HELP!!! NON-MB EXTENDED Warranty Details - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 12-10-2011, 04:00 PM Thread Starter
Date registered: Feb 2008
Hi, I need some help and guidance in picking the NON-MB EXTENDED Warranty from EFG Companies (EFG Companies). Anybody knows this company? They are providing coverage for all EXCEPT standard industry Exclusions
Anybody heard of Century Warranty Services ?. this is from Costco it is a exclusionary warranty policies:
( $5000 for 48M/48K More Miles w/$250 deductible)
exclusionary List:
BRAKE LININGS, BRAKE DRUMS AND ROTORS, DISC BRAKE PADS (EXCEPT WHERE NOTED UNDER RELATED DAMAGE COVERAGE), STANDARD TRANSMISSION CLUTCH COMPONENTS AND ASSEMBLIES, AIR BAGS, SOLAR POWERED DEVICES, HINGES, GLASS, LENSES, SEALED BEAMS, BODY PARTS AND/OR PANELS, TRIM, MOLDINGS, DOOR HANDLES, LOCK CYLINDERS, TIRES, WHEELS, BATTERIES, LIGHT BULBS, UPHOLSTERY, PAINT, BRIGHT METAL, FREEZE PLUGS, HEATER AND RADIATOR HOSES, EXHAUST SYSTEM, SHOCK ABSORBERS, AUDIO/SECURITY OR OTHER SYSTEMS NOT FACTORY INSTALLED, WORK SUCH AS FRONT-END ALIGNMENT OR WHEEL BALANCING, CONSTANT VELOCITY JOINT BOOTS, SAFETY RESTRAINT SYSTEMS, CELLULAR PHONES, RADAR DETECTORS, APPLIANCES, VINYL AND CONVERTIBLE TOPS.
VS EFG Companies( $3500 for 60M/60K More miles w/$100 deductible)
exclusionary List:
Paint,Carpet,bright metal trim, sheet metal, bumpers,body panels, glass, physical damage, molding, upholstery, lenses,sealed beams,light bulbs, fuses,circuit breakers, cellular phones, television/VCR/DVD players, games centers, AM/FM Radio/Cassette/CD players and speakers, exceeding three hundred dollar($300) repair or replacement costs, audio/video equipment, all touch screen and/or voice activated accessories including related display screens and heads up displays on windshields, electronics transmitting/receiving devices, navigation systems( unless Navigation system coverage box has marked and paid in the registration page), voice recognition systems, remote control consoles,radar detection devices, weather-strips, all exhaust components the following emission components: purge valve/ solenoids/sensors, vacuum canister, vapor return canister, vapor return line/valves, air pump/lines/valves, emission vapor sensors,gas cap/filler neck,catalytic converter,battery,battery cables/harness, spark plug wires, fan belts, non-metallic hoses,
distributor cap and rotor, shock absorbers,manual/hydraulic clutch assembly, friction clutch disc, and pressure plate, weather strips,trim,outside ornamentation, frame and structural body parts, vinyl and convertible top, canvas tip, any convertible top assemblies, fabric top, fiberglass top, hardware or linkages, tires, wheels/rims, wheel balance, safety restraint system(including air bags), air and water leaks, wind noise, squeaks, rattles, and all maintenance services including alignments, brake pads and shoes,brake rotors and drums, tune ups, coolants lubricants.
Which one would one buy????
johnvkumar is offline
Mercedes Extended Warranty Group Purchase Discount! See Inside For Details. brucemendel W163 M-Class 11 06-09-2011 01:02 PM
Mercedes Extended Warranty Group Purchase Discount! See Inside For Details. brucemendel W203 C32 AMG, C55 AMG 1 04-26-2011 06:48 PM
Mercedes Extended Warranty Group Purchase Discount! See Inside For Details. brucemendel W164 M-Class 3 04-08-2011 07:18 PM
Mercedes Extended Warranty Group Purchase Discount! See Inside For Details. brucemendel X204 GLK-Class 0 03-31-2011 07:16 AM
Mercedes Extended Warranty Group Purchase Discount! See Inside For Details. brucemendel C216 CL-Class 0 03-31-2011 07:08 AM
