2001 E430 opinions needed - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 05-16-2019, 01:27 PM Thread Starter
Date registered: May 2019
I have a 2001 E430, that about 2 weeks ago i paid about $1500 to have the conductor plate replaced, & new map sensor put in. A few days ago i was driving the car when it appeared to go into limp mode again, resulting in me being stuck at a light for about 30 mins til it decided it wanted to move. Had the car towed back to my local repair place. I have my own code reader, & it shows these codes: P0130 (O2 SENSOR BAD), & P0700(TRASNMISSION CONTROL SYSTEM). The guy at the repair shop called me today & said it needs some transmission work that could be anywhere from $2000-$4000.
What I would like to know from ya'll is if it is worth repairing the car at almost 200k miles or putting that money towards another used car under $10k. My fear is that i have the car's transmission repaired & something else breaks, or that i spend 10k max on a used benz & the car give me similar problems with weeks/month/years. Please share your thoughts, Thanks.
vetteguy777 is offline
post #2 of 7 (permalink) Old 05-17-2019, 11:36 AM
DrX
DrX's Avatar
Date registered: Aug 2006
Vehicle: 2002 ML320, 2003 A160, 2002 ML500, 2018 GLS350d
Quoted: 649 Post(s)
Ask him exactly what the codes are, from the ETC module (also known as TCM). If there is P0700, then there must be a corresponding 3-digit fault code that only a pro-level scanner can extract from the trans control system.
If it had transmission work just 2 weeks ago, return it to the workshop who changed the conductor plate. They probably overfilled the gearbox with trans fluid.
(wrong forum)
DrX is offline
post #3 of 7 (permalink) Old 05-17-2019, 11:46 AM Thread Starter
the three digit code is "146", then says the transmission has sporadically an impermissible transmission ratio. He referred me to a transmission shop. is that necessary? or is it the overfilled gearbox?
post #4 of 7 (permalink) Old 05-17-2019, 11:48 AM Thread Starter
I forgot to mention that he said that he "cleared the code, which makes the car drive able, i assume till the code pops back up, & he told me that i could keep driving the car, just to clear the code with my reader the next time it came up... makes me think it's an electrical or ecu issue. I drove the car home from the repair shop about an hr ago with no hiccups thankfully.
post #5 of 7 (permalink) Old 05-17-2019, 01:14 PM
DrX
DrX's Avatar
Quoted: 649 Post(s)
For code 146, it was probably incorrect ATF level after the trans pan drop/refill. See the table under Figure 1 at “050 146 P0700”: STAR TekInfo
That lists potential causes as ATF level, wiring harness, and incorrectly reassembled piston B2/B3 guide (screws loose/missing), all of which sound fixable for under $2000. 🤔
Your basic code reader can’t clear code 146, but it can clear P0700. Might not get it out of limp mode. You can limp back to his shop to clear the ETC module.
DrX is offline
post #6 of 7 (permalink) Old 05-22-2019, 12:23 PM Thread Starter
Just a quick update, the guy at the transmission shop called me today to tell me that nothing is wrong with the car...so I fear that I will be driving the car with my kid or something & It goes into limp mode or stalls or whatever.
post #7 of 7 (permalink) Old 05-23-2019, 08:39 PM
Date registered: Sep 2016
Vehicle: 2002 E55 AMG Sedan
Quoted: 270 Post(s)
You overpaid for the conductor plate replacement and map sensor.
When you had the conductor plate replaced, do you know what brand part was used? Also was the pilot bushing/electrical connector that always leaks replaced? I would also check your TCM for transmission fluid to see if there is any fluid in there which can cause issues. I would also check the fluid level.
illstplaya is offline
Help needed to get my 2001 clk convertible started dan84v General Mercedes-Benz 0 04-15-2013 01:52 PM
What is fair price to pay for 2001 e430 Taylors 420 W210 E-Class 5 08-11-2011 11:15 AM
2001 E430 Sport Rim spawnx1 W210 E-Class 6 05-13-2011 10:47 AM
10 Best Cars of the Past Decade Nightbird Off-Topic 2 12-30-2010 12:54 PM
2001 E430 Time to Sell? Opinions.... chino26 W210 E-Class 8 07-25-2010 04:26 PM
