name of this part? - Mercedes-Benz Forum
post #1 of 20 (permalink) Old 06-14-2019, 12:27 PM Thread Starter
Tiha4's Avatar
Date registered: May 2019
Vehicle: 1997 E200 kompressor
name of this part?
guys what is this metal part on the air filter box name of it and what does it do if you can tell me thanks
ID:	2520254   Click image for larger version
ID:	2520256   Click image for larger version
Tiha4 is offline
post #2 of 20 (permalink) Old 06-14-2019, 01:37 PM
Date registered: Jun 2012
Vehicle: 1998 E320 base sedan @ 160kmiles
Quoted: 1191 Post(s)
Send a message via Skype™ to mrboca
M16/7 Recirculating air flap actuator. It is to do with your supercharge function.
What is the problem ? error codes?
mrboca is online now
post #3 of 20 (permalink) Old 06-14-2019, 03:28 PM Thread Starter
Tiha4's Avatar
if bad can i have loss of power? cuz i dont feel like the car is fast for the 183 horsepower it has
Tiha4 is offline
post #4 of 20 (permalink) Old 06-14-2019, 03:57 PM
khomer2's Avatar
Date registered: Nov 2015
Vehicle: w163 02 ML500 W210 97 E50Amg w202 99 C230K w124 - need more space, time to build again
Quoted: 306 Post(s)
Have you scanned of any saved codes?
That would be one of the first (several) things I would do instead of using a guessing/ feely approach.
khomer2 is offline
post #5 of 20 (permalink) Old 06-14-2019, 05:35 PM
Yes.
If the valve is not closed or partially closed (under the control of the ECU) you will not get the adequate boost pressure when you accelerate.
post #6 of 20 (permalink) Old 06-15-2019, 07:44 AM Thread Starter
Tiha4's Avatar
no error codes because in my country no one has a good computer for checking error codes they all have a trial version and that doesnt do the job it doesnt show small error codes ill see what i can do to check that Recirculating air flap actuator thanks.
Tiha4 is offline
post #7 of 20 (permalink) Old 06-15-2019, 09:52 AM
You can remove it and check it the flap moves with closed throttle and the wide open throttle. It may be stuck.
post #8 of 20 (permalink) Old 06-15-2019, 10:07 AM Thread Starter
Tiha4's Avatar
i took it out tried with my fingers i pushed the flap moves but when i started the car pressed the throttle it didnt move not even on 4000 rpm flap does not move. when i shut of the car it moved up a millimeter very little what can it be what should i change? thanks at idle aswell it doesnt move
Tiha4 is offline
post #9 of 20 (permalink) Old 06-15-2019, 10:16 AM
Perform the test in item 37. You need to test the voltage across the flap actuator at closed throttle and full throttle WITH the engine running.
STAR TekInfo
pt_700 and Tiha4 like this.
post #10 of 20 (permalink) Old 06-15-2019, 10:24 AM Thread Starter
Tiha4's Avatar
thanks for the help you are gonna make me a mechanic ill test the wiring and the n3/10 thanks agein
Tiha4 is offline
