Battery dead in my 97 E420, and can't get in... - Mercedes-Benz Forum
post #1 of 54 (permalink) Old 03-14-2019, 04:13 PM Thread Starter
War_Destroyer's Avatar
Date registered: Jun 2018
Vehicle: 1997 E420, 1999 E320, 2002 S600
Quoted: 19 Post(s)
Hi guys, so I didn't use my E420 this past winter and now the battery is dead. Is there an easy way to jump it from the undercarriage since I can't get in to open the hood?
Sent from my Galaxy Note9 using Tapatalk
War_Destroyer is offline
post #2 of 54 (permalink) Old 03-14-2019, 04:56 PM
Date registered: Sep 2016
Vehicle: 2002 E55 AMG Sedan
Quoted: 270 Post(s)
No. But don't you have the metal key? If not, then how do you start the car?
Anyway if you don't have the metal key, you can try to take off the plastic cover on the bottom of the engine and reach up to pull on the hood release cable. But I'm not sure how much room you would have with the E420.
illstplaya is offline
post #3 of 54 (permalink) Old 03-14-2019, 05:40 PM
tuttebenne's Avatar
Date registered: Jul 2005
Vehicle: W124
Quoted: 474 Post(s)
Would it be worth a try attaching a positive jumper cable to the heavy positive cable on the battery and of course ground the other one?
'93 400E
'93 500E
'94 E320TE
'00 E320
'02 E320
'73 Alfa GTV
'77 308GTB
tuttebenne is offline
post #4 of 54 (permalink) Old 03-14-2019, 05:45 PM
Quoted: 270 Post(s)
Yeah you can do that.
post #5 of 54 (permalink) Old 03-14-2019, 05:51 PM
Date registered: Jun 2012
Vehicle: 1998 E320 base sedan @ 160kmiles
Quoted: 1142 Post(s)
Send a message via Skype™ to mrboca
Actually you do not need a heavy jumper cable, if the purpose is to open the car doors so you can open the hood to charge the battery. For my other car, the battery is under the hood, close to the firewall. I had connected a fused cable that came with the battery maintainer which I extended to just under the passenger side wiper. The cable has a special connector and a protector cap. When I do not use the car. I put it on the maintainer. Even if I forget it and let the battery to discharge, I can connect the maintainer to charge the battery enough to open the doors.
I am thinking of doing that with the E320, using the charge posts under the hood at the driver's side. You can get fused cables with proper connectors to mate with the maintainer from Amazon or Ebay.
mrboca is online now
post #6 of 54 (permalink) Old 03-14-2019, 06:32 PM Thread Starter
Quoted: 19 Post(s)
I do have the flip key, but I get no response from the car when I press the button, and I also get no response when insert and turn the key in trunk's keyhole. The keyhole in the front passenger door never worked, it just turns freely.
I bought a brand new Bosch battery just a few months ago in mid October. I drove it sparingly though because I had been working on it on and off with your help @mrboca and others in this forum. I just didn't think the battery would go flat this quickly...
So I'm locked out of the car, the battery is under the back seats, I can't open the hood. I was hoping there would be like a third positive terminal under the car somewhere, or a hack that you guys would know of.
Even if there was, I'm also not sure if I can jack the car up, it's on a slight incline in the driveway, parking brake not engaged. Maybe its safe to lift from one side and the help of a wheel chock?
post #7 of 54 (permalink) Old 03-14-2019, 07:11 PM
Witek_M's Avatar
Date registered: Sep 2008
Vehicle: 1972
Quoted: 834 Post(s)
With key blade unlock the car from right door handle.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #8 of 54 (permalink) Old 03-14-2019, 07:15 PM Thread Starter
Quoted: 19 Post(s)
That keyhole doesn't work at all. The key just turns freely. That's why I've used the trunk keyhole when flip key battery died, but now the actual car battery is the issue...
post #9 of 54 (permalink) Old 03-14-2019, 07:22 PM
Witek_M's Avatar
Vehicle: 1972
Quoted: 834 Post(s)
Lift it up. Connect positive charger lead to large lug on the starter. Negative to any clean engine block part.
boyd waugh and wlb50 like this.
1972 280SEL 4.5
1999 ML320
2000 E320
2003 ML350
Witek_M is offline
post #10 of 54 (permalink) Old 03-14-2019, 07:42 PM
Can you open the trunk with the key ?
