Cross Post: 40MPH Vibration Solved! - Page 2 - Mercedes-Benz Forum
post #11 of 14 (permalink) Old 08-09-2014, 10:56 AM
freedspeak's Avatar
Date registered: Jan 2012
Vehicle: W210 E55
Vacuum line next to MAF popped out of it's rubber boot (see new post for details). Reset ECU/TCU with accelerator pedal trick and light hasn't come back yet. Fingers crossed.
freedspeak is offline
post #12 of 14 (permalink) Old 08-12-2014, 11:47 AM
ddb
Date registered: Apr 2013
SoDiezl350,
Thanks to you, as well as others that have contributed to this thread. I too have been fighting vibration issues with my 2002 E55. I've recently replaced motor mounts (the driver's side was ruptured and the passenger side was in poor shape); both flex discs; the transmission mount; the center driveshaft support bracket and bearing; and had all four tires re-balanced. I'm not sure if the parts other than the motor mounts needed replacing, but I'm glad I did while there.
These changes helped greatly, but didn't totally eliminate the vibrations. I saw this thread and thought I would remove the spacer and see if it helped. It did! Just took the car for a thirty minute drive and it such a noticeable improvement! I believe I still have an issue and may need lower control arm bushings. But I'm thrilled with the ride and will look into replacing the LCA bushings at a later date.
I too don't totally understand why removing the spacer helped. Is it to compensate for the new motor mounts and slightly altered angle because of them? If so, it seems to me there would be a lot more talk about removing and adding spacers with as many motor mounts changes that must happen with W210's and other models. At any rate, I'm just glad it helped.
Some notes about removing the spacer: I removed the small panel that sits just inboard of the passenger side rear wheel. It is held on by four 10mm nuts. I also removed the bracket that supports the panel. It is held on by two 10mm nuts. Removing this panel just gives you a little more space to work, plus it allowed me to better see my headlight level mechanism which I thought may be broken (it was o.k. and I found the front level mechanism broken).
You need a 8mm hex bit to remove the bolt that holds the spacer in place and my car had a 17mm nut on top. It is a little difficult to secure the top nut in place to loosen and tighten the bolt. I was able to do it relatively easy using a 17mm ratcheting wrench with an articulating head.
A couple of pics. My spacer had 4 notches so I guess it is 4mm.
Thanks again for posting this information!
ddb
ddb is offline
post #13 of 14 (permalink) Old 11-09-2015, 12:51 AM
Date registered: Nov 2015
Is removing the spacer not only curing a symptom. Normaly the hardydisk is flexible and must pick up the minimal misalignment. When driving, the front and back axle is moving a bit because of the flexible bushings, so the hardysisk is for that reason a flexible one?
BertMercedes is offline
post #14 of 14 (permalink) Old 02-09-2019, 02:44 PM
Date registered: Sep 2016
WOW! This worked on my 2001 E55. 15 min job to pop out the spacer and torque it back up. Vibration disappeared!
alhounos is offline
  Mercedes-Benz Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
