Serpentine Belt shredded... Help? - Page 2 - Mercedes-Benz Forum
post #11 of 16 (permalink) Old 04-03-2012, 05:11 PM
SHAUNE55's Avatar
Date registered: Aug 2010
Vehicle: 2001 E55 AMG
Quoted: 4 Post(s)
I will have a look in the morning at the size,
CC my mistake I've only ever encountered the older style tensioner, if you mean the top idler pulley I've only ever had to take the fan off to get the long bolt out.
Eric Cantona quotes
When the seagulls follow the trawler, it is because they think sardines will be thrown into the sea.
SHAUNE55 is offline
post #12 of 16 (permalink) Old 04-03-2012, 06:17 PM
Date registered: Jul 2006
Vehicle: 1999 E55, 2001 E320, 1990 560 SEC, 2004 ML350, 2001 ML55, 1995 S500, 1998 SL500, 2010 E550 Sport zoo
Quoted: 157 Post(s)
I have replaced idler wheel pulley - it's cheap buddy - since you are removing the fan the pulley is a easy job. Sure, pulling shroud clips and tilting works best to pull and reinstall the fan.
Go down to the W210 standard forum, same DIY, just a bit less front space to work with.
It would be foolish NOT to replace the idler pulley - since your old style tensioner shreded the belt (they sheds long way) - and your idler pulley already has serious cracks running fron the inner bearing race to alsmost the outside rim - it's ready to blow soon and with that you will be at square one over one $20/whatever part.
Yes - that idelr pully bolt is like a never ending long one for sure !
fabbrisd1 is offline
post #13 of 16 (permalink) Old 04-04-2012, 10:06 AM
SHAUNE55's Avatar
Quoted: 4 Post(s)
OK I have the newer tensioner on this 2001 car so I can't help you with the torx size for the old one, I sold the one that had the old tensioner.
New one is 17mm and lift counter clockwise.
As I said though I've done the old ones with a ring spanner.
Eric Cantona quotes
SHAUNE55 is offline
post #14 of 16 (permalink) Old 04-07-2012, 01:45 PM Thread Starter
Gray_Ghost's Avatar
Date registered: Oct 2008
Vehicle: None currently. W210 or W211 AMG wanted.
Many thanks to the people that chimed in with help and advice. The tools arrived about 2:30 today. Finished up disassembly and reassembly in and hour and a half. New belt, fan, and clutch. Warmed it up to operating temperature, then took it on a rather spirited test drive (scaring my girlfriend's bro in the process, hehehe). My baby is back on the road and running about 10 degrees cooler as well. Again thank you! I couldn't have done it without your help.
Welcome my son, Welcome to the machine...
Gray_Ghost is offline
post #15 of 16 (permalink) Old 04-07-2012, 02:26 PM
Quoted: 157 Post(s)
If you didn't replace the tensioner and the idler pulley at the same time - then my hat's off to you buddy for attitude.
post #16 of 16 (permalink) Old 08-04-2018, 11:00 PM
Date registered: Aug 2018
So I recognize this thread/post is very old but I have a 2001 W210 e55 that started shredding belts weekly. Shredded 5 before I took it in to the Mercedes dealer for some help. This is my son's car and outside of this issue it has been a real trooper of car. It has 156K on the clock and it runs really well but this was annoying as hell and very inconvenient when it would shred many miles from the house. Anyway, I started into a long drown out process of replacing parts before I finally figured it out. At least I think I have as it's been two weeks and 150 miles since I have thrown a belt.
Parts replaced in order:
First belt: new belt
Second belt: new belt again
Third belt: new belt + tensioner + pulley (new style)
Fourth belt: new belt + fan clutch (sorta needed to be replaced anyway)
Fifth belt: new belt + alternator (old one full of melted rubber from all the previous thrown belts)
Sixth and current belt: new belt + A/C compressor & dryer + water pump (water pump was the culprit)
So after all that it turned out that the water pump had a very slow leak and was dripping on the belt. The water and coolant was causing the rubber get slick and walk back and forth on the hub of the fan clutch. They would get extremely hot weakening the belt and you know what comes next. The leak in the water pump was very slight but would increase once the revs would get up and the engine got to operating temperature. Let this be a service to anyone who's had the dreaded shredded belt situation on these cars. Start with checking to see if you have a very hard to detect leak that's dripping on your belt.
W210e55 is offline
  Mercedes-Benz Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
poly v belt -- serpentine belt [email protected] V-Class 3 07-27-2014 01:25 PM
V belt or Serpentine Belt replacement question bavenda W163 M-Class 2 01-29-2011 07:44 AM
3 Serpentine Belts shredded in 5 days! gsj224 W163 M-Class 4 09-26-2010 02:51 PM
"V Belt" as MB calls it or Serpentine Belt 98MBE320 W210 E-Class 12 01-05-2010 02:36 PM
V belt completely shredded ... delikanli W210 E-Class 20 12-24-2009 01:44 AM
