the CAN bus. ( CAN timeout fault ) CAN communication with the engine system is faulty. / Fault: Not Relevant!
Code: 2312
Code: 2311
Event: One or more messages from control unit N19 (Air conditioning control module) are not available on the CAN bus. One or more messages from control unit N19 (Air conditioning control module) are not available on the CAN bus. ( CAN timeout fault ) One or more messages from control unit A1 (Instrument cluster) are not available on the CAN bus. ( CAN timeout fault ) Fault in CAN communication with control unit A1 (Instrument cluster). / Fault: Not Relevant!
Code: 2316
ESM - Electronic selector module (MB: 2115451932)
Instrument cluster:
OCP - Overhead control panel (MB: 2118205401)
Fault: The obstruction sensor data are no longer current.
Code: 90E2
Code: 90FF
Fault: Panoramic sliding roof is not normalized. If fault code occurs with no complaint reported and no malfunctions, erase fault memory and perform a function check. SR is not normalized. If fault code occurs with no complaint reported and no malfunctions, erase fault memory and perform a function check. / Fault: Component M12b3 (Obstruction sensor) has Open circuit. Not Relevant!
Code: 9068
Sorry, there is no explanation available
Code: 90E8
Fault: Output 'Terminal 58d' is overloaded. / Fault: Fault in CAN communication with control unit EZS. / Event: Fault in CAN communication with control unit EZS. / Event: CAN reception timeout: EIS electronic ignition switch . ( Do not replace control module OCP. Continue troubleshooting in control unit EZS. )
Code: 90D0
Fault: The obstruction sensor unit has detected a hardware fault.
Code: 90E0
Fault: Either normalization of the obstruction sensor in the tilting/sliding roof has not yet been performed, or an error occurred during normalization. Either normalization of the obstruction sensor in the tilting/sliding roof has not yet been performed, or an error occurred during normalization. The reference values following the teach-in process are beyond the predefined limits.
Code: 90E1
IC - Instrument cluster (MB: 2115402947)
Event: Fault in CAN communication with control unit N72/1 (Upper control panel control unit). / Fault: Not Relevant! / Fault: @TODO: Error reading Thesaurus-Index: 082502 / Event: Fault in CAN communication with control module A35/8 (TELE AID control unit) or E-call. / Fault: Fault in CAN communication with control unit TELE AID or E-Call. Fault in CAN communication with control unit Telematics platform. / Event: Fault in CAN communication with control unit Telematic.
Code: 9116
Event: Fault in CAN communication with control unit Telecommunications. / Fault: Not Relevant! / Fault: @TODO: Error reading Thesaurus-Index: 082502 ( Only valid for USA vehicles ) / Event: Fault in CAN communication with control unit N52 (Soft top control module). / Event: Fault in CAN communication with control unit VR. / Event: Fault in CAN communication with control unit CGW.
Code: 9117
Event: Fault in CAN communication with control unit Central gateway. / Fault: Fault in CAN communication with control unit Keyless Go. / Event: @TODO: Error reading Thesaurus-Index: 082502 / Fault: Fault in CAN communication with control unit Upper control panel. / Fault: Not Relevant! / Event: Fault in CAN communication with control unit Dr-side SAM. Fault in CAN communication with control unit UCP.
Code: 9118
Event: The supply voltage of the control unit is too low (undervoltage). / Fault: The brake fluid level is not o.k.
Code: 9128
Fault: CAN signal 'Battery voltage' is implausible. Not Relevant! / Fault: CAN signal Battery voltage through CAN faulty / Fault: Control module EZS has detected undervoltage.
Code: 9133
Fault: 'Reset' pushbutton jamming. / Fault: Not Relevant!
Code: 913C
UCP - Upper control panel (MB: 2118212758)
Fault: The folding switch panel received no authorization to open or close from the AGW, CD changer, COMAND or audio systems. / Fault: The control unit N72/1 (Upper control panel control unit) no longer sends on the CAN bus. ( CAN bus OFF ) / Fault: Right heated seat not operating : Possible cause: Open circuit in wiring / Fault: Not Relevant! Control module N72/1 (Upper control panel control unit) has detected a short circuit at one of the outputs for the function lighting.
