Mercedes-Benz Forum (https://www.benzworld.org/forums/)
-   W210 E50 AMG, E55 AMG (https://www.benzworld.org/forums/w210-e50-amg-e55-amg/)
-   -   E55 BAS Problem (https://www.benzworld.org/forums/w210-e50-amg-e55-amg/3010610-e55-bas-problem.html)
s38junkie 11-26-2018 05:10 AM
E55 BAS Problem
I have a 2001 E55 with 124K miles that seems to be randomly activating the BAS at highway speeds when lightly touching the brakes. This means I am getting full brake when I am only applying very light brake pressure and it momentarily triggers the ABS to prevent the front wheels from locking. It releases brakes and deactivates the BAS a second after I take my foot off the brake pedal. I have no BAS / EPS warning lights in the dash.
Obviously, this is dangerous and I have unplugged the BAS / EPS module. Any ideas where to start trouble shooting? I think these cars also have yaw and steering angle sensors that are inputs for the BAS / EPS?
Thanks in advance!
illstplaya 11-27-2018 06:05 PM
You should post this question in the regular W210 forum because there's a lot more people there. There's nothing specific to the E55 regarding BAS or ABS so it's OK to post over there.
s38junkie 11-28-2018 08:37 AM
Will do. Thanks for the tip!
JOE55 12-03-2018 12:11 PM
Thanks in advance!
Did you scan for errors and what are the error codes?
Also did you recently changed your battery and forgot to reset the BAS.
s38junkie 12-04-2018 02:59 PM
I'm not getting any error codes or warning lights on the dash.
I suspect it is either the membrane travel sensor and / or the brake booster. Is it possible to replace just the travel sensor? Anyone have the correct part #?
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
