A/C compressor problem... - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 05-22-2019, 07:54 PM Thread Starter
Doni's Avatar
Date registered: Nov 2008
Vehicle: Vogon constructor fleet.
Quoted: 2184 Post(s)
I don't know if this is a dumb question or not ...BUT is there a control module or relay that powers up the AC compressor? I recharged the system (just like I've done every summer for the past three years) but the compressor isn't kicking in....nor are the aux fans. As far as I can tell, I'm not getting power to them OR the compressor itself..
Is the entire AC system operation in the climate control head in the dash or is there are separate relay/module/fuse somewhere I can't seem to locate?
Please get back to me before it gets really "summery." Thanks in advance, guys!
Pecuniam Habere Nobis Necesse Est...
Doni is offline
post #2 of 8 (permalink) Old 05-22-2019, 08:26 PM
Date registered: Sep 2016
Vehicle: 2002 E55 AMG Sedan
Quoted: 270 Post(s)
Scan for error codes in the climate control.
Turn the ignition on. Put the driver side to HI and passenger side to LO. Then press and hold the EC button and the REST button at the same time and wait for the screen to change. You have to do this within 15 seconds of turning the ignition on, otherwise the screen won't change.
After the screen changes you will see eb1 on the left and a number on the right. Press the Auto button to scroll through all the error codes. After you scrolled through all codes you need to erase them, do this by pressing both AUTO buttons at the same time. The screen should then show e FF. Turn the ignition off and back on again and re-scanning for codes.
Post the codes that you see during the first test and then post the codes that show up again (if any) during the second test.
Doni, southpaw and khomer2 like this.
illstplaya is offline
post #3 of 8 (permalink) Old 05-23-2019, 09:20 AM
Date registered: Jun 2012
Vehicle: 1998 E320 base sedan @ 160kmiles
Quoted: 1141 Post(s)
Send a message via Skype™ to mrboca
To answer your question, no, there is no compressor relay that switches the compressor on and off per cooling demand (old design). The compressor is controlled by the head unit (the controller), and it is turned on whenever the EC button LED is not "red". It is supposed to run continuously.
What was the cooling condition before you recharged the system ? partially cooling ? or not cooling at all ?
Obviously, the compressor was running when you were recharging, else it would be very hard to "feed" the refrigerant.
Look for the fault codes and clear them as described.
How much refrigerant did you put into the system ?
mrboca is online now
post #4 of 8 (permalink) Old 05-23-2019, 09:48 AM
Kajtek1's Avatar
Quoted: 1961 Post(s)
In the time you spend on starting forum topic, you could do proper troubleshooting.
Link to procedure in stickies.
Kajtek1 is offline
post #5 of 8 (permalink) Old 06-05-2019, 06:44 AM Thread Starter
Doni's Avatar
Okay.....I think I did this right. The "codes" I noted are as follows:
231
232
233
234
235
422
459
I also pulled down quite a few secondary numbers but I don't know if they're "trouble codes" or system reading/levels.
1-91
2-73
3-107
4-109
5-147
6-152
7-00
8-75
9-27
10-0.8
11-2.6
12-3.7
20-3.2
21-32
22-00
23-32
24-11.6
40-164
41-32
42-76
43-152
I've been driving my W140 lately so the W210's AC hasn't been an issue ....but I would like to get it working again just in case I need the car on a hot day.
Thanks in advance for any guidance you guys can give me!!
Doni is offline
post #6 of 8 (permalink) Old 06-05-2019, 07:26 AM
reset each code from the diagnostic menu, by pressing both auto keys .
see the instructions in STEP 9 of the attached.
STAR TekInfo
Then come back and re-post the codes that do not clear.
You have no refrigerant in the system (at least that is what the second set of figures say). Then again you have a refrigerant pressure sensor fault. After clearing the codes, do the sensor tests again (second set of tests).
Your evap. core temp seems to be a bit out of wack. Not even good enough for Magrathea
post #7 of 8 (permalink) Old 06-05-2019, 03:53 PM Thread Starter
Doni's Avatar
LOL!!
Okay, Zaphod. I’ll run them again!
Doni is offline
post #8 of 8 (permalink) Old 06-05-2019, 04:11 PM
LOL!!
Okay, Zaphod. Iíll run them again!
I believe Trump has been called that
Doni likes this.