Code: 9033
Fault: Switch N72/1s11 (Right front HS switch) is defective or has been operated for longer than 25 seconds. Not Relevant! / Fault: Switch N72/1s13 (Left front seat ventilation switch) is defective or has been operated for longer than 25 seconds. / Fault: Switch N72/1s8 (PTS OFF switch) or N72/1s4 (Windshield heater button) is defective or has been operated for longer than 25 seconds. Switch N72/1s8 (PTS OFF switch) is defective or has been operated for longer than 25 seconds. Switch N72/s4 (Windshield heater button) is defective or has been operated for longer than 25 seconds. Switch N72/1s8 (PTS OFF switch) or N72/1s4 (Windshield heater button) is defective or has been operated for longer than 25 seconds. Switch N72/1s8 (PTS OFF switch) is defective or has been operated for longer than 25 seconds. Switch N72/1s50 (Windshield heater switch) is defective or has been operated for longer than 25 seconds. / Fault: Switch Left head area ventilation is defective or has been operated for longer than 25 seconds.
Code: 9003
RWT - Rear-end door control module (MB: 0355455432)
Fault: Component E4/1e3 (Right backup lamp) is faulty or the line to the component has a short circuit or open circuit.
Code: 9065
Fault: Component E37 (Rear-end door spotlight) or line to component has short circuit or open circuit. Not Relevant!
Code: 9029
Fault: Component E3/1e3 (Left backup lamp) is faulty or the line to the component has a short circuit or open circuit.
Code: 9064
Fault: Control unit N93 (Central gateway control unit) is not transmitting data on the CAN bus.
Code: 9041
Fault: Control unit N72/1 (Upper control panel control unit) is not transmitting data on the CAN bus.
Code: 9096
Fault: Component M6/4 (Tailgate wiper motor) is defective or the line to the component has a short circuit.
Code: 9010
Fault: Component E19/2 (Right license plate lamp) is faulty or the line to the component has a short circuit or open circuit.
Code: 9072
Fault: Control unit N69/2 (Right front door control unit) is not transmitting data on the CAN bus.
Code: 9094
Fault: Component E19/1 (Left license plate lamp) is faulty or the line to the component has a short circuit or open circuit.
Code: 9071
Light/Rain Control:
Heating / AC:
AAC - Automatic air conditioning (MB: 2118300985)
Fault: A component connected to the AC bus has a short circuit. ( Stepping motors , PTC heater booster ) / Fault: Normalizing of the positioning motors is not o.k. One or several positioning motors are faulty, or normalizing has not been carried out.
Code: 9100
Fault: Communication error of AC bus with component A32n1 (Blower regulator)
Code: 9360
Fault: Not Relevant! A32n1 (Blower regulator) If no customer complaint exists, the fault can be erased. / Fault: Electrical fault A32n1 (Blower regulator) If no customer complaint exists, the fault can be erased. / Fault: A32n1 (Blower regulator) A32n1 (Blower regulator) Important note: If no customer complaint exists, the fault can be erased.
Code: 9460
Event: CAN bus OFF / Fault: CAN bus OFF / Event: CAN bus failure
Code: 9600
Event: Fault in CAN communication with control unit Door control module front right. / Event: Not Relevant! Fault in CAN communication with control unit DCM-FR.
Code: 9651
Event: Fault in CAN communication with control unit Central gateway. / Event: Not Relevant! Fault in CAN communication with control unit RVC.
Code: 9680
Immobilizer System:
ASSYST Active Service System (MB: 2115403545)
Fault: Control unit ASSYST is not receiving any messages from the engine compartment CAN bus.
Code: 9204
ASSYST PLUS - PLUS Active Service System (MB: 2115403545)
Fault: Coding of control module ASSYST PLUS is faulty. Note: If the service menu is properly displayed in the instrument cluster, this fault can be ignored.
