Remove CD changer? - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 01-31-2015, 11:06 PM Thread Starter
meooem1's Avatar
Date registered: Nov 2006
Vehicle: 2004 e320 svr/blk 136k
Quoted: 16 Post(s)
Remove CD changer?
I would rather have the storage under the radio then have a cd changer. Has anyone removed theirs. Do I need to buy the storage bin or is it just an empty area after the removal of the cd changer.
meooem1 is offline
post #2 of 13 (permalink) Old 02-01-2015, 04:17 PM
Date registered: Feb 2010
Vehicle: 2007 E320 Bluetec, 2008 320ML CDI
Quoted: 272 Post(s)
Interesting thought. That would create a nice storage area.
Would the removal of the CD player require coding of the MOST system or would the head unit accommodate that aspect?
Skippy
SkippyJasper is offline
post #3 of 13 (permalink) Old 10-11-2016, 03:47 PM
Ottin's Avatar
Date registered: Jun 2014
Vehicle: 2008 E550
Quoted: 20 Post(s)
Same thoughts, may someone give a solution?
Thanks!
从我的 iPhone 发送,使用 Tapatalk
Ottin is offline
post #4 of 13 (permalink) Old 10-12-2016, 08:15 AM
konigstiger's Avatar
Date registered: Jan 2007
Vehicle: '71 Pinto
Quoted: 388 Post(s)
Disconnect electrical harness / fuse 26 @ interior panel beside dash.
Convert fiber optic harness by reversing instructions in attachment, or install bridge part # 0005454484 to eliminate CDC from MOST loop.
Reconfigure MOST using SDS (MB diagnostic system).
Install storage tray part # 2116830091.
File Type: pdf W211 CD-Changer Wiring Harness Retrofitting.pdf (585.1 KB, 291 views)
File Type: pdf Retrofit fiber optic cable wiring harness.pdf (61.3 KB, 229 views)
Noodles and Ottin like this.
konigstiger is offline
post #5 of 13 (permalink) Old 10-17-2016, 05:19 PM
Ottin's Avatar
Vehicle: 2008 E550
Quoted: 20 Post(s)
Thanks brother!
Have done it last weekend, only trick is bypassing the 2 optic cables,easy.
Also, I do have a tray, using glue adhesive it. No need coding.
Ottin is offline
post #6 of 13 (permalink) Old 10-17-2016, 08:50 PM
Ottin's Avatar
Vehicle: 2008 E550
Quoted: 20 Post(s)
Remove CD changer?
Forgot picture
Thanks again
Noodles likes this.
Ottin is offline
post #7 of 13 (permalink) Old 02-18-2019, 07:12 PM
Date registered: Feb 2019
Vehicle: 2007 E350
I know this is an old thread, but I figured asking anyhow...
I too want to change out my CD changer for a storage compartment, but I have a few questions.
-I swapped out my NTG head unit for an Android unit, so am bypassing fiber optics in the car. Would I still need a fiber optic closeout in order for the CD changer panel to operate?
-If so, would you have a part number for the FO close out? (sorry, I'm a complete noob)
Kind of a shot in the dark, but thanks in advance!
Brooklyn.W211 is offline
post #8 of 13 (permalink) Old 02-19-2019, 02:05 PM
jlexvold's Avatar
Date registered: Jun 2018
Vehicle: 2008 E350 4Matic Sport
Quoted: 15 Post(s)
Haha...All I can think of when looking at this, is that you all must have a need for a hidden drug compartment.
jlexvold is offline
post #9 of 13 (permalink) Old 08-09-2019, 11:53 AM
Date registered: Aug 2019
Question
I'd actually welcome advice on how to do this too...
CD changer isn't working for me anymore following switch to android headunit. It had stopped opening actually before that too when I pressed the open button it wouldn't work and I'd see CD error when attempting to remove from the old radio....So it's entirely possible the release door won't open for me even after the switch. :-/ I think I'm in exactly the same situation as Brooklyn.w211 above.
Thanks all!
IsleofManw211 is offline
post #10 of 13 (permalink) Old 08-09-2019, 12:46 PM
Well I managed to remove the CD changer ok, the front panel came up after I loosened it. I detached the bit at the bottom to do so which I assume was the motor to open and close the compartment?? After teh drawer had closed again it now will not reopen again and pushing the silver button does nothing. Thankfully the hazard warning lights, door lock, and other buttons on the front panel still work.
Suggestions on how to make the front fascia/panel work again? Is it powered by the same wire as the hazards or a different connector?
