E55 Pitfalls - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 11-02-2007, 01:23 PM Thread Starter
Date registered: Jul 2006
E55 Pitfalls
My 300e is recently totaled. I am thinking of buying a 2001 e55 with 27,000 miles. Can you tell me are there any pitfalls/mechanicals specific to the e55 (my 300e needed a wiring harness) that I should be on the look out for? Generally, are there any problems with the cars? What are peoples experiences with the cars as far as maintenance?
Thanks in advance for your candid replies as I am a bit nervous about the purchase.
1gmoney is offline
post #2 of 5 (permalink) Old 11-02-2007, 09:30 PM
ruBENZ_00E55's Avatar
Date registered: Mar 2006
Vehicle: 2000 E55 AMG
The most common pitfalls include: defective MAF sensor, defective motor mounts, defective spring perch, defective instrument cluster pixels, defective rear window motor. Eighteen months ago, I bought my 2000 E55 with 40K on the clock, and have only experienced the MAF sensor and motor mounts issues. You may experience all or none. Nonetheless, an incredible vehicle with a phenomenal 349hp/391torque. Truly a rocket in disguise. Absolutely, no regrets. Good luck.
ruBENZ_00E55 is offline
post #3 of 5 (permalink) Old 11-03-2007, 08:12 AM
Date registered: Oct 2007
I just bought one with 56k miles, and as far as I can tell it has no problems. I love it. I'm probably going to replace the crank pulley as a preventative thing. The rubber in it can come apart from what I've read online.
roybotnik is offline
post #4 of 5 (permalink) Old 11-04-2007, 11:02 PM Thread Starter
Thanks, I am excited to go forward with the purchase. I am going to buy an extended warranty.
Thanks and I will post pics when I get the car.
1gmoney is offline
post #5 of 5 (permalink) Old 11-08-2007, 12:30 PM
Eraser-X's Avatar
Date registered: Jan 2005
Vehicle: 2003 S55
Motor mounts
The motor mouts are about $100 each not that bad a job to replace and they will FAIL!!! So if you want them to last as long as possible use your parking brake to keep the weight of the whole car off of them. I just picked up my 02 E55 and I have no idea how long the passanger side one has been dead but it has pumped out most of its fluid! Before Mercedes went to the fluid filled units the old rubber style ones would last 100K as long as they were not under an oil leak and the driver used there parking brake. On the W140 cars you would have to replace them before you could change the spark plugs most of the time.
Eraser-X
07 R500 Silver/Charcoal, P02
03 S55
2003 Birkin S3 (Track toy)
53 356 Cab
Eraser-X is offline
  Mercedes-Benz Forum > Mercedes-Benz AMG Forums > W210 E50 AMG, E55 AMG
Will 2003 E55 engine fit in a 2000 E55 ieblackguy W210 E50 AMG, E55 AMG 17 11-24-2007 09:52 AM
Difference between '05 E55 and an '05 E55 with the MY06 upgrade perkij W211 E55 AMG, E63 AMG 6 06-06-2007 12:43 PM
Common pitfalls of the e320 JohnnyRnR W210 E-Class 6 05-30-2007 04:59 AM
06 E55 Lease Program vs 04 E55 purchase mrdtail W211 E55 AMG, E63 AMG 0 03-13-2006 05:21 PM
What are the pitfalls of a C36/43 WashMB W202 C36 AMG, C43 AMG 4 06-22-2005 10:13 AM