Code: 9102
Park distance control:
Audio/Navi/Communication:
TEL / NAVI (MB: 2118206285)
Code: D001
Code: D003
Code: D010
Code: D500
NAVI or SDAR - Satellite radio (MB: 2114470059)
Code: D800
COMMAND / Audio / Handy Interface (MB: 2118276342)
Code: D010
Code: D200
Code: D241
TEL / CD Changer (MB: 2118275542)
Fault: The control unit was switched off due to excessive temperature (MOST transmitter and receiver unit)..
Code: D004
Code: D010
Fault: Watchdog error : The control unit has been reset due to an internal error.
Code: D001
UCI - Media Interface (MB: 2114470359)
Code: D900
AGW - Audio gateway (MOST network management, diagnosis gateway, radio tuner) (MB: 2118271062)
Fault: Ring break - Segment before pos. 4 is damaged
Code: D104
Fault: The wake-up line has Short circuit to ground.
Code: D135
Fault: Ring break - Segment before pos. 0 is damaged
Code: D100
Fault: Ring break - Segment before pos. 3 is damaged
Code: D103
Fault: No or incorrect CAN message from control unit N72/1 (Upper control panel control unit) Not Relevant!
Code: D148
Fault: The supply voltage of the control unit is too low (undervoltage). Not Relevant!
Code: D010
ccrobin is offline
post #4 of 11 (permalink) Old 11-08-2015, 07:45 AM Thread Starter
ccrobin's Avatar
Here is part 2:
Systems:
BCM - Battery control module (MB: 2115406945)
Fault: The contact of component K57/2 (Auxiliary battery relay) does not open.
Code: 9090
Fault: Not Relevant! Consumer shutoff, stage 2
Code: 9050
Fault: Component K57/2 (Auxiliary battery relay) or the signal wire to the component is faulty.
Code: 9071
Fault: The contact of component K57/2 (Auxiliary battery relay) does not close or the fuse upstream of the contact is defective.
Code: 9091
Fault: Component G1/7 (Auxiliary battery) is defective or not installed.
Code: 9092
EZS - Electronic ignition switch (MB: NO_HWID_FOUND)
SCM [MRM] - Steering column module (MB: 0305459632)
Pass-side SAM - Passenger-side signal acquisition and actuation module (MB: 2115452132)
Fault: Component E1e2 (Left low beam) is faulty or the line to the component has an open circuit. Component E2e2 (Right low beam) is faulty or the line to the component has an open circuit.
Code: 9003
Fault: Component E5/1 (Left fog lamp or line to component has short circuit. Component E5/2 (Right fog lamp) or line to component has short circuit.
Code: 9004
Fault: Component E5/1 (Left fog lamp is faulty or the line to the component has an open circuit. Component E5/2 (Right fog lamp) is faulty or the line to the component has an open circuit.
Code: 9005
Fault: Component E1e3 (Left standing and parking lamp) is faulty or the line to the component has an open circuit. Note symptom 'LED 'Standing lights' is installed and the associated fault code is not stored in the fault memory despite an open circuit.'. Note symptom 'LED 'Standing lights' flashes.'. Component E2e3 (Right standing and parking lamp) is faulty or the line to the component has an open circuit. Note symptom 'LED 'Standing lights' is installed and the associated fault code is not stored in the fault memory despite an open circuit.'. Note symptom 'LED 'Standing lights' flashes.'.
Code: 9007
Fault: Component E1e5 (Left turn signal lamp) is faulty or the line to the component has an open circuit. Component E2e5 (Right turn signal lamp) is faulty or the line to the component has an open circuit.
Code: 9009
Fault: Control unit N73 (EIS [EZS] control unit) is not transmitting data on the CAN bus.
Code: 9091
Code: 9097
Fault: Control unit N10/2 (Rear SAM control unit with fuse and relay module) is not transmitting data on the CAN bus.
Code: 9098
Code: 9099
REAR SAM - Rear signal acquisition and actuation module (MB: 2115452101)
Fault: Control unit N73 (EIS [EZS] control unit) is not transmitting data on the CAN bus. / Fault: Fault in CAN communication with control unit N73 (EIS [EZS] control unit). If fault code occurs with no complaint reported and no malfunctions, erase fault memory and perform a function check. Not Relevant! / Fault: Control module N73 (EIS [EZS] control unit) is not sending any data.
