Yes, another AC thread. - Mercedes-Benz Forum
post #1 of 75 (permalink) Old 06-23-2019, 04:26 PM Thread Starter
Kobus's Avatar
Date registered: Apr 2007
Vehicle: 2001 SLK 320(215K Miles), 2002 E320 Special Edition(182K Miles)
Quoted: 29 Post(s)
Wink Yes, another AC thread.
But don't panic - I've taken all the readings, checked the error codes (no surprises, the normal sun sensor fault), etc.
Basically, the AC on the driver side sometimes only supply lukewarm air instead of cold air like the passenger side. Other times it cools perfectly. Refrigerant pressure (reading 07) varies between 10 and 16 depending on speed. All other readings seem to be normal. The interesting thing is that when the problem occurs, the left heater core temperature is always about 17 degrees higher then right core temperature, even if I set both sides to LO.
My feeling is that the duo valve for the left side is sticking or not closing properly. Any ideas on my diagnosis or any other way I can test my hypothesis before I disassemble the duo valve? I think that if I do disassemble the duo valve, I'll just order this from Amazon for $41.99 - "Heater Valve Repair Kit Compatible with Mercedes-Benz Cars - Set of Heater Repair Parts for Self-Repair - W210, W220, W124, W202". I think if I open it up, I may just as well replace all the rubbers, seals, poppet valves, etc while I have it open.
Your thoughts?
Only two thing are infinite, the universe and human stupidity, and I'm not so sure about the former.
Albert Einstein
Honest politicians are like UFOs. Most people believe that there must be some out there somewhere, but nobody has yet been able to prove their existence.
Kobus is offline
post #2 of 75 (permalink) Old 06-23-2019, 04:53 PM
Date registered: Jun 2012
Vehicle: 1998 E320 base sedan @ 160kmiles
Quoted: 1170 Post(s)
Send a message via Skype™ to mrboca
Sounds like the correct diagnosis. It you clamp the hose to the aux pump, you should have the same readings as you are effectively stopping the hot coolant circulation.
Witek_M likes this.
mrboca is online now
post #3 of 75 (permalink) Old 06-23-2019, 05:00 PM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 885 Post(s)
Clamp off hose from duo valve first. See if that changes readings. Otherwise your refrigerant is low.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #4 of 75 (permalink) Old 06-23-2019, 06:41 PM Thread Starter
Kobus's Avatar
Quoted: 29 Post(s)
Thanks, I'll do the clamping part first. Should I disconnect power to the aux pump to reduce the strain on it with the water circulation blocked?
Albert Einstein
Kobus is offline
post #5 of 75 (permalink) Old 06-23-2019, 06:50 PM
Witek_M's Avatar
Vehicle: 1972
Quoted: 885 Post(s)
Unless you live past north circle. And you are not. Aux pump should not even be on.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #6 of 75 (permalink) Old 06-23-2019, 06:50 PM
No need. When you go LO LO, the aux pump should not be running, and the duo valves should be completely off anyway.
post #7 of 75 (permalink) Old 06-23-2019, 08:11 PM Thread Starter
Kobus's Avatar
Quoted: 29 Post(s)
Thanks. And temperatures in Texas are currently more than 100F higher than the North Pole.
Albert Einstein
Kobus is offline
post #8 of 75 (permalink) Old 06-24-2019, 05:30 AM
Vehicle: 1999 E430; 2005 ML500
Quoted: 106 Post(s)
In Texas summers, your high side pressures should be north of 18 bar, so don’t rule out a refrigerant or compressor issue.
R-134a System Pressure Chart - AC Pro<?php/* bloginfo('name'); */?>
Hirnbeiss is offline
post #9 of 75 (permalink) Old 06-24-2019, 08:43 AM Thread Starter
Kobus's Avatar
Quoted: 29 Post(s)
Originally Posted by Hirnbeiss View Post
In Texas summers, your high side pressures should be north of 18 bar, so donít rule out a refrigerant or compressor issue.
Thanks, something else to consider. I'll first try the duovalve test to eliminate possible problems there.
Albert Einstein
Kobus is offline
post #10 of 75 (permalink) Old 06-24-2019, 10:37 PM
Kajtek1's Avatar
Quoted: 1976 Post(s)
When MB never reports recommended high pressures, the high limit is 32 bars, just for referral.
yours max is 16.
Do the math.
Kajtek1 is offline
