How advanced is AC Compressor Clutch replacement? - Mercedes-Benz Forum
post #1 of 31 (permalink) Old 04-25-2019, 09:30 AM Thread Starter
Date registered: Jun 2011
Vehicle: 1998 E320 Sedan RWD 150k mi
Quoted: 23 Post(s)
AC blowing warm, got code 419 (ac clutch I guess), and best quote so far for the compressor+drier is 830. Just wondering how hard it would be to do it or part of it myself (only done the blower motor and aux water pump so not a lot of wrenching experience)?
tmabiker is offline
post #2 of 31 (permalink) Old 04-25-2019, 09:48 AM
Date registered: Sep 2016
Vehicle: 2002 E55 AMG Sedan
Quoted: 263 Post(s)
It's not too hard but it does require patience and the correct tools. I don't know what model you have but, here's a link that shows how to do it.
https://www.benzworld.org/forums/w21...ent-write.html
tmabiker likes this.
illstplaya is offline
post #3 of 31 (permalink) Old 04-25-2019, 10:06 AM Thread Starter
Quoted: 23 Post(s)
Thanks that is a great write up!
tmabiker is offline
post #4 of 31 (permalink) Old 04-25-2019, 10:11 AM
Date registered: Jun 2012
Vehicle: 1998 E320 base sedan @ 160kmiles
Quoted: 1116 Post(s)
Send a message via Skype™ to mrboca
If you want to change the compressor, yes, but if you want to replace the coil have a look at the fine write-up from G-AMG.
https://www.benzworld.org/forums/w14...ch-coil-r.html
Also find out first what the problem is. The coil has a fuse in it so if the compressor is about to seize, the pulley would get hot and open the thermal fuse and letting the clutch release the shaft, so your drive belt is not shredded to pieces.
Make sure that the compressor is not binding.
mrboca is offline
post #5 of 31 (permalink) Old 04-25-2019, 10:42 AM Thread Starter
Quoted: 23 Post(s)
So it might be just the fuse that needs replacing? I think maybe this happened over the winter when I smelled smoke for a few minutes and there was a bit of burnt oil/rubber? that appeared sprayed from the compressor.
tmabiker is offline
post #6 of 31 (permalink) Old 04-25-2019, 10:49 AM
No. The fuse is embedded in the coil assembly. If the fuse opens you get the 419 fault, and you either replace the whole coil, or the compressor. I would go for the latter. Your compressor was seizing and the belt got hot due to slips around the pulley, then the fuse melted to open the circuit and released the clutch, saved you from a broken belt slapping around damaging components under the hood.
Witek_M and tmabiker like this.
mrboca is offline
post #7 of 31 (permalink) Old 04-25-2019, 01:59 PM Thread Starter
Quoted: 23 Post(s)
Okay thanks, would it be worth trying to recharge the refrigerant before doing all that or at least for the short term? My readings for #7 are 03-4 at night and 5-6 during the day in the sun today.
tmabiker is offline
post #8 of 31 (permalink) Old 04-25-2019, 02:04 PM
Try resetting the fault code and run the a/c. If the code comes back, "It's dead, Jim" . No amount of refrigerant will mend the opened fuse in the clutch. If the clutch does not turn the compressor, how will you feed the refrigerant into the system ?
mrboca is offline
post #9 of 31 (permalink) Old 04-25-2019, 02:07 PM Thread Starter
Quoted: 23 Post(s)
Okay thanks, I tried resetting (holding up and down buttons) but it didn't seem to work. Is there another way? Also I read somewhere that if the refrigerant is too low the compressor automatically stops working and won't until it gets filled back up a bit, does that sound right? https://www.benzworld.org/forums/w21...-clearing.html
tmabiker is offline
post #10 of 31 (permalink) Old 04-25-2019, 02:12 PM
Yes, the correct way of resetting the code. see item 9 in the attached (press AUTO buttons simultaneously for more than 2 seconds).
http://manual.startekinfo.com/manual/JSP/cc/3_5/m15.jsp
The compressor will only turn if the clutch engages by the controller, and if you have a coil fuse problem the compressor will not engage, and will not start even it is full to the brim with refrigerant.
mrboca is offline
"Airmatic Visit Workshop" after strut's replacement Nachogy W220 S-Class 16 12-31-2017 10:47 AM
DIY 1999 S320 Mercedes coolant thermostat replacement with picturess chickenfriend W140 S-Class 2 02-16-2013 04:30 PM
Ohhhhhhhhhhhhhh Yahoo Japan (as in Donuts) stormtigers W124 E,CE,D,TD Class 5 10-12-2012 04:35 PM
Spark Plug Replacement Interval - and Replacement Plug pengineer W126 S,SE,SEC,SEL,SD,SDL Class 2 03-03-2012 01:52 PM
DIY Procedures (Updated 03.18.08) JOE55 W210 E-Class 0 07-05-2007 11:48 AM
