Oil level warning - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 03-19-2019, 04:16 PM Thread Starter
Date registered: Dec 2017
Vehicle: 1998 E320
Oil level warning
Question concerning '98 E320 we picked up last year...
First oil change, done at local garage - I supplied the filter, crush ring, etc. After the oil change, oil level near minimum error appears, then oil level below minimum error after 15 minutes or so. As per dip stick check, level appears fine.
Garage claims oil sensor wonky after oil change, quoted $500+ to replace, which I skipped.
As FYI: Car currently has 50,000 miles on it, no previous issues with oil level errors. Hasn't burned or leaked any oil in the year we've owned it.
Ideas, thoughts, experience?
yoeddy is offline
post #2 of 16 (permalink) Old 03-19-2019, 04:28 PM
Date registered: Mar 2019
Vehicle: 1998 E300 turbo diesel
Quoted: 9 Post(s)
500+ is a lot of money but I believe the sensor is inside the oil pan so that would have to come off.
Mr Krabs is offline
post #3 of 16 (permalink) Old 03-19-2019, 04:58 PM
Date registered: Sep 2016
Vehicle: 2002 E55 AMG Sedan
Quoted: 249 Post(s)
Sensor is most likely bad. You can check the wiring to make sure they didn't damage anything but I doubt they would have because the wires aren't near the drain plug or filter.
illstplaya is online now
post #4 of 16 (permalink) Old 03-19-2019, 05:19 PM
Date registered: Jun 2012
Vehicle: 1998 E320 base sedan @ 160kmiles
Quoted: 1045 Post(s)
Send a message via Skype™ to mrboca
Have a look at the TSB below.
My experience with this was, I was having the oil minimum / faulty messages from time to time. I replaced the battery, and the sensor messages magically disappeared. Was it the low battery voltage (only appeared when before I started the car and sometimes) or was it the oil sensor electronics needed a reset ?. Who knows. BTW the sensor has smart circuitry in it to determine the oil level as well as oil quality. That is why it is around 100 bucks. The rest is the hard job of removing the oil pan, and re-installing it.
Is your mechanic honest ?
wlb50 and southpaw like this.
mrboca is online now
post #5 of 16 (permalink) Old 03-20-2019, 06:43 PM
Benzyle's Avatar
Date registered: Nov 2013
Vehicle: MY05 CLK55 AMG , MY05 CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
Quoted: 267 Post(s)
Doesn't the sensor just unbolt from the bottom of the pan ?
Is it really necessary to remove the pan first ?
Benzyle is offline
post #6 of 16 (permalink) Old 03-20-2019, 06:52 PM
No, and yes.
The oil sensor is accessed from the bottom for 2001+ cars. This is for 1998 E320.
https://www.benzworld.org/forums/5224840-post6.html
Benzyle likes this.
post #7 of 16 (permalink) Old 03-20-2019, 07:39 PM
Kajtek1's Avatar
Quoted: 1892 Post(s)
"fine" can have million variations, so what is it?
If it is not touching max scale, I would add 1l of oil and see if that will quiet the warning.
Kajtek1 is offline
post #8 of 16 (permalink) Old 03-22-2019, 05:56 AM
tuttebenne's Avatar
Date registered: Jul 2005
Vehicle: W124
Quoted: 453 Post(s)
Avoid overfilling the crankcase. Add just enough oil to raise the level to the "maximum" indication on the dipstick,
'93 400E
'93 500E
'94 E320TE
'00 E320
'02 E320
'73 Alfa GTV
'77 308GTB
tuttebenne is online now
post #9 of 16 (permalink) Old 03-23-2019, 01:12 AM
wlb50's Avatar
Date registered: Mar 2013
Vehicle: 1996 SL500, 2000 E430
Quoted: 658 Post(s)
Is that an M104 straight 6 or the M112 V6? If that M104 is like my old M103 (they shared the same block) the sensor is just on the side of the oil pan, secured by 2 bolts. It is strange that the error appeared right after you got it back. If it is on the side, did the wire get jarred loose?
If it is inside the pan I haven't a clue ;-)
wlb50 is offline
post #10 of 16 (permalink) Old 03-23-2019, 06:57 AM
Quoted: 9 Post(s)
i'm pretty sure 98' had the v6. pre 98' had the I6.
wlb50 likes this.
Mr Krabs is offline
DIY: how to change oil s430 95g atl W220 S-Class 36 04-17-2016 06:16 AM
Amsoil vs Mobil 1 Bruce24 W211 E-Class 46 06-16-2015 09:48 PM
Low oil level warning JSRacing V-Class 25 12-10-2012 04:27 AM
Who Do You Trust? Qubes Off-Topic 75 08-19-2010 06:35 AM
