Center speaker distortion - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 05-18-2015, 07:27 AM Thread Starter
ps2cho's Avatar
Date registered: Oct 2006
Vehicle: 2008 E350 4M, 1988 300TE
Quoted: 344 Post(s)
So I got my aux input installed and with the engine off I can hear the center speaker is distorted and is fuzzy. I didn't notice this before on lower quality radio.
Is there any repair or is it replacement only? Any aftermarket or is it typical MB oddball sizes?
Thanks!
ps2cho is offline
post #2 of 11 (permalink) Old 05-18-2015, 08:54 PM Thread Starter
ps2cho's Avatar
Quoted: 344 Post(s)
I pulled the top off the dash today and it seems that the speaker has separated from the metal frame. I called the dealer and they wanted $157 plus tax!!! Insane....
Until I can order one off ECSTuning which is only $103, I put a layer of glue all around the outside to hold the speaker to the frame. We will see tomorrow once its dried if it holds me over.
I wonder if the exposure to the sun/heat is the reason why this one failed quickly?
2016 Monsoon Gray Audi Allroad - 26k
2008 Black Mercedes E350 4Matic Sport P1 - 140k
2014 Jeep Wranger Unlimited Sahara - 90k
2003 Silver ML350 - 135k
ps2cho is offline
post #3 of 11 (permalink) Old 05-18-2015, 10:34 PM
Purple Moderator
Date registered: Jul 2005
Quoted: 1507 Post(s)
That is the reason. Other users have used an adhesive that stays flexible after it cures for the repair and reported a good success rate.
Noodles is offline
post #4 of 11 (permalink) Old 05-19-2015, 07:24 AM Thread Starter
ps2cho's Avatar
Quoted: 344 Post(s)
Well it seems to have fixed the problem!
The song that it would always buzz and hiss at was John Mayer - Stitched Up. It has a huge range that always nailed that speaker while 90% of all my other songs would give no indication.
Glad it was a cheap fix and next time I hear an issue I'll replace it with a new one!
ps2cho is offline
post #5 of 11 (permalink) Old 05-21-2015, 08:39 AM
dtsdig's Avatar
Date registered: Feb 2011
Vehicle: 1994 Mercedes E320 Sedan 97K, 1995 Mercedes E320 Wagon 156K, 2009 VW EOS 45K (Wife's car)
Quoted: 103 Post(s)
Send a message via Skype™ to dtsdig
@ps2cho , Since I have taken my 95 E320 off the road, I have been looking for what's next in my driveway and got curious about the W211 wagons. Since you own both, can I hit you up for some insight?
dtsdig is offline
post #6 of 11 (permalink) Old 10-20-2017, 09:27 AM
Date registered: Mar 2011
Vehicle: 2007 E350 SP1 (M211.056/E272.964)
Quoted: 21 Post(s)
Just wonder if anyone successfully replaced center speaker with an aftermarket one?
btv94 is offline
post #7 of 11 (permalink) Old 10-20-2017, 02:42 PM Thread Starter
ps2cho's Avatar
Quoted: 344 Post(s)
Itís been 2-years since my glue repair and speaker still works fine. Anything can be done, but there is no direct swap with the correct ohms
ps2cho is offline
post #8 of 11 (permalink) Old 10-20-2017, 03:01 PM
Quoted: 21 Post(s)
I try to fix the speaker itself, but in my case the lower material/cone has also separated from the rubber part. Just purchased new one from OE discount parts.
btv94 is offline
post #9 of 11 (permalink) Old 01-30-2018, 12:17 PM
Date registered: Feb 2017
Vehicle: 2007 E320
Quoted: 2 Post(s)
I had the same center speaker distortion on my 07 E320. I ended up pulling the speaker out and running a bead of silicone around the speaker where the speaker material meets the metal frame. After letting it dry for a day the speaker sounds great! What a cheap fix! I think this is a common problem for W211.
2007w211 is offline
post #10 of 11 (permalink) Old 01-30-2018, 02:09 PM
LasCondes's Avatar
Date registered: Jul 2011
Vehicle: 2013 E350, 212.059, Avantgarde, Engine: 276.952, Gearbox 722.906
Quoted: 75 Post(s)
Do you recall what silicone you used, many varieties out there! I'd rather go with something that's been tried and proven. Thanks.
History of:
1968 280 S
1985 300 D Turbodiesel
1990 300 E
1995 E320
1999 E320
2005 E320
LasCondes is offline
