"<20> <80>" - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 06-22-2019, 03:28 PM Thread Starter
Date registered: Sep 2012
Vehicle: '95 S500 (sold), '97 E420
Quoted: 6 Post(s)
"<20> <80>"
The temperature markings on the transmission dipstick. Is that the temp shown on the gauge in the instrument cluster, or the actual tranny temp? While the engine temp is showing 80, the fluid level on the tranny dipstick is just above the high mark for 20, but nowhere near the low mark for 80.
I have the "sealed for life" tranny, (I forget the model number, 722. something)
Thanx,
Shorty.
"If you set out to fail, and succeed, which have you done?"
bluerooster is offline
post #2 of 9 (permalink) Old 06-22-2019, 03:46 PM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 878 Post(s)
It is actual fluid temperature. Measured with infrared temp gauge or retrieved using MB scan tool.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #3 of 9 (permalink) Old 06-22-2019, 03:50 PM Thread Starter
Quoted: 6 Post(s)
OK thanx. I guess it may well be in parameter then. What a PITA. What keeps it from cooling between dipping and measuring temp? Other than hooking up the scan tool every time I want to check fluid level, I guess it's just "poke and hope" or do it cold?
Thanx,
Shorty.
post #4 of 9 (permalink) Old 06-22-2019, 05:12 PM
Witek_M's Avatar
Vehicle: 1972
Quoted: 878 Post(s)
No, it is not poke and hope. Measure pan temperature with gauge.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #5 of 9 (permalink) Old 06-22-2019, 09:50 PM
Kajtek1's Avatar
Quoted: 1975 Post(s)
First confirm what transmission you have.
If you have factory dipstick that means you have 4sp transmission who required often fluid changes.
The newer 5G transmission never had dipstick on the car and you have to use shop dipstick to check the level.
When 20C marks are for initial fill after servicing, the 80C marks are for proper confirmation of the level.
Kajtek1 is offline
post #6 of 9 (permalink) Old 06-22-2019, 11:03 PM
Benzyle's Avatar
Date registered: Nov 2013
Vehicle: MY05 CLK55 AMG , MY05 CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
Quoted: 294 Post(s)
The 20 degree section is for initial check only , ,,,the correct check is done at 80 degrees,,,engine running , car in Park after shifting through all gears for 5 seconds.
Drive your car for at least 12 miles in suburban setting ,,and the temp will be at 80 ,,,come back ,park level and do the fluid level check as per the method above...aim for the upper half of the 80 degree section ,,add no more than 100 ml at a time to avoid overfilling.
Benzyle is offline
post #7 of 9 (permalink) Old 06-24-2019, 04:50 PM Thread Starter
Quoted: 6 Post(s)
No factory dipstick, just a cap, with a locking device. Have the dipstick "tool" from Autohaus.
Thanx,
Shorty.
post #8 of 9 (permalink) Old 06-24-2019, 04:51 PM Thread Starter
Quoted: 6 Post(s)
Thanx, that's what I needed to know.
Benzyle likes this.
Thanx,
Shorty.
post #9 of 9 (permalink) Old 06-24-2019, 09:31 PM
Benzyle's Avatar
Quoted: 294 Post(s)
So you have 722.6 5 speed transmission ,,,
btw ,,sealed for life ,,,doesn't work very well ,,they need regular fluid and filter changes if you want it to perform for a long time. Also replace the electrical connector bushing.
Benzyle is offline
