a/c blowing cold on passenger side only - Mercedes-Benz Forum
post #1 of 29 (permalink) Old 05-19-2019, 10:38 AM Thread Starter
Date registered: May 2018
Vehicle: 1999 E320
Quoted: 16 Post(s)
I have an 1999 E320 with about 64K miles.
a/c is cold on the passenger side only.
I would appreciate your help.
I couldn't find what "normal" values are.
what is also interesting is that when I search for the topic I put in on the forum, it tells me nothing is there or the words are too long, etc. I change wording around and still get the same problem. I google it and then find somethings on the forum
Codes with engine OFF:
1-86
2-82
3-89
4-85
5-87
6-98
7-05
8-82
9-27
10-5.7
11-0.3
12-4.3
20-3.2
21-32
22-00
23-32
24-11.4
40-164
41-85
42-104
43-136
Error codes:
eb 1235
cleared it and then no error codes
Codes with engine ON:
1-85
2-82
3-89
4-80
5-93
6-182
7-08
8-100
9-31
10-2.3
11-0.8
12-4.3
20-3.2
21-42
22-00
23-32
24-13.3
40-164
41-85
42-104
43-136
No error codes
I did the flap test but honestly I couldn't tell any difference or that sound
Thanks!!
shadypa is offline
post #2 of 29 (permalink) Old 05-19-2019, 10:58 AM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 829 Post(s)
Originally Posted by shadypa View Post
1-85
2-82
3-89
4-80
5-93
6-182
7-08
Second set of values with engine on. Is compressor running and right side cooling?
1-85
2-82
3-89
4-80
5-93 Evaporator temp too high. Should be ~40
6-182
7-08 Refrigerant pressure too low. Should be 12-14 bar.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #3 of 29 (permalink) Old 05-19-2019, 11:01 AM
Date registered: Jun 2012
Vehicle: 1998 E320 base sedan @ 160kmiles
Quoted: 1141 Post(s)
Send a message via Skype™ to mrboca
Put a can of R134a, and then test it again.
mrboca is online now
post #4 of 29 (permalink) Old 05-19-2019, 11:07 AM Thread Starter
Vehicle: 1999 E320
Quoted: 16 Post(s)
Thanks for your quick response!
Yes, the right side is cooling while the engine is running so I assume the compressor is running. When my wife is driving, she has the passenger vents facing her towards her as much as possible
What do I do about the below?
It doesn't make sense to me why it would be cold only on one side.
shadypa is offline
post #5 of 29 (permalink) Old 05-19-2019, 11:15 AM
Some people have some conspiracy theories that the Germans are trying to penalize you, the driver, (not your innocent wife), by not taking care of your air conditioning system
The expansion valve is closer to the passenger side of the evaporator. If you have insufficient refrigerant, by the time it gets to your side, it has already turned to gas from liquid. So, not much to cool your side.
post #6 of 29 (permalink) Old 05-19-2019, 11:15 AM Thread Starter
Vehicle: 1999 E320
Quoted: 16 Post(s)
Please excuse my ignorance.
Any particular brand?
links as to how to do it properly? I found this one, good?: You are being redirected...
Is there is a leak since it is low?
Thanks!!
shadypa is offline
post #7 of 29 (permalink) Old 05-19-2019, 11:16 AM
Witek_M's Avatar
Vehicle: 1972
Quoted: 829 Post(s)
For a/c to cool well evaporator has to be flooded with liquid refrigerant. Your system is low therefore only right side has liquid. If you run blower on low you will hear hissing coming from center of the dash.
If you are brave shoot a can in it. Otherwise have it recovered evacuated and recharged with ounce of oil dye mix and 1000 grams of R134A.
mrboca likes this.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #8 of 29 (permalink) Old 05-19-2019, 11:24 AM
Kajtek1's Avatar
Quoted: 1961 Post(s)
The first measurements seem to be done with engine warm, so it is useless for sensor calibration test.
The 2nd test is not saying what stage of engine running it is on, so impossible to tell what happen to the compressor.
Repeat measurements 1st thing in the morning with engine off and before car temp can be affected by sunshine.
2nd test should be done on hot car just seconds after engine start. Point is to get the computer at moment when it calls for max AC output.
Best yet, when you come to hot car, start with displaying #7 pressure value, then start the engine and observe changes.
5 bars static refrigerant pressure should still get compressor running.
Kajtek1 is offline
post #9 of 29 (permalink) Old 05-19-2019, 11:38 AM Thread Starter
Vehicle: 1999 E320
Quoted: 16 Post(s)
First measurements were done in my garage about 6 hours after she drove it. I live in Houston.
Second measurements were done immediately after I did the first with the car running.
I don't understand "what stage of engine running."
Remember, I'm ignorant, can't you tell?
Does "when you come to hot car, start with displaying #7 pressure value, then start the engine and observe changes" mean that after the car has been running for a while, turned off for a few minutes? or does it mean to leave the car outside in the sun and check it?
shadypa is offline
post #10 of 29 (permalink) Old 05-19-2019, 12:00 PM
Witek_M's Avatar
Vehicle: 1972
Quoted: 829 Post(s)
Porpoise of first check is to spot temp sensor that has drifted in value. Values of 1-6 should be equal +/- 2 degrees. That's why it is best done after overnight rest.
Value #7 will be highest with hot engine/hot interior few minutes after compressor engages. Electric condenser fans will be running on high. Of course that applies to properly charged and functioning system.
mrboca likes this.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
A/C BLOWS COLD AIR ONLY PASSENGER SIDE pery W210 E-Class 1 09-24-2015 01:45 PM
Air con blowing cold on one side, warm on the other? 99E430 W210 E-Class 31 09-03-2011 08:16 PM
A/C vent blowing hot and cold air angelousoul W210 E-Class 4 08-28-2011 11:34 AM
A/C was cold, stopped for gas, then A/C was blowing hot air. 86560sel W126 S,SE,SEC,SEL,SD,SDL Class 7 06-08-2011 06:49 PM
Weird A/C Issue and fixed the other problem with it not blowing cold... mclare W126 S,SE,SEC,SEL,SD,SDL Class 11 07-21-2009 09:49 PM
