Bolt Mystery - '00 E55 Exhaust/Transmission Bracket - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 03-20-2018, 10:19 PM Thread Starter
Komrade 124's Avatar
Date registered: Dec 2010
Vehicle: '04 G500, '00 E55 AMG, '90 300TE 4Matic, '82 240D
Quoted: 151 Post(s)
Recently noticed an exhaust rattle emanating from the transmission area under my 2000 E55. It only happens at idle in Drive, i.e. at stop lights. While driving or in Park it stops. After getting the car on a lift it's clear there is a missing bracket and accompanying bolts (I assume..) that connect the two sides of the exhaust to the transmission.
Looking at the EPC diagram it appears there is a two-piece rubber and metal plate (1404920118, 1404920018) that are missing, however the corresponding bolt in the diagram is listed as *not valid for this model*
Anybody know what's going on here or perhaps can point towards a PN for the correct bolts?
2004 G500 - 116,000
2000 E55 AMG - 140,000 mi
1990 300TE 4MATIC JDM - 82,000 mi
1982 240D 4-spd - 140,000 mi
1983 250
1998 ML320
1995 E300D
1992 400E
1994 E320T
1990 300E 2.8
1988 300CE Lorinser
1988 300TE
1990 300E
Komrade 124 is offline
post #2 of 8 (permalink) Old 03-23-2018, 09:21 PM
khomer2's Avatar
Date registered: Nov 2015
Vehicle: w163 02 ML500 W210 97 E50Amg w202 99 C230K w124 - need more space, time to build again
Quoted: 219 Post(s)
I think you may have pulled up the exhaust assembly for a six cylinder.
here's what I found for a w210 E55 AMG North America.... 8 cylinder.
Mercedes-Benz Teilekatalog (Ersatzteile online)
part # 59
Komrade 124 likes this.
khomer2 is online now
post #3 of 8 (permalink) Old 03-24-2018, 09:20 AM Thread Starter
Quoted: 151 Post(s)
part # 59
Interesting, thank you!
It gives two part numbers for #59..
1. N914007008029 (COMBINATION BOLT
FRONT EXHAUST PIPE TO TRANSMISSION M 8X40)
This one doesn't seem to bring up a part in any of the online catalogs
2. N304017008018 (SCREW
FRONT EXHAUST PIPE TO TRANSMISSION M 8X35)
From parts . com: Mount bracket bolt $1.77 ea.
When I search for Mercedes "M8x40" I get part number 1409904801/000000001153 indicated for a timing cover bolt. "M8x35" gets me 910105008014/900170008018 indicated for "EXHAUST COMPONENTS / Converter & pipe screw"
All things seem to be pointing to that 2nd part (8x35 bolt) I will try ordering a couple and see if that's correct.
Thanks again for the info.
2004 G500 - 116,000
1983 250
1998 ML320
1995 E300D
1992 400E
1994 E320T
1990 300E 2.8
1988 300CE Lorinser
1988 300TE
1990 300E
post #4 of 8 (permalink) Old 03-24-2018, 10:22 AM
khomer2's Avatar
Quoted: 219 Post(s)
Btw, if you require the rubber component that sits between the transmission and the bracket, you can use any type of thicker rubber piece you may have laying around or neoprene to prevent metal-to-metal chaffing.
I've cut up older rubber/ neoprene floor mats for use, to use as a go between in situations like this.
post #5 of 8 (permalink) Old 03-24-2018, 01:16 PM Thread Starter
Quoted: 151 Post(s)
Ah nice, I already have the new bracket and rubber piece from Mercedes but that's a good tip, I'll keep that in mind if I ever have to deal with these again.
My local dealership had the bolt (304017008018) in stock @$2.50ea so I picked up a couple of those and will try them out when I can get the car in the air.
Is there any trick for assembly? Or is it essentially just fold the rubber part in half, sandwich it between the exhuast brackets+top plate, put the bolts through everything, and then tighten them down?
2004 G500 - 116,000
1983 250
1998 ML320
1995 E300D
1992 400E
1994 E320T
1990 300E 2.8
1988 300CE Lorinser
1988 300TE
1990 300E
post #6 of 8 (permalink) Old 03-24-2018, 03:17 PM
khomer2's Avatar
Quoted: 219 Post(s)
No trick, just like a sandwich and then install the bolts and tighten up her up.
post #7 of 8 (permalink) Old 03-25-2018, 11:22 PM
unimogken's Avatar
Date registered: May 2004
Vehicle: 1965 404, 1980 MB4/94, 1983 240D, 1999 E55, 2000 ML55
Quoted: 78 Post(s)
Good to see you still have the E55!
Haven't seen you on here in a long time!
A buddy of mine has a friend in Everett that parted out a '99 and has a ton of bins and boxes full of stuff.
unimogken is offline
post #8 of 8 (permalink) Old 04-01-2018, 09:52 AM Thread Starter
Quoted: 151 Post(s)
Yes, my E55 has been very well behaved for the most part and is thus keeping me busy with projects on my W124
Thanks for letting me know about the '99 being parted, I'll keep that in mind.
It'd be fun to have an E55 meet-up for all the PNW owners!
2004 G500 - 116,000
1983 250
1998 ML320
1995 E300D
1992 400E
1994 E320T
1990 300E 2.8
1988 300CE Lorinser
1988 300TE
1990 300E
  Mercedes-Benz Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