Code: 9088
Fault: Communication with component B33 (ATA inclination sensor) is interrupted. / Fault: Fault in communication with component B33 (ATA inclination sensor) or there is a cable fault.
Code: 9059
Fault: Control unit N72/1 (Upper control panel control unit) is not transmitting data on the CAN bus. / Fault: Fault in CAN communication with control unit N72/1 (Upper control panel control unit). If fault code occurs with no complaint reported and no malfunctions, erase fault memory and perform a function check. / Fault: Control module N72/1 (Upper control panel control unit) is not sending any data. / Fault: Error: relay terminal 15R1, load side circuit to GND
Code: 9096
Fault: Control unit N93 (Central gateway control unit) is not transmitting data on the CAN bus. / Fault: Control module N93 (Central gateway control unit) is not sending any data.
Code: 9041
Fault: Fault in communication with component B33 (ATA inclination sensor). / Fault: The cable to component B33 (ATA inclination sensor) is faulty.
Code: 9060
Dr-side SAM - Driver signal acquisition and actuation module (MB: 2115453901)
Fault: Component E1e2 (Left low beam) is faulty or the lead has open circuit. Component E2e2 (Right low beam) is faulty or the lead has open circuit. / Fault: Component M13 (Heating water circulation pump) or the line to the component has a short circuit to ground or open circuit. Component M13 (Heating water circulation pump) is not installed. Ignore fault code if it nevertheless occurs. / Fault: Additional water pump short circuit or no load / Fault: Error: High beam right short to earth
Code: 9003
Fault: Component E5/1 (Left fog lamp is faulty or the lead has open circuit. Component E5/2 (Right fog lamp) is faulty or the lead has open circuit. / Fault: Component M5/2 (HCS pump) or the line to the component has a short circuit to ground or open circuit. / Fault: SRA driver short circuit or no load / Fault: Error: left low beam Short circuit to earth
Code: 9005
Fault: Component E1e3 (Left standing and parking lamp) is faulty or the lead has open circuit. Note symptom 'LED 'Standing lights' is installed and the associated fault code is not stored in the fault memory despite an open circuit.'. Note symptom 'LED 'Standing lights' flashes.'. Component E2e3 (Right standing and parking lamp) is faulty or the lead has open circuit. Note symptom 'LED 'Standing lights' is installed and the associated fault code is not stored in the fault memory despite an open circuit.'. Note symptom 'LED 'Standing lights' flashes.'. / Fault: Component E2e1 (Right high beam) is faulty or the line to the component has a short circuit or open circuit. / Fault: High beam right short circuit or no load / Fault: Error: Dipped beam, right short to earth
Code: 9007
Fault: Component E1e5 (Left turn signal lamp) is faulty or the lead has open circuit. Component E2e5 (Right turn signal lamp) is faulty or the lead has open circuit. / Fault: Component E2e2 (Right low beam) is faulty or the line to the component has a short circuit or open circuit. / Fault: Low beam right short circuit or no load / Fault: Error: fog light left short to earth
Code: 9009
Fault: Component E6/1 (Left front side marker lamp USA) or lead has Short circuit to ground or open circuit. / Fault: Component E1e2 (Left low beam) is faulty or the line to the component has a short circuit or open circuit. / Fault: Low beam left short circuit or no load / Fault: Error: Side marker defective right
Code: 9010
Fault: Component E6/2 (Right front side marker lamp USA) or lead has Short circuit to ground or open circuit. / Fault: Component E5/1 (Left fog lamp is faulty or the line to the component has a short circuit or open circuit. / Fault: Fog light left short circuit or no load / Fault: Error: faulty turn signal right
Code: 9012
Fault: Component M5/3 (Tailgate washer fluid pump) or lead has Short circuit to ground or open circuit. This fault code should be ignored on model variant 'Sedan'. / Fault: Not Relevant! / Fault: Short Kl. 58 Kl cockpit. 58d short / Fault: Error: reveille air suspension Short circuit to earth
Code: 9022
Fault: Component M6/1 (wiper motor) is blocked. / Fault: Circuit 30 has an overvoltage of > 17V. / Fault: Voltage of the terminal 30 via 17V / Fault: accounted message failure HBF
Code: 9052
Fault: Component M6/1 (wiper motor) is defective. / Fault: Component K9 (Auxiliary fan stage 1 and 2 relay) has Short circuit to ground. ( Series 463 ) / Fault: Reserve 2 relay lever lighting dimming Short circuit Short circuit, KL. 58D selector lever module relay day / night switching short / Fault: accounted message failure KG
Code: 9053
Fault: Switch S1 (Rotary light switch) supplies an implausible value.
