Headlight adjustment - Page 4 - Mercedes-Benz Forum
post #31 of 35 (permalink) Old 02-10-2018, 12:15 PM
Date registered: Mar 2006
Vehicle: 2008 W211
Quoted: 10 Post(s)
I followed his instruction and did this yesterday. But you dont have to cut up the bridge, just remove the 3 torx crews, then you can easily remove the bridge.....
MB_FanAddict likes this.
nguyenphananh is offline
post #32 of 35 (permalink) Old 02-10-2018, 03:01 PM
MB_FanAddict's Avatar
Date registered: Oct 2009
Vehicle: 2013 Mercedes-Benz C250 Sedan
Quoted: 9 Post(s)
Originally Posted by nguyenphananh View Post
I followed his instruction and did this yesterday. But you don't have to cut up the bridge, just remove the 3 torx screws, then you can easily remove the bridge.....
That's great, I'm glad it helped you!
I did not attempt to try and remove the bridge without cutting it up first (on my pre-facelift W211), as it did not look like there was enough clearance to lift it over the adjustment screw and the other member that tried, did not have any luck (maybe face lifted cars are different?).
MB_FanAddict is offline
post #33 of 35 (permalink) Old 03-03-2018, 10:22 AM
Date registered: Nov 2009
Vehicle: 2006 E320 CDI
Quoted: 72 Post(s)
I just made the high beam adjustment, without cutting off the bridge from the low beam adjuster. I drilled a hole in the bridge to reach the high beam screw, removed the 3 torque screws holding the bridge in place, then pried the bridge up to disengage the mechanism. Made the the high beam adjustment, then put the bridge back in place. Will check my beam throw after dark.
John
hangit is offline
post #34 of 35 (permalink) Old 03-07-2018, 09:47 PM
ot1
Date registered: Apr 2007
Quoted: 143 Post(s)
on a 06 E320 the WIS says adjustment of BiXenon with Active Curve is via Star, is this absolute?
ot1 is offline
post #35 of 35 (permalink) Old 03-08-2018, 08:25 AM
Quoted: 9 Post(s)
Yes, that's correct. The fog lights and auxiliary high beams are the only lights you can manually aim on cars equipped with Bi-Xenons.
