Electrical Drain 2002 E320 - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 07-25-2019, 04:18 AM Thread Starter
Date registered: Jan 2018
Vehicle: 2002 E320
Question Electrical Drain 2002 E320
Battery drain started at random about a week ago. No problem starting multiple times during the day but when it sits overnight it drains the battery to the point where it will not start.
Battery, starter and alternator checked out well.
Ideas?
Timsawdey is offline
post #2 of 13 (permalink) Old 07-25-2019, 04:37 AM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 911 Post(s)
Your thread belongs in W210 forum.
Trunk light, blower speed regulator, PSE pump. Any water inside vehicle? Wet carpet, wet battery area?
Connect amp meter in series with negative battery cable or use accurate clamp on probe to check amount of current draw.
mrboca likes this.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #3 of 13 (permalink) Old 07-25-2019, 06:22 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 134 Post(s)
There are several videos on youtube that walk you through the procedure of finding a parasitic draw.
Mike
Michael Pillay is offline
post #4 of 13 (permalink) Old 07-25-2019, 10:42 AM
Date registered: Nov 2014
Vehicle: 2000 E 320 Wagon + 2002 ML 500 SUV
Quoted: 161 Post(s)
Indeed!
YT's legendary crazy Scotty Kilmer showed connecting a simple light bulb circuit tester between neg battery terminal & cable - the parasitic draw will illuminate bulb.
Begin pulling fuses or relays one at a time until light goes dark, that identifies problem circuit.
Simple !
Gone, and fondly remembered:
1975 240D - 4 speed manual, power nothing
1984 190E 2.3 - Cute, reliable & slow
1983 300SD - Great highway tourer, 28mpg
Here & greatly appreciated:
2000 E 320 Wagon -
2002 ML 500 - Finally got one !
2000 E 320 White Wagon is online now
post #5 of 13 (permalink) Old 07-25-2019, 12:43 PM
Date registered: Jun 2012
Vehicle: 1998 E320 base sedan @ 160kmiles
Quoted: 1187 Post(s)
Send a message via Skype™ to mrboca
Not so simple.
What Kilmer suggests may be OK for old cars, but the new cars support many circuits per fuse, plus not all circuits are supplied by a fuse (e.g. the blower regulator).
In many cases, the current drain small and is not enough to light a test bulb. Witek's suggestion is a good one. It is always a great idea to find out exactly what the drain current is. It usually leads to possible clues.
There is also voltage drop measurements on each fuse. As each fuse has certain resistance, if certain amount of current flows through the fuse, it will provide a voltage drop in the millivolts range. This is a non-intrusive test, but requires some experience, a decent voltmeter, and knowledge of standard fuse resistances.
BTW: If the car is a 2002 E320 wagon, it belongs to W210, if sedan it is W211.
mrboca is online now
post #6 of 13 (permalink) Old 07-28-2019, 12:32 PM Thread Starter
Vehicle: 2002 E320
Found it!
A 7.5amp fuse under the back seat was drawing 1 amp when everything was off.
Now I need to find a schematic to see what the fuse powers.
Thanks for your help!
post #7 of 13 (permalink) Old 07-28-2019, 01:09 PM
raymond-'s Avatar
Date registered: Jan 2004
Vehicle: 99 E320
Quoted: 214 Post(s)
raymond- is offline
post #8 of 13 (permalink) Old 07-28-2019, 01:28 PM
Two fuses of 7.5 amp value. One is for the CTEL transmitter (fuse 15), the other is for the steering angle sensor module + alarm siren (battery powered): Fuse 11. Typically when the battery goes bad, the siren module has a tendency to draw current. Or, of course, the alarm condition is ON, but the horn with the battery is is bad.
For the CTEL transmitter, there have been cases of disintegrated wiring insulation causing the current draw.
post #9 of 13 (permalink) Old 07-28-2019, 06:19 PM Thread Starter
Vehicle: 2002 E320
The piece of tape indicates the spot where the fuse was.
Name:	E320 Fuse Board.jpg
post #10 of 13 (permalink) Old 07-28-2019, 08:03 PM
E-Call (Tele-aid).