Code: 9080
Fault: Fault in CAN communication with control unit UCP.
Code: 9096
Fault: Component M16/32 (Heat exchanger shutoff motor) is faulty or the lead has open circuit. / Fault: Control module MSS is not sending any data. If fault code occurs with no complaint reported and no malfunctions, erase fault memory and perform a function check. / Fault: Embassy failure MRM CAN message failure MSS / Fault: Accounts for rear window regulator open load
Code: 9027
Fault: Operational fault of component A7/3n1 (SBC control unit) Operational fault of component ABR / Fault: Component N10/1kM (Circuit 15R relay) has Short circuit to ground. / Fault: Relay Kl. 15r short / Fault: Error: oil cooler relay coil short to UBatt oil cooler Relay Short to UBatt
Code: 9034
System diagnosis (MB: 2115403545)
Fault: Synchronization of the DTC memory cannot be ensured. Not Relevant!
Code: 930E
Fault: Knowledge base configuration incomplete. Not Relevant!
Code: 930C
CGW - Central gateway (MB: 2115403545)
Chassis:
Airmatic (MB: 2115450432)
Fault: B22/3 (Rear axle level sensor) : Failure of both signals Not Relevant! / Fault: Check component B22/7 (Left rear level sensor).
Code: 5150
Fault: Critical vehicle level at rear axle
Code: 5501
Body:
HS - Seat heater (MB: 2118203626)
Fault: Not Relevant! / Fault: The supply voltage of the control unit is too low (undervoltage). The supply voltage of the control unit is too low (undervoltage). If the fault is not a current one, it can be ignored.
Code: 9010
Code: 9852
Fault: Component R13/1 (Left front seat heated cushion) or component R13/2 (Left front backrest heated cushion) is overloaded or has a short circuit. Not Relevant! / Fault: Component R13/1 (Left front seat heated cushion) or component R13/2 (Left front backrest heated cushion) is overloaded or has a short circuit. If the fault is not current when seat heater is on, it can be ignored.
Code: 9853
Fault: Component R13/3 (Right front seat heated cushion) or component R13/4 (Right front backrest heated cushion) is overloaded or has a short circuit. Not Relevant! / Fault: Component R13/3 (Right front seat heated cushion) or component R13/4 (Right front backrest heated cushion) is overloaded or has a short circuit. If the fault is not current when seat heater is on, it can be ignored.
Code: 9854
ESA passenger - Electric seat adjustment front passenger (with memory) (MB: 2118201285)
Fault: Fault in CAN communication with control unit EZS. / Fault: CAN-Statusinformation EZS (Time-out)
Code: 9852
Fault: Fault in CAN communication with control unit REAR SAM. / Fault: CAN-Statusinformation SAM_H (Time-out)
Code: 9853
Fault: Fault in CAN communication with control unit ICM. / Fault: CAN-Statusinformation Kombi (Time-out)
Code: 9854
ESA driver - Electric seat adjustment driver (with memory) (MB: 2118201185)
Fault: Hall sensor of component M27m3 (Front raise/lower motor) is faulty. Hall sensor of component M27/3 (Front seat height adjustment motor, driver) is faulty. Hall sensor of component M27/3 (Left front seat height adjustment motor) is faulty. / Fault: Hall sensor height front defective
Code: 9201
Code: 9852
Code: 9853
Code: 9854
Fault: No normalizing of backrest adjustment. / Fault: Scaling back is missing
Code: 9064
Fault: No normalizing of front height adjustment. / Fault: Normalization missing front height
Code: 9061
DCM-RL - Door control module rear left (MB: 2118201526)
Fault: Not Relevant! S21/3 (Left rear power window switch) : The switch lighting has a short circuit. Erase and ignore fault code: the component is not installed in this model series and (or) vehicle variant. / Fault: S21/3 (Left rear power window switch) : The switch lighting has a short circuit. / Fault: Current recognition 'Rear right power window' is faulty. Not Relevant! / Fault: Current recognition 'Right rear' is faulty.
