ABS rpm sensor replaced the rotation direction is incorrect - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 02-13-2015, 02:00 PM Thread Starter
Date registered: Jun 2012
Vehicle: 03 sl55 amg, slk230 hers, 06 e350 4matic estate black 7 pass, 97 sl500 red 2013 ml350 bluetec
Hi has anybody ever experienced this before. i replaced a bad left rear abs speed sensor .and the new code i get with star diagnostics is 4823 L6/3(left rear speed sensor) the rotation direction is incorrect... i used a pex abs sensor. when i check the actual vaules all 4 wheels are turning the same speed. any body have any suggestions. I thought about switching the location of the pins in the plug. but i thought i would ask for suggestions first.. thanks Dan i tried clearing the code a couple times but it returns almost instantly the car is an E350 2006
danosll is offline
post #2 of 4 (permalink) Old 11-07-2017, 12:32 PM
Date registered: Nov 2017
Hello! Did you ever find out what was wrong? I am from Norway and i have done the same as you and got the same problem... I have search google from top to bottom and you are the only one with the same problem! Please tell me you found a solution to the problem!
niklasf91 is offline
post #3 of 4 (permalink) Old 11-07-2017, 12:51 PM Thread Starter
Actually No . I have tried a different sensor with the same results i even tried cutting wires and switching them only to get a code for defective sensor. i have the magnetic ring to try but i havent as of yet.
danosll is offline
post #4 of 4 (permalink) Old 11-07-2017, 01:08 PM
to bad, i was really hoping for a solution:/ If you ever find out, please do tell
