Trunk button center console not working - Mercedes-Benz Forum
post #1 of 17 (permalink) Old 04-12-2019, 06:31 PM Thread Starter
LoveMyE320's Avatar
Date registered: Mar 2019
Vehicle: 2002 Mercedes Benz E320 W210
I have not checked it out yet but is the trunk button separate from the window controls? My trunk button stopped working and trying to find one is slim pickings. I've checked everywhere. Any help would be appreciated.
LoveMyE320 is offline
post #2 of 17 (permalink) Old 04-12-2019, 07:03 PM
khomer2's Avatar
Date registered: Nov 2015
Vehicle: w163 02 ML500 W210 97 E50Amg w202 99 C230K w124 - need more space, time to build again
Quoted: 169 Post(s)
I assume your key still opens the trunk, yes?
Did you check the fuse box under the back seat?
khomer2 is online now
post #3 of 17 (permalink) Old 04-12-2019, 07:32 PM
Date registered: Jun 2012
Vehicle: 1998 E320 base sedan @ 160kmiles
Quoted: 1040 Post(s)
Send a message via Skype™ to mrboca
No. It is part of the assembly together with the mirror and window switches. You can buy the assembly from Ebay or get one from a Junk Yard (if you know the problem is the trunk switch itself.).
mrboca is online now
post #4 of 17 (permalink) Old 04-13-2019, 08:53 AM Thread Starter
LoveMyE320's Avatar
I have checked the fuse and it's good. I'm going to have to get it from a junk yard. I looked on Ebay and saw none that looked good. Meaning either the mirror control was bad or something was missing from them. There was one with an esp button but also had the rear window shade button, and there was another that instead of an esp had something called an asr.
post #5 of 17 (permalink) Old 04-13-2019, 09:53 AM
I don't know what you are looking at but the the assembly looks like this.
https://www.ebay.com/itm/98-02-Merce...MAAOSwqDha1gNA
The ESP/ASR and other buttons are not part of the window/trunk/mirror assembly.
post #6 of 17 (permalink) Old 04-13-2019, 09:58 AM
mgill85258's Avatar
Date registered: Oct 2006
Vehicle: 1999 W210 E320
Quoted: 20 Post(s)
I think the trunk button is a vacuum operated system if I'm not mistaken. So, I'm not sure if it's the switch itself that you have verified is bad or if the vacuum lines, somewhere, may be leaking.
My rear passenger door actuator was leaking air so often times there would be a very long delay in opening the trunk due to the leak (I think)... but I'm not sure if the leak in one of the door actuators could cause a problem with opening the trunk, I was just making the association, although I'm not certain if that's correct or not.
Matt
Previously Owned:
1999 W210 E320
2013 W451 fortwo pure
1997 W202 C230
1996 W202 C220
1996 W140 S320 L
1995 W202 C220
mgill85258 is offline
post #7 of 17 (permalink) Old 04-13-2019, 10:08 AM
If the remote (fob) trunk button opens the trunk then it is not a vacuum issue. I assume that the OP is talking about a physically damaged trunk button which is not really uncommon considering the age of the car. It is very hard to replace the button itself, let alone its unavailability as a separate component.
Delay is intentional from the remote trunk button operation. I am not sure about the delay about the center console button. It is possible to have a leaky actuator at the trunk side, which is also common for the doors. But an isolated leaky actuator at a door should not affect the trunk operation.
post #8 of 17 (permalink) Old 04-13-2019, 11:53 AM Thread Starter
LoveMyE320's Avatar
oh wow! 8 didnt see that one! Thanks mrboca!
post #9 of 17 (permalink) Old 04-13-2019, 11:54 AM Thread Starter
LoveMyE320's Avatar
When I use the key fob and hit the trunk open the trunk button on the console fors not light up.
post #10 of 17 (permalink) Old 04-13-2019, 11:57 AM Thread Starter
LoveMyE320's Avatar
When I use the key fob and hit the trunk open the trunk button on the console does not light up
1972 350SL dashboard lighting, clock and center console not working federicosl R/C107 SL/SLC Class 10 09-27-2016 12:40 PM
C240 W203 trunk key fob or door release not working / no noise, nothing SanDiegoMike W203 C-Class 1 10-11-2014 06:08 PM
Trunk Release not working cvjp C208/A208 CLK-Class 3 08-16-2014 08:05 AM
Trunk Button not working and changing the rear turn signal ShazAMG W220 S-Class 5 03-25-2013 06:38 AM
Zebrano Wood Center Console Replacement. A Pictorial - EASY!! slownrusty W124 E,CE,D,TD Class 14 08-03-2004 11:07 AM