Code: 9207
Fault: Component S51/3s1 (Left rear power window switch) hanging. S21/3 (Left rear power window switch) : The component is hung or has a short circuit. / Fault: The number of blockages of the right seat belt extender is exceeded.
Code: 9505
DCM-RR - Door control module rear right (MB: 2118201626)
Fault: E17/6 (Right rear door entry/exit lamp) : Short circuit or open circuit / Fault: This fault can be ignored and erased.
Code: 9206
Fault: E17/14 (Right rear door inside handle illumination) : Short circuit
Code: 920E
Fault: M14/9 (CL right rear door motor) : Short circuit / Fault: M14/9 (CL right rear door motor) : Short circuit or open circuit
Code: 9404
Fault: Component S51/4s1 (Right rear power window switch) hanging. S21/4 (Right rear power window switch) : The component is hung or has a short circuit.
Code: 9505
DCM-FL - Door control module front left (MB: 2118208185)
Fault: Component S20/1s2 (Right front power window switch) hanging. Not Relevant! / Fault: S20/1s2 (Right front power window switch) : The component is hung or has a short circuit. Not Relevant! / Fault: S20/1s2 (Right front power window switch) : Component does not operate or has short circuit. / Fault: S20/1s2 (Right power windows switch) : The component remains in the switched status (contact sticking) or has Short circuit. Not Relevant!
Code: 9502
Fault: Component S20/1s5 (Rear side windows child safety lock switch) hanging. Not Relevant!
Code: 950D
DCM-FR - Door control module front right (MB: 2118208285)
Fault: The output of component E17/4 (Right front door entry/exit lamp has Short circuit or open circuit. / Fault: E17/4 (Right front door entry/exit lamp : Short circuit / Fault: Component E17/4 (Right door entrance/exit lamp) has Short circuit. Not Relevant! / Fault: E17/4 (Right door entrance/exit lamp) : Short circuit
Code: 9206
Fault: The signal line of component M21/2r2 (Mirror adjustment up/down potentiometer) has Short circuit or open circuit or the component is defective. Erase and ignore fault code: the component is not installed in this model series and (or) vehicle variant. The signal line of component M21/1r2 (Mirror adjustment up/down potentiometer) has Short circuit or open circuit or the component is defective. / Fault: M21/2r2 (Mirror adjustment up/down potentiometer) : Faulty or short circuit . Code 'Mirror memory fitted' is probably wrong. / Fault: The signal line of component M21/2r2 (Mirror adjustment up/down potentiometer) has Short circuit or the component is defective. Not Relevant!
Code: 9208
Fault: The signal line of component M21/2r3 (Mirror adjustment in/out potentiometer) has Short circuit or open circuit or the component is defective. Erase and ignore fault code: the component is not installed in this model series and (or) vehicle variant. / Fault: M21/2r3 (Mirror adjustment in/out potentiometer) : Faulty or short circuit . Code 'Mirror memory fitted' is probably wrong. / Fault: The signal line of component M21/2r3 (Mirror adjustment in/out potentiometer) has Short circuit or the component is defective. Not Relevant!
Code: 9209
Fault: There is a discontinuity in the line to component E6/6 (Right exterior mirror turn signal lamp) or the component is defective. / Fault: E6/6 (Right exterior mirror turn signal lamp) : Open circuit or bulb faulty / Fault: Component E6/6 (Right exterior mirror turn signal lamp) has Open circuit.
Code: 920B
Fault: There is a discontinuity in the line to component M21/2r1 (Mirror heater) or the component is defective. / Fault: Component M21/2r1 (Mirror heater) has Open circuit.
