Bulb out system detect inside bulbs too ? - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 07-09-2019, 09:10 PM Thread Starter
Date registered: Nov 2014
Vehicle: 2000 E 320 Wagon + 2002 ML 500 SUV
Quoted: 171 Post(s)
...such as front drivers / passenger vanity & map lights ?
I'm hoping not as I'd like to convert our w210 to led interior lights, and would prefer not to have bulb out warnings trigger.
Fwiw, I just converted the highbeam H7 pair away from HID (one had burned out) to H7 LED - 25w per each, and to my pleasant surprise, the Bulb out warning the HID always triggered went away !
So, I'd be curious to know...
thanks, David in East Texas
2000 E 320 White Wagon is offline
post #2 of 7 (permalink) Old 07-10-2019, 07:15 AM
Date registered: Jun 2012
Vehicle: 1998 E320 base sedan @ 160kmiles
Quoted: 1191 Post(s)
Send a message via Skype™ to mrboca
No bulb defective triggers for internal lights. I replaced the dome lights, door courtesy lights, the glove box light, the trunk light with LEDs.
mrboca is online now
post #3 of 7 (permalink) Old 07-10-2019, 10:19 AM Thread Starter
Quoted: 171 Post(s)
Great news thank you.
I just ordered my interior LED's.
Mr Boca, have you tried H7 LEDs for headlamps yet?
Cheers- David
post #4 of 7 (permalink) Old 07-10-2019, 11:23 AM
Not yet.. I am tempted
1) The E320 is not my daily driver. My son uses it for his 8-to-5 job. So he mostly uses his daylight bulbs.
2) I have enough supply of H7 bulbs (4300 Kelvin, so they are whiter than the stock) to keep going for a few years
3) I will wait for the technology to mature a bit. I have read mixed reactions regarding performance. Not sure about longevity yet.
4)Not sure if it will require changes in the rear cover of the stock headlight assemblies.
post #5 of 7 (permalink) Old 07-10-2019, 12:00 PM
pt_700's Avatar
Date registered: Apr 2012
Vehicle: 1998 e430
Quoted: 60 Post(s)
i recently replaced my vanity lights with leds, no problems. i have a kit coming to do the rest of the interior bulbs.
camping trip last weekend made me think i'd like to conserve power there while loading / unloading. along those lines, you can pull the little pin on the trunk light switch plunger out about 1/4" to temporarily (until you close the trunk) keep that light off.
a bit more on some exterior one's to be wary of (& how to get at the vanity bulbs...);
https://www.benzworld.org/forums/w21...l#post17680638
pt_700 is offline
post #6 of 7 (permalink) Old 07-10-2019, 12:50 PM Thread Starter
Quoted: 171 Post(s)
Exclamation Thanks to you both....
Hey PT & mrboca:
I've already got LED's inside ML500, er, w163 and they don't give any 'bulb out' warning. In fact, my 2002 ML doesn't seem to have that feature. Good. It's a stupid idea anyhow !
But, til now I've had partial HID on both MB's with HID low beam & halogen high beam.
On the w210 I have the 2000 year that requires bumper removal to change Drivers side low beam (oh joy...), so it's a hassle on that rig.
The ML, couple screws & out pops the assembly - much easier !
Well, I just tried the new 'fanless' 25w LED H7's on the w210 High Beam, and I all I can say is:
IMPRESSED !!
35% brighter than HID's on the low beam, and far less plumbing junk, wires ballasts, etc. Really just 'plug n play'.
These ones are the 'Beamtech' brand that have a largish heat sink, but no fan and yes they just clear the rear dust cover. There are now available extended dust covers in case some assemblies need more space.
I'll try to grab the link for you.
This matters more to us than others, perhaps, as we travel deer invaded rural FM - 'Farm to Market' rural highways here.
In 12 years, I've made contact with deer 4 times. By the Grace of God, no major damage but lots of smaller hassle & expense.
Latest of which was the w210 lost the radiator due to bent support when I launched over a dead Doe that way laying across my lane.
I had a burned out High Beam bulb, and I was looking down when it happened.
$200 later, the w210 is back with new radiator & un-bent radiator support.
And this is the reason I'm so thrilled at the new LED high beams, so I can see far further to avoid deer or hogs (the other road obstacle !).
Anyhow, I'm planning on trying a pair in the High Beams of the ML500, which like the w210, are now just plain H7 halogens.
Here's the one I installed:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Here's my quick review:
https://www.amazon.com/gp/customer-r...at_pdctrvw_srp
Hope this helps some out.
My wife noted their brightness, which means alot !
Cheers - David
post #7 of 7 (permalink) Old 07-10-2019, 12:58 PM Thread Starter
Quoted: 171 Post(s)
Exclamation
PT,
That's an important safety / convenience point: less chance of a dead battery due to leaving a small inside light on.
The massive amp draw of incandescent or halogen almost guarantee a dead starting battery.
I have 5 children, so you can imagine how many times that happened in our vans over the years !
(they're all older now, so that phase is over...whew...)
I just know it's not always simple. Like on the w163/ ML I re-did all the interior in LED, and then when I tried to do the door bottom / front kick panel ones the system didn't like it, I think they flashed or just didn't illuminate.
Oh well, I just left them with normal bulbs for now.
Hoping to avoid that with the w210, if possible.
Cheers - David
