Need help getting correct O2 sensors - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 08-27-2018, 07:07 AM Thread Starter
Date registered: Aug 2018
Vehicle: 2000 E55 AMG
I have a 2000 E55 AMG VIN: WDBJF74J4YB133714
I'm looking to replace the two O2 sensors upstream and I'm getting conflicting information on which ones to get and wanted to know if anyone knows for certain which are the right ones. I'm looking to get bosch sensors with OEM connectors. Various parts stores such as autohausaz and pelican parts state I need the following:
Bosch 13642 - Left Front
Bosch 13798 - Right Front
However going to the Bosch website in putting in the vehicle information yields different results:
Bosch 16274 - Left Front
Bosch 16353 - Right Front
Any help would be appreciated.
Fotoflame is offline
post #2 of 4 (permalink) Old 08-27-2018, 09:08 PM
Date registered: Sep 2016
Vehicle: 2002 E55 AMG Sedan
Quoted: 270 Post(s)
I don't know where you got the Bosch 13642 and 13798 from but I don't not see it on Autohausaz.com.
The correct oxygen sensors are the second numbers you listed, 16274 and 16353.
illstplaya is offline
post #3 of 4 (permalink) Old 08-28-2018, 05:42 AM Thread Starter
Thanks for the response. On Autohaus, if you input your E55 AMG as 2001 or newer, it says the O2 sensors are 16274 and 16353.
However if you enter a 2000 or earlier E55, it states they are 13642 and 13798. FCP Euro has the same output.
It seems that they changed sensors somewhere on the line. But I'm getting conflicting info from Bosch vs the parts vendors.
post #4 of 4 (permalink) Old 09-26-2018, 01:23 PM Thread Starter
So I just wanted to provide a current status to my situation. I went with the recommendations of the Bosch website for O2 sensors for my year and model and got 16274 and 16353. Almost immediately after installation I got two engine codes P0135 and P0155 which are for a O2 sensor heater circuit malfunction. I pulled the sensors out and checked resistance on the heater circuit and got a reading around 10 ohms for each sensor. Thinking maybe this was due to defective sensors I returned them and got new sensors of the same model. I tested resistance for the new ones before installation and they both had a resistance of around 10 ohms as well. I'm fairly certain that's the spec resistance for these sensors.
After that I returned the 16274 and 16353 sensors and ordered the Bosch 13642 and 13798 sensors. The resistance of these sensors was around 5 for each one. I installed them and have had no problems ever since.
  Mercedes-Benz Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
