10w40 high mileage will hurt engine??? - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 03-16-2019, 02:23 AM Thread Starter
Shpingalet's Avatar
Date registered: Nov 2010
Vehicle: 2001 E430 4Matic
Quoted: 44 Post(s)
Hi guys ...
I have 138xxx miles ...its a M113 engine owned about a 1.5 years
Previous owner seems like neglected oil change..due the deposits on valve covers ..and seem like conventional oil was used ...
Can I use 10w40 in this kind engine? I heard think oil is going to help ... because engine is getting wear and opens tolerance between parts... and thick oil such as 10w40 will help ....
So should I keep use 5w40 or better stick to 10w40...??????
And I have oil consumption..about 1qt per 3000 miles ....
Shpingalet is offline
post #2 of 8 (permalink) Old 03-16-2019, 09:07 AM
Kajtek1's Avatar
Quoted: 1965 Post(s)
1. your engine was design to run dino oils
2. 138k miles is not high mileage
3. going to 10 grade oil will not improve normal lubrication, but will slow delivering the oil on cold start.
I don't think such change would make difference you can notice this way, or the other, but read some about oil quality. Just viscosity is not all that matters.
Kajtek1 is offline
post #3 of 8 (permalink) Old 03-16-2019, 01:04 PM
Date registered: Sep 2016
Vehicle: 2002 E55 AMG Sedan
Quoted: 270 Post(s)
I would stay with 0w-40 or 5w-40.
illstplaya is offline
post #4 of 8 (permalink) Old 03-16-2019, 01:30 PM
wlb50's Avatar
Date registered: Mar 2013
Vehicle: 1996 SL500, 2000 E430
Quoted: 671 Post(s)
"1. your engine was design to run dino oils"
The M113 was not designed to run dino oils due to FSS. In fact, there was a class-action suit because early on some dealers were putting in dino oil and due to the extended intervals of FSS (12,000 miles and up) the engines were getting crud - some were replaced under warranty.,
If you are trying to clean out the crud I would go with a synthetic - change at 5,000 miles or so - do that maybe once or twice - then regular FSS mandated intervals.
wlb50 is offline
post #5 of 8 (permalink) Old 03-19-2019, 08:47 PM Thread Starter
Shpingalet's Avatar
Quoted: 44 Post(s)
Does M112 and M113 was invent to run with dino oil ... ???
Is this his 229.1 specs?????
Engine was engineered in mid 90s......!
At those time was only 229.1 available?????
229.1 it's a 10w40 ...most of that .....
So 10w40 it's fine ???
post #6 of 8 (permalink) Old 03-19-2019, 09:46 PM
Kajtek1's Avatar
The 229.1 and other MB oil classifications come on the market 10-15 years ago.
Your car is well older than this.
Still disappointing lack of knowledge about oils.
About 1/2 of 229.1 classify oils are dino oils.
We are talking 2-300 of oils that can be used, so over 100 available in dino or mixes.
https://bevo.mercedes-benz.com/bevolisten/229.1_en.html
Kajtek1 is offline
post #7 of 8 (permalink) Old 03-20-2019, 06:57 AM
Date registered: Jun 2012
Vehicle: 1998 E320 base sedan @ 160kmiles
Quoted: 1142 Post(s)
Send a message via Skype™ to mrboca
Originally Posted by Shpingalet View Post
Hi guys ...
I use Mobil 1 10W40 high mileage with no problems.
mrboca is online now
post #8 of 8 (permalink) Old 03-20-2019, 02:21 PM
Supporting Vendor
AutohausAZ's Avatar
Date registered: Dec 2004
Vehicle: Too Many to List
Quoted: 31 Post(s)
To slowly dissolve existing sludge (the safest way to do it, you don't want to knock chunks of grime loose), many experts suggest changing to synthetic oil. The first time you run the new synthetic, change it again after half of the normal mileage interval, as a large amount of sludge may dissolve initially and you don't want that dirty oil pumping through your engine any longer than necessary. After that, the cleaning process will be slower and the normal oil change interval is fine.
Visit the AutohausAZ Vendor Section for special pricing for Benzworld members:
AutohausAZ is offline
Maintenance Manuals Merc-S600 W140 S-Class 214 08-12-2018 01:58 PM
R129 SL500 '95 ticking noise/oil pressure bmcraddock R129 SL-Class 18 11-11-2017 09:04 AM
Code Help! jporrata W202 C-Class 10 07-31-2009 08:02 PM
Engine's History (G. Daimler & W. Maybach) Curacao General Mercedes-Benz 1 08-03-2006 03:37 AM
ML NOT STARTING IN HOT WEATHER OR HOT ENGINE!!!!! jmarenas W163 M-Class 11 09-06-2005 03:42 PM
