Instrument Cluster Pixel - 2001 W210 E-320 Station Wagon - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 05-15-2019, 07:41 AM Thread Starter
Date registered: Nov 2005
Vehicle: 1997 E-420, 2001 E-320, 2007 S-550, 2009 E-350
Quoted: 26 Post(s)
Send a message via Yahoo to hadam
Hi all, I have 2001 W210 E-320 Station Wagon. Recently the pixel on instrument cluster where you see the outside temperature are not showing the correct temperature.
I will be taking IC off this weekend for other troubleshooting. I wanted to do a easy quick temporary fix.
I found this on YouTube. I like to perform this on IC only for the outside temperature.
Has any one done this and how long this remedy lasted?
Thanks in advance for your support.
ID:	2512706   Click image for larger version
2001 MB E-430 - 150K Miles Gone- Totaled
2009 MB E-350 - 107K Miles
2001 MB E-320 - 164K Miles
2003 MB CLK-320 Cabriolet - 126K Miles
1997 MB E-420 - 157K Miles
2007 MB S-550 - 140K Miles
2011 MB G-550 - 90K Miles
hadam is offline
post #2 of 4 (permalink) Old 05-15-2019, 08:22 AM
Date registered: Jun 2012
Vehicle: 1998 E320 base sedan @ 160kmiles
Quoted: 1111 Post(s)
Send a message via Skype™ to mrboca
It may work for a while, but if you want a better solution and have steady hands, and mechanical skills, you may consider the replacement of the ribbon cable.
AK speedo
They also have a Youtube video on how to do it.
mrboca is online now
post #3 of 4 (permalink) Old 05-18-2019, 04:23 PM Thread Starter
Quoted: 26 Post(s)
mrboca, some update. I went easy way by adding some foam between the ribbon cable and factory pad on display in IC.
All good it is working fine. I just did the ambient temperature display, I did not do the time/gear shifter, may be next time.
It was Easy peasy job. Took me 1 hour from time to remove the IC from car and then working on IC plus re installing in car. Quite easy. Next I will do ambient temperature on my W208 2003 CLK-320, my summer baby.
Below are the photos.
ID:	2513834   Click image for larger version
ID:	2513836   Click image for larger version
ID:	2513838   Click image for larger version
ID:	2513840   Click image for larger version
ID:	2513844   Click image for larger version
ID:	2513846   Click image for larger version
ID:	2513848   Click image for larger version
ID:	2513850   Click image for larger version
hadam is offline
post #4 of 4 (permalink) Old 05-18-2019, 04:26 PM Thread Starter
Quoted: 26 Post(s)
Some more photos.
ID:	2513854   Click image for larger version
ID:	2513856   Click image for larger version
ID:	2513858   Click image for larger version
ID:	2513860   Click image for larger version
ID:	2513864   Click image for larger version
ID:	2513866   Click image for larger version
hadam is offline
W638 instrument cluster swap - 14" to 15" tyres & tools to reprogram speedo ratio Thirsty V-Class 0 05-07-2019 09:53 AM
FS: parting out several 98,99,00,01 ML's sc_mopar For Sale/Wanted/Trade/Giveaway 1 01-21-2016 01:06 AM
WANTED: Instrument Cluster for W210 E320 cqhall For Sale/Wanted/Trade/Giveaway 4 01-27-2007 12:13 AM
wanted w210 wagon instrument cluster nihilo For Sale/Wanted/Trade/Giveaway 0 04-26-2005 07:57 PM
from 2001 vette to 2002 320 wagon Guest (MBNZ) W203 C-Class 2 08-08-2001 09:55 AM
