Alignment - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 12-28-2017, 03:21 PM Thread Starter
rufrob's Avatar
Date registered: May 2009
Quoted: 24 Post(s)
Alignment
I got new tires about 2 years ago covered about 10,000km. Suddenly the steering felt a bit too light and strange. Pulled the wheels off and found rear tires worn on the inside corner.
Front wasnít so bad.
I checked all the suspension and steering components with a crowbar but couldnít find any play.
Iím running US tire size on a Euro spec car.
Are the alignment specs different for US and German cars?
rufrob is offline
post #2 of 7 (permalink) Old 01-17-2018, 04:25 AM
Date registered: Jan 2009
Hi , i don't know ,if Us alignment data are different fron EU cars , (i think they should be the same).In the pictures it seems you have too much toe in.
Best regards
Antonino
antoninosavoca is offline
post #3 of 7 (permalink) Old 01-17-2018, 10:51 AM
pt_700's Avatar
Date registered: Apr 2012
Vehicle: 1998 e430
Quoted: 54 Post(s)
my 1998 e430 had similar issues. turned out to be negative camber, most of which the alignment shop was able to remove with the stock adjustments available.
if yours is beyond that, there are special bolts for the control arms that can add / remove about 3 degrees or you could replace a control arm with an adjustable one.
ID:	2354769   Click image for larger version
pt_700 is offline
post #4 of 7 (permalink) Old 01-17-2018, 01:43 PM Thread Starter
rufrob's Avatar
Quoted: 24 Post(s)
Thanks. Iíll have it check.
Sent from my iPad using Tapatalk
rufrob is offline
post #5 of 7 (permalink) Old 07-07-2018, 09:45 PM Thread Starter
rufrob's Avatar
Quoted: 24 Post(s)
Finally got around to working on my front suspension. I did the left front LCA bushings. PITA but wow!! Huge difference in firmness and road feel. Iíll do the right side next week.
rufrob is offline
post #6 of 7 (permalink) Old 07-08-2018, 12:40 PM
Date registered: Jul 2018
Vehicle: 2001 Mercedes-Benz E55 AMG
Quoted: 2 Post(s)
I would check for toe-out on both front and rear.
range96 is offline
post #7 of 7 (permalink) Old 07-08-2018, 02:38 PM Thread Starter
rufrob's Avatar
Quoted: 24 Post(s)
Will do when I get the other side done
rufrob is offline
  Mercedes-Benz Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
