Engine randomly dies with easy restart. - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 06-17-2019, 06:28 PM Thread Starter
Date registered: Jul 2008
Vehicle: 2001 E320
When my wife drives the E320 it usually dies. Sometimes it dies in the driveway. Sometimes it dies while merging into traffic or coasting down a hill. It always starts right up.
No codes.
No check engine light.
I resoldered the K40 relay board and thought it was fixed and thought I was a genius. But no, I am not a genius, it died again.
So I bought and installed a NEW K40 relay module. Thought it was fixed. Nope. I drove it trouble free for three days. She jumps in and can't even get out of the driveway.
It has new tires, new accessories, new ac...new steering rack, new conductor board in trans, new bushings everywhere... POS ! My old dodge omni is more reliable any day.
I would think fuel problem but it does not have classic fuel issue failure mode. Lots of power. I'm going to try changing the fuel filter next if I can find it.
Any ideas anyone?
1999 E320, 2000 E320, Southeast USA
TurboTom is offline
post #2 of 5 (permalink) Old 06-17-2019, 07:02 PM Thread Starter
Vehicle: 2001 E320
OK I read the stickies -- time to start throwing more parts at it.
I'll put in a crank position sensor first.
Sorry for the redundant post for such a common problem.
ugh.
Deplore likes this.
TurboTom is offline
post #3 of 5 (permalink) Old 06-17-2019, 09:37 PM
khomer2's Avatar
Date registered: Nov 2015
Vehicle: w163 02 ML500 W210 97 E50Amg w202 99 C230K w124 - need more space, time to build again
Quoted: 269 Post(s)
ugh.
I wish I had deep pockets....
Maybe throw some of that money into a decent scanner, read any saved codes and post them here.
khomer2 is offline
post #4 of 5 (permalink) Old 06-18-2019, 06:14 AM
Date registered: Jun 2012
Vehicle: 1998 E320 base sedan @ 160kmiles
Quoted: 1170 Post(s)
Send a message via Skype™ to mrboca
Does the engine die when the car is standstill and you depress the gas pedal to go wide open throttle ?
It does not sound like a typical bad CPS issue, but hey, it is around $30 (get a Bosch or OEM).
Do you have this problem when the engine is cold ? warmed up ? Have you checked your coolant temp sensor reading to see if it is plausible ?
mrboca is offline
post #5 of 5 (permalink) Old 06-18-2019, 07:36 AM
nugent's Avatar
Date registered: Jul 2005
Vehicle: 2008 E350 110k, 2000 E320 143k, 1983 380SEC 240k
Quoted: 119 Post(s)
MAF? You can try cleaning it. Or simply unplug it and see what happens.
Strange that there are no codes, pending or otherwise.
nugent is offline
