slow acceleration problem....o2 sensors? - Page 4 - Mercedes-Benz Forum
post #31 of 38 (permalink) Old 09-05-2009, 04:31 PM
Date registered: Jul 2006
Vehicle: 1999 E55, 2001 E320, 1990 560 SEC, 2004 ML350, 2001 ML55, 1995 S500, 1998 SL500, 2010 E550 Sport zoo
Quoted: 157 Post(s)
You might have a bad cat holding you back..
You might have a bad cat holding you back, if everything else get's swapped out..
fabbrisd1 is offline
post #32 of 38 (permalink) Old 09-05-2009, 10:24 PM
Date registered: Oct 2008
Vehicle: 2000 E55 W210
Quoted: 2 Post(s)
Well if cats were a problem than power would not be restored after a reset would it?
amgalex is offline
post #33 of 38 (permalink) Old 09-11-2009, 10:37 AM
Quoted: 157 Post(s)
You have mentioned a -100bhp reduction in power, that kindof power loos can only come as a result of serious restriction in-or-out.
Normally, a soft reset restores the factory defaults, and then the factory defaults degrade over drive time, but 4-6 weeks is not uncommon before even a hep owner "feels" the need to do another soft reset to get the zip back.
However, degrading the factory defaults that result in a - 100bhp loss, something has to be very wrong - wouldn't be the fuel supply, or the soft reset wouldn't improve fuel pressure loss, the only thing it possibly could be in my mind is a major cat problem - if the soft reset restores the defaults, then the resstrictive cat cause the 02 sensors to lean everything back down (and fast).
I have not had any cat problems whatsoever, so I am not hep on that backend issue - but yes, could be the cause of the major performance loss you describe.
post #34 of 38 (permalink) Old 09-11-2009, 03:58 PM
Quoted: 2 Post(s)
Well my thinking is that if the cats were clogged: restriction after a reset would no go away so power loss would be immediate not gradual
amgalex is offline
post #35 of 38 (permalink) Old 07-13-2017, 04:02 AM
Date registered: Jul 2017
i have the same problem. sometimes the car gives really powerful acceleration but sometimes it's not that much powerful. what is the actual problem?
Razor1 is offline
post #36 of 38 (permalink) Old 03-19-2019, 10:46 PM
Date registered: Mar 2019
Hi guys,
Same sort of issues. I’ve taken a video of before and after my hard reset to show the difference in acceleration but I don’t know how to post them here.
Would appreciate any advice as well thanks.
Steven
Stevenkrash is offline
post #37 of 38 (permalink) Old 04-01-2019, 01:58 PM
Date registered: Aug 2018
Vehicle: 2000 E55 AMG
Just a consideration, but is it possible you have a EVAP/vacuum leak? Have you had a smoke leak test performed?
I ask this because I purchased a new to me 2000 E55 last summer. The car kept on having CEL codes P0170 and P0173. I replaced many, many parts. MAF, spark plugs, breather hoses, vacuum lines, gasket between throttle body and intake manifold, O2 sensors. After all those parts and still getting codes, I took it to a great mechanic with a smoke leak test machine. He hooked it up and you could see faint smoke coming out of the sides of the engine as he pumped smoke into the intake from the MAF. The problem was the gaskets between the intake manifold and the heads were leaking. Replaced the gaskets and no more engine codes. The car ran much better because it could control the fuel trim within parameters.
I don't feel the parts a replaced were a complete waste. I didn't know the history of the car so I consider it maintenance
Best of luck with solving your issue.
Fotoflame is offline
post #38 of 38 (permalink) Old 04-06-2019, 11:51 AM
khomer2's Avatar
Date registered: Nov 2015
Vehicle: w163 02 ML500 W210 97 E50Amg w202 99 C230K w124 - need more space, time to build again
Quoted: 204 Post(s)
Hi Fellas, Razor1, Stevenkrash, Fotoflame,
You do realize the last active post was over 9 years ago.....
Best for you to start a new thread and refer to this old one.
As well, post in the w210 thread may get you a faster response.
khomer2 is offline
  Mercedes-Benz Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
Very Slow Acceleration? Haroundb W123 E,CE,D,CD,TD,TE Class 22 09-07-2007 09:31 PM
slow acceleration cyne wan W126 S,SE,SEC,SEL,SD,SDL Class 9 05-18-2006 12:28 PM
acceleration quite slow elgatoensombrero W123 E,CE,D,CD,TD,TE Class 26 01-11-2006 08:53 AM
slow acceleration... IFILIIIPIDoIN W163 M-Class 2 01-03-2005 03:58 PM
slow acceleration ESTE W163 M-Class 3 07-27-2004 09:28 AM
