Steering wheel airbag - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 07-10-2019, 11:46 PM Thread Starter
Mercedesist's Avatar
Date registered: Mar 2017
Vehicle: 1999 Mercedes-Benz E-Class Estate 2.7CDi 125kW
Quoted: 8 Post(s)
Hello!
So, I was planning on removing my steering wheel, because it's worn, to get it refurbished. Watched several tutorials how to do it and it's pretty straight forward - 2 screws, airbag is off and then the center nut for steering wheel.
Everything would be great, except there are no airbag bolts, just empty holes, but the airbag is still holding in it's place. I assume, that in the past some smart people have glued airbag to the steering wheel itself.
Question is - how to get it off and is it even worth it?
ID:	2526998   Click image for larger version
Mercedesist is offline
post #2 of 7 (permalink) Old 07-10-2019, 11:53 PM
Benzyle's Avatar
Date registered: Nov 2013
Vehicle: MY05 CLK55 AMG , MY05 CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
Quoted: 300 Post(s)
Probably you would have to prise ,lever and pull the airbag section away,,,
only you can decide if you want to do it ,,how badly do you want to fix it ?,,
if you do , maybe better to fit a used /replacement wheel which has the bolts in place,,,as far as I know they are captive bolts.
Benzyle is offline
post #3 of 7 (permalink) Old 07-11-2019, 05:52 AM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 890 Post(s)
Bolts for air bag a a lot deeper then your picture. You need 2 inch long T30 Torx bit to reach them.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #4 of 7 (permalink) Old 07-11-2019, 03:12 PM
Benzyle's Avatar
Quoted: 300 Post(s)
Ah yes well spotted witek..M
Yes they are deep in behind the plastic...
Benzyle is offline
post #5 of 7 (permalink) Old 07-12-2019, 02:48 PM Thread Starter
Quoted: 8 Post(s)
Thank you for responses. Turns out there are bolts. Made a toll that works in that small hole and everything unscrews!
post #6 of 7 (permalink) Old 07-12-2019, 07:30 PM
Witek_M's Avatar
Vehicle: 1972
Quoted: 890 Post(s)
So, now that you got your answers it would be nice to document the procedure. Close ups of tools used and such.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #7 of 7 (permalink) Old 07-13-2019, 07:38 AM
Date registered: Mar 2010
Vehicle: 88 560SL - 01 C240 - 02 E320 4matic Wagon
Quoted: 72 Post(s)
I had a few tork screwdrivers and none of them worked. All the thin shaft ones being too short .. all the long ones too thick to fit in the hole.
I went to harbor freight and was able to find a kit that just worked -- once you remove the screws the bag comes off and the connector is behind. I had the battery disconnected and did not reconnect until I had it all together again.
I was taking mine off to replace the multi switch
yeldogt is online now
