Battery Weak - Mercedes-Benz Forum
post #1 of 19 (permalink) Old 04-18-2019, 04:31 PM Thread Starter
Date registered: Aug 2005
Vehicle: 1999 E320, 2001 E320, 2004 S430
Quoted: 36 Post(s)
Battery Weak
1999 E320, 190K miles.
The car's battery was weak and not able to start the car. I used a battery load tester and determined that it needs to be replaced. A new MB battery was installed. It worked for several days and it's weak again. I measured the alternator output and it's charging the battery at 13.86V. Is that alternator also weak and needs to be replaced too?
Thanks for your input.
cerritos is offline
post #2 of 19 (permalink) Old 04-18-2019, 05:06 PM
Date registered: Sep 2016
Vehicle: 2002 E55 AMG Sedan
Quoted: 262 Post(s)
You have something draining your battery when the car is off. You have to find it by using a multimeter and measuring the draw in milliamps. Then you have to start pulling fuses until you see a noticeable drop in draw. Once you find which fuse is causing it, you have to then look and see what components are on that circuit and figure out which component is causing the current draw.
I had to do this in September of 2017. Turned out the cause of my dead battery after 2 days was the teleaid module not going to sleep. I just unplugged it and the battery drain stopped.
cerritos and Witek_M like this.
illstplaya is offline
post #3 of 19 (permalink) Old 04-18-2019, 06:47 PM
tabijan's Avatar
Date registered: Jan 2017
Vehicle: 1998 E320s sedan and wagon
Quoted: 215 Post(s)
Where is the teleaid module?
Sixto
02 C320 wagon
tabijan is offline
post #4 of 19 (permalink) Old 04-18-2019, 07:06 PM
Quoted: 262 Post(s)
Sixto
02 C320 wagon
Behind the trunk lining, on the left side of the trunk, next to the left trunk hinge.
post #5 of 19 (permalink) Old 04-18-2019, 08:22 PM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 770 Post(s)
There are dozen other things that may cause battery drain. Teleaid should be disconnected because it is defunct, obsolete and worthless.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #6 of 19 (permalink) Old 04-18-2019, 09:26 PM
Date registered: Jun 2012
Vehicle: 1998 E320 base sedan @ 160kmiles
Quoted: 1107 Post(s)
Send a message via Skype™ to mrboca
Was Tele-aid available in a 1999 E320 ?
mrboca is offline
post #7 of 19 (permalink) Old 04-18-2019, 10:08 PM
Quoted: 262 Post(s)
The teleaid was an example of the battery drain that my car had lol.
I don't know if his car even has a teleaid module. The point was to give some relief and let him know the weird battery drain issues happen to everyone and it's usually not a difficult problem to fix.
post #8 of 19 (permalink) Old 04-18-2019, 10:09 PM
Quoted: 262 Post(s)
That's true. But you do lose one useful thing and that is the voice control feature.
post #9 of 19 (permalink) Old 04-18-2019, 11:42 PM Thread Starter
Quoted: 36 Post(s)
Thanks for your suggestions. I will perform the battery drain diagnose as suggested.
My 1999 E320 does not have the antenna on the roof. Does that mean it does not have the teleaid?
To unplug the teleaid module, I assume it involves removing the trunk lining. Can the teleaid module be easily identified?
cerritos is offline
post #10 of 19 (permalink) Old 04-19-2019, 01:47 AM
Before you pull your trunk lining, check if you have a red SOS button next to the front dome lights. If you do not, you do not have Tele-aid.
mrboca is offline
Battery replacement recommendation for '04 ML-350 erikluca W163 M-Class 22 03-16-2015 07:36 AM
Brand New Bosch Premium Performance Car Battery Group Size 49 - Mercedes BMW andyb For Sale/Wanted/Trade/Giveaway 2 08-21-2014 08:07 AM
A problem to test the more experienced members peterjacobs W211 E-Class 14 06-02-2009 04:23 AM
Check Engine Light -- Caused by weak battery??? soundquest W124 E,CE,D,TD Class 1 04-21-2009 06:19 PM
Starting problems Ericeclass W210 E-Class 38 05-23-2008 07:47 AM
