99 E300d hard cold starting - Mercedes-Benz Forum
post #1 of 5 (permalink) Old Yesterday, 02:48 PM Thread Starter
Date registered: Jul 2015
Vehicle: 1987 300D W124 Turbo OM603
Quoted: 36 Post(s)
New to me 99 with new injectors, fuel line orings, glow plugs. No codes. Takes a full minute to get started when cold. Local Benz shop said maybe the lift pump is weak or the glow plug relay is timing out too soon? When warm it takes longer than it should to fire. Is there a way to bypass the relay to stay on to test, and also was thinking of adding a helper electric fuel pump. Which one of these lines is the fuel supply?
cropduster is offline
post #2 of 5 (permalink) Old Yesterday, 05:51 PM
SDS Guru
Deplore's Avatar
Date registered: Apr 2014
Vehicle: 1998 MB E300TD, 1997 MB E320
Quoted: 768 Post(s)
How many miles? Do you see air bubbles in the fuel lines?
--1998 MB E300TD 291k
--1997 MB E36 Frankenstein'd AMG 199k
--2011 Suzuki DL650 58k
--1997 MB E320 161k. SOLD...loved that stupid car.
--1997 MB C36 AMG 273k -- stripped and junked
Deplore is online now
post #3 of 5 (permalink) Old Yesterday, 06:01 PM Thread Starter
Quoted: 36 Post(s)
I don’t see bubbles....it’s got 240k miles
post #4 of 5 (permalink) Old Yesterday, 07:54 PM
Kajtek1's Avatar
Quoted: 1999 Post(s)
Originally Posted by cropduster View Post
.... fuel line orings
...I think here is your problem.
New orings on deteriorated plastic groves never had good reliability records.
Rev the engine high (you don't have to worry about overreving as it has governor) and then observe for air bubbles.
Wouldn't hurt to check voltage on glow plugs when you turn the ignition.
Kajtek1 is offline
post #5 of 5 (permalink) Old Today, 02:55 AM
Date registered: Jun 2012
Vehicle: 1998 E320 base sedan @ 160kmiles
Quoted: 1187 Post(s)
Send a message via Skype™ to mrboca
Check the engine coolant temp sensor. You could emulate a cold engine reading by the IFI (the engine computer) with a substitute resistor to get the pre-glow plugs running.
mrboca is online now
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
ScottinBflo
