1996 e320: A/C warm at high speed and cold at idle - Page 3 - Mercedes-Benz Forum
post #21 of 25 (permalink) Old 06-18-2019, 09:31 PM
Kajtek1's Avatar
Quoted: 1980 Post(s)
I disagree what mrboca sees in his crystal ball.
Evaporator at 10C= 45F is clear evidence that the compressor is running and cooling.
I think Witek's crystal ball is way better as it has a point, but again, lack of spending 90 seconds for proper troubleshooting opens the way for a book of guessing.
Kajtek1 is offline
post #22 of 25 (permalink) Old 06-19-2019, 07:59 PM Thread Starter
Jason4758's Avatar
Date registered: Jul 2017
Vehicle: 1993 300TE VIN: WBDEA92E7PF248963
Quoted: 37 Post(s)
I completed the diagnostic exactly as recommended and here are the codes.
Eb1 226
Eb1 232
Eb1 234
e ff
Based on what I can find, I understand this to mean that the issue is the Refrigerant Pressure Sensor? (And also the in-car temp sensor, and sun sensor?)
I am not sure what the e/ff message means
Thank you all for your help!
Jason4758 is offline
post #23 of 25 (permalink) Old 06-19-2019, 08:05 PM
Date registered: Jun 2012
Vehicle: 1998 E320 base sedan @ 160kmiles
Quoted: 1170 Post(s)
Send a message via Skype™ to mrboca
Reset the codes per item 9 in the instructions (press and hold both AUTO keys till it resets to ff)
e ff means end of the list. If the faults clear and do not come back (do the test again), then the faults are likely transient.
If the faults persist, get them ( refrigerant pressure sensor and the in car temp sensor) changed. Sun sensor does not really matter much.
Jason4758 likes this.
mrboca is offline
post #24 of 25 (permalink) Old 06-19-2019, 08:18 PM
As I said ALWAYS start with the fault codes, if you have a fault in the refrigerant pressure sensor or the refrigerant temp sensor, this is detected by the controller.
When the controller starts compressor, it checks changes (increase) in the refrigerant pressure and temp readings. If it does not see plausible values, it will declare that the appropriate sensor is faulty.
mrboca is offline
post #25 of 25 (permalink) Old 06-19-2019, 08:20 PM Thread Starter
Jason4758's Avatar
Quoted: 37 Post(s)
Thank you. I appreciate your help!