Code: 9211
Fault: Component S92/2 (Right front seat adjustment switch group) hanging. Erase and ignore fault code: the component is not installed in this model series and (or) vehicle variant.
Code: 9506
Fault: No signal from component 'S92/2 (Right front seat adjustment switch group)' on switching bus. Code 'Seat adjustment switch' is probably wrong. Erase and ignore fault code: the component is not installed in this model series and (or) vehicle variant.
ccrobin is offline
post #5 of 11 (permalink) Old 11-08-2015, 12:43 PM
boardboy330's Avatar
Date registered: Mar 2008
Vehicle: 2000 ML320
Quoted: 57 Post(s)
Send a message via AIM to boardboy330 Send a message via Yahoo to boardboy330
Not sure your specific issue, but the battery in our W211 was recently load tested - since we have experienced a completely random mess of red messages while driving. Come to find out, the battery terminal wasn't properly fastened and was just barely loose. Pushing it completely on and tightening has resolved the issue. It is at least worth a look.
"I'd rather peel off my skin and bathe my weeping raw flesh in a bath of vinegar than spend any time with you. But that's just my opinion. Don't take it personally."
(\__/)
(o.O )
(> < ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination
2000 ML320
boardboy330 is offline
post #6 of 11 (permalink) Old 11-08-2015, 03:16 PM
Roadking999's Avatar
Date registered: Apr 2008
Vehicle: E350 4M 06
Quoted: 6 Post(s)
You may want to clear the faults and rescan
These are mostly related to lack of battery power
Roadking999 is offline
post #7 of 11 (permalink) Old 11-09-2015, 06:17 AM Thread Starter
ccrobin's Avatar
Thank you, I will need to try that. I checked all cables and they are tight. I had thought that replacing the aux battery and aux relay would correct this issue. Perhaps though the ECU doesn't clear those codes automatically?
Unfortunately my OBD2 reader program won't clear codes, it will only read them. I could pay about $60 to get the PRO version of the software and clear the codes, but I would rather put that towards an iCarsoft or C3 system. I was just hoping I could clear the annoying RED FAULT in the meantime.
ccrobin is offline
post #8 of 11 (permalink) Old 11-09-2015, 09:48 PM
Ottin's Avatar
Date registered: Jun 2014
Vehicle: 2008 E550
Quoted: 20 Post(s)
Use service mode to monitor voltage for a long time, this happened on my 2005 E320; voltage dropped down after 10 min driving from 14.2 to 13V, that's not enough to charge battery. Finally I changed alternator regulator, a $45 part, so everything works well.
Ottin is offline
post #9 of 11 (permalink) Old 11-09-2015, 11:22 PM
Date registered: Jan 2012
Vehicle: 2008 ML320 CDI , 2006 E320 CDI
Quoted: 55 Post(s)
i dont know if this applies to 2004 models- mine is a 2006
but do a search and find my thread
red battery light- visit workshop = battery control module
not sure how to post the thread link here
maybe this will help
2006 E320 CDI
2008 ML320 CDI
2008 GL320 CDI
cvincent is offline
post #10 of 11 (permalink) Old 11-19-2015, 06:29 PM
Date registered: Mar 2012
Vehicle: 2005 E320 CDI
Quoted: 68 Post(s)
I'm glad you had the main battery load tested. I'm curious if the aux battery that you replaced is not faulty? Perhaps measure the voltage on it after it sits all night and post the results here.
I recently had an issue with my aux(SBC) battery myself. I measured it after it sat all night and it was down to 11.71VDC. Started the car up while monitoring voltage at each battery and the battery in trunk went right up as expected as the vehicle tops it's charge off. The aux battery stays at 11.71 volts for around 30-45 seconds and then jumps to 14.15. Apparently the BCM charge circuitry/relay for that is working so that is good. If you see the same voltage swing as the BCM circuitry/relay kicks in then you know that's working like it should. I ended up installing a YUASA GYZ16H in mine since it has a 16AH capacity vs the 12 in the OE FIAMM version. Battery technology has come along way since 2004/2005.
Josh8loop is offline
