Misfire after downshift - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 05-06-2019, 06:19 PM Thread Starter
tuttebenne's Avatar
Date registered: Jul 2005
Vehicle: W124
Quoted: 474 Post(s)
2000 e320 This is now the second time this has happened. First was a routine downshift upon acceleration a year ago. A misfire immediately developed and CEL. Pulled over and restarted, misfire gone and CEL needed to be cleared. Had a "misfire on cylinder 3" code. Today, I I must have bumped the shifter into manual mode and the trans was in 4th at around 40mph. Slapped the shifter but in the "-" direction by mistake which caused a downshift and the same thing, misfire. It cleared on restart but CEL with "misfire on cylinder 4" code had to be cleared. Any ideas what to look for?
'93 400E
'93 500E
'94 E320TE
'00 E320
'02 E320
'73 Alfa GTV
'77 308GTB
tuttebenne is offline
post #2 of 8 (permalink) Old 05-06-2019, 06:49 PM
Date registered: Jun 2012
Vehicle: 1998 E320 base sedan @ 160kmiles
Quoted: 1142 Post(s)
Send a message via Skype™ to mrboca
Was any recent work done on the car ?
Have you run the fuel down to minimum before filling up ?
Do you think it could be bad fuel ?
Since it is a travelling misfire (cylinder 3, cylinder 4 if I understood it correctly), it is unlikely spark issue.
Does the CEL flash ?
mrboca is online now
post #3 of 8 (permalink) Old 05-06-2019, 06:58 PM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 834 Post(s)
Codes that have set have freeze frame data. What is it?
What is your current STFT and LTFT?
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #4 of 8 (permalink) Old 05-07-2019, 07:34 PM Thread Starter
tuttebenne's Avatar
Vehicle: W124
Quoted: 474 Post(s)
Only work ever done to this car over the last three years is one coil pack, two cats, refrigerant top up and four tires. The CEL is hard on, not flashing until the code is cleared.
'93 400E
'93 500E
'94 E320TE
'00 E320
'02 E320
'73 Alfa GTV
'77 308GTB
post #5 of 8 (permalink) Old 05-07-2019, 07:43 PM Thread Starter
tuttebenne's Avatar
Vehicle: W124
Quoted: 474 Post(s)
Can I get the freeze frame data if the code has been cleared? If so, any clues how to? As for STFT and LTFT, sorry I don't even know what those acronyms are for.
'93 400E
'93 500E
'94 E320TE
'00 E320
'02 E320
'73 Alfa GTV
'77 308GTB
post #6 of 8 (permalink) Old 05-08-2019, 03:58 AM
Witek_M's Avatar
Vehicle: 1972
Quoted: 834 Post(s)
No you cannot. Most scanners warn that clearing fault will clear freeze frame data as well.
I have pending code P0400 "EGR Flow Malfunction" Here is freeze frame from that event.
Freeze frame report generated by Torque for Android
Vehicle VIN: Not present
Vehicle Manufacturer: Unknown
Vehicle Calibration ID: Not present
Freeze frame information:
Fuel Status = 0 byte
Engine Load = 10.98 %
Engine Coolant Temperature = 82 C
Fuel Trim Bank 1 Short Term = 0 %
Fuel Trim Bank 1 Long Term = 0.781 %
Fuel Trim Bank 2 Short Term = 0 %
Fuel Trim Bank 2 Long Term = 1.562 %
Intake Manifold Pressure = 29 kpa
Engine RPM = 1,375 rpm
Speed (OBD) = 39.768 mph
End of report.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #7 of 8 (permalink) Old 05-08-2019, 05:40 AM
Which coil pack ? The one for the cylinder that misfired in the past ?
Cylinder 3 is located closest to the firewall, and cylinder 4 is closest to the front at the opposite bank. Which makes me think it is a fuel demand issue (when you accelerate). Has the fuel filter been replaced at all ?
You may try a fuel system cleaner. It may help for some time, but if the fuel filter is plugged up, the only remedy is to replace it.
It may also be an air intake issue. Make sure that the air filter is clean.
post #8 of 8 (permalink) Old 05-08-2019, 08:13 PM Thread Starter
tuttebenne's Avatar
Vehicle: W124
Quoted: 474 Post(s)
Thanks. I will put the fuel filter on the list of things to do. As for the coil pack that had failed, yes I think it was three. I installed a new, from the dealer MB genuine coil pack and plug wires. I'll re check my work and make sure the connector is not loose.
'93 400E
'93 500E
'94 E320TE
'00 E320
'02 E320
'73 Alfa GTV
'77 308GTB
SL500 Misfire/rough idle mystery. Cudavanti R129 SL-Class 111 11-23-2015 01:58 PM
ML350 06 164 272 110k dcallen25 W164 M-Class 4 01-09-2014 05:44 PM
Rough Idle or Misfire In Gear and Hard Start mannys9130 W201 190-Class 26 02-09-2012 10:35 AM
Misfire at/around idle despite everything! Nick-V R129 SL-Class 24 12-29-2009 07:42 AM
Help with engine misfire codes johnny63ml320 W163 M-Class 15 11-14-2006 05:52 PM
