FRONT window regulator - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 07-11-2019, 02:17 PM Thread Starter
Obuhmyuh's Avatar
Date registered: Jul 2019
I’ve seen several older (unresolved) posts regarding the front window regulator installation. The pelican instruction are awesome, but lack detail to the layman. The only promising video was just the pictures in already confused about, and the stickies contain all the info I’ve already read.
My problem is: getting both arms into the slide rail (at the bottom of the window), whilst having the proper orientation of the regulator to install in place.
Thanks!
Obuhmyuh is offline
post #2 of 15 (permalink) Old 07-11-2019, 02:58 PM Thread Starter
Obuhmyuh's Avatar
Well... just bent them
Obuhmyuh is offline
post #3 of 15 (permalink) Old 07-11-2019, 03:21 PM Thread Starter
Obuhmyuh's Avatar
I have the slides in the rail but cannot rotate the center of the regulator
ID:	2527118   Click image for larger version
Obuhmyuh is offline
post #4 of 15 (permalink) Old 07-11-2019, 08:53 PM
SDS Guru
Deplore's Avatar
Date registered: Apr 2014
Vehicle: 1998 MB E300TD, 1997 MB E320
Quoted: 763 Post(s)
Do the motors work? You'll need to move them until the arm with the gear goes up.
I vaguely remember a car, maybe 202 or 140, with the same geared pivot arm regulator and I remember having to plug in the regulator and play Jenga/Tetris with it in various position to get it out.
--1998 MB E300TD 291k
--1997 MB E36 Frankenstein'd AMG 199k
--2011 Suzuki DL650 58k
--1997 MB E320 161k. SOLD...loved that stupid car.
--1997 MB C36 AMG 273k -- stripped and junked
Deplore is offline
post #5 of 15 (permalink) Old 07-11-2019, 09:39 PM Thread Starter
Obuhmyuh's Avatar
Perhaps a little manipulation of the window position (higher/lower) while moving the arms? I’ll have to get a second set of hands to help me, as it was pretty tough trying to move all those things into position at once without falling entirely. I noticed having it lowered all the way didn’t seem to help at all.
Obuhmyuh is offline
post #6 of 15 (permalink) Old 07-11-2019, 09:43 PM Thread Starter
Obuhmyuh's Avatar
To answer your question, the motor does work. But had a tough time moving the arm/gear assembly with it attached and thought it might be better to do after the regulator is in place. Also, I assumed the motor wouldn’t raise/lower much as I can already move the window/ bottom rail freely
Obuhmyuh is offline
post #7 of 15 (permalink) Old 07-11-2019, 11:05 PM
raymond-'s Avatar
Date registered: Jan 2004
Vehicle: 99 E320
Quoted: 214 Post(s)
many of us are familiar with the rear regulator since it's the one most likely to fail. my
wild ass guess is that the front regulator self destructs about 10% vs 90% in the rear.
so the folks likely to have good firsthand knowledge is going to be fewer. (I'm subscribing
to the thread because I may learn something on the chance I need to replace mine someday)
raymond-
47ļ34'N 122ļ18'W
raymond- is offline
post #8 of 15 (permalink) Old 07-12-2019, 10:47 AM Thread Starter
Obuhmyuh's Avatar
The back is busted on mine as well, but I would prefer both front windows fixed over the rears. They will all be done eventually but I figured I should start up front smh
Obuhmyuh is offline
post #9 of 15 (permalink) Old 07-12-2019, 02:13 PM
Date registered: Jul 2014
Vehicle: 1998 e430
Quoted: 33 Post(s)
Originally Posted by Obuhmyuh View Post
Perhaps a little manipulation of the window position (higher/lower) while moving the arms? Iíll have to get a second set of hands to help me, as it was pretty tough trying to move all those things into position at once without falling entirely. I noticed having it lowered all the way didnít seem to help at all.
If you get the glass in the desired position, tape it in place by using blue painters tape. Run a few strips over the top molding and the outside face of the glass.
southpaw is offline
post #10 of 15 (permalink) Old 07-12-2019, 03:16 PM Thread Starter
Obuhmyuh's Avatar
Been doing that, thanks though! I’m not sure if there’s some combination of the window height relative to the arms in the sliders. I’m under the impression slid all the way the right is most likely the window in the UP position, but could probably use some clarification.
Obuhmyuh is offline
